WT1011N
WT1011N
    ATG
    WT1011:WT1/WP65/XNTA/WSR201120
WT1011N 数据手册
PROFESSIONAL Product Information WT1011 1-Channel Power Unit, 95 W Product no.: WT1011N Benefits Digital Soldering Station WT1, 120V, 60Hz (95W) with WP65 and WSR201 WP65 The soldering iron (65 W) power response tip for delicate and small applications. Tip family XNT OFF time, Prozess window, Lock function, Offset PROFESSIONAL Product Information Technical Data Dimensions L x W x H (mm) Dimensions L x W x H (inches) Weight (approx.) in kg 149 x 138 x 101 5,87 x 5,44 x 3,98 1.9 Voltage 120 V Power 95 W Channels 1 Temperature range (depends on tool) °C Temperature range (depends on tool) °F Temperature accuracy °C 50 - 450 150 - 850 ±9 Temperature accuracy °F ±17 Temperature stability °C ±2 Temperature stability °F ±4 Equipotential bonding socket Display Via 3,5 mm pawl socket on front of device Backlit LCD Air consumption l/min --- Operating pressure in bar/psi --- Capacity l/min --- Vacuum --- Weller Tools GmbH Carl-Benz-Straße 2 74354 Besigheim Germany Phone: +49 (0) 7143 / 580-0 Fax.: +49 (0) 7143 / 580-108 Email: info@weller-tools.com Web: www.weller-tools.com
WT1011N 价格&库存
很抱歉,暂时无法提供与“WT1011N”相匹配的价格&库存,您可以联系我们找货
