WT1010HN
WT1010HN
    ATG
    WT1010H:WT1H/WP120/XTB/WSR2011
WT1010HN 数据手册
PROFESSIONAL Product Information WT1010H 1-Channel Power Unit, 150 W Product no.: WT1010HN Benefits Digital Soldering Station WT 1H 120V, 60Hz (150W) with WP120 and WSR201 WP 120 (120 W): Power-Response soldering tip, XT Tip family and XT soldering handpiece OFF time, process window, Lock function, Offset Compatible with a large selection of soldering pencils, pre-heat plates and solder baths 2-in-1 WSR Safety Rest, flips between sponge and brass wool Stackable Units, saving space on the workbench RS232 protocol for Automation and Control PROFESSIONAL Product Information Technical Data Dimensions L x W x H (mm) Dimensions L x W x H (inches) Weight (approx.) in kg 149 x 138 x 101 5.87 x 5.43 x 3.98 3 Voltage 120 V Power 150 W Channels 1 Temperature range (depends on tool) °C Temperature range (depends on tool) °F Temperature accuracy °C 50 - 550 150 - 950 ±9 Temperature accuracy °F ±17 Temperature stability °C ±2 Temperature stability °F ±4 Equipotential bonding socket Display Via 3,5 mm pawl socket on front of device Backlit LCD Air consumption l/min --- Operating pressure in bar/psi --- Capacity l/min --- Vacuum --- Weller Tools GmbH Carl-Benz-Straße 2 74354 Besigheim Germany Phone: +49 (0) 7143 / 580-0 Fax.: +49 (0) 7143 / 580-108 Email: info@weller-tools.com Web: www.weller-tools.com
WT1010HN 价格&库存
很抱歉,暂时无法提供与“WT1010HN”相匹配的价格&库存,您可以联系我们找货
