9g Metal Gear Micro Servo (1.8Kg )
SKU:SER0039
INTRODUCTION
Do you need a servo for a tiny little project? Or are you seeking for an affordable solution? This mini metal servo is quite
impressive, it does quite the job for a large range of tasks. With metal gear, it could gives you a 1.8kg*cm torque. Pretty strong
regarding its size. Suitable for Beam robots and other automation tasks. Keep in mind that if you need some heavy lifting you
should be considering some of our other options. This servo is for you if you are planning on building smaller size robots.
Why Metal? Usually a metal gear servo will last longer than plastic version, especially for robotic applications which require
servo moving at most of time. Metal servo provide way better solid performance than plastic version.
SPECIFICATION
Operating Voltage: 4.8~6V
liLimit angle: 180°± 10°
Reduction ratio: 320:1
No load speed: 0.12 seconds / 60 degrees (4.8V)
Stall torque: 1.8 kg / cm (4.8V)
Stall current: 300mA (4.8V)
Operating temperature: -10 ~ +50 degrees Celsius
Cable length: 180mm(7")
Size: 22.3*11.8*26.3 mm(0.88*0.46*1.04")
Weight: 12 grams
SHIPPING LIST
DMS-MG90 micro servo x1
https://www.dfrobot.com/product-1338.html 5-4-17
很抱歉,暂时无法提供与“SER0039”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+70.235601+9.13040
- 3+61.977703+8.05690
