Micro DC Motor with Encoder‐SJ02 SKU: FIT0458
Contents
1 Introduction
2 Specification
3 Pin Description
4 Tutorial
4.1 Ready to work
4.2 Wiring Diagram
4.3 Interrupt Port with Different Board
4.4 Encoder Sample Code 1
4.5 Encoder Sample Code2
5 More
Introduction
This is the DFRobot Micro DC geared motor with encoder. It is a motor with a 120:1 gearbox and an
integrated quadrature encoder that provides a resolution of 16 pulse single per round giving a
maximum output of 1920 within one round. With an Arduino controller and motor driver, applications
for this might include a closed-loop PID control or PWM motor speed control. This motor is an ideal
option for mobile robot projects. The copper output shaft, embedded thread and reinforced
connector greatly extends the motor's service life.
Specification
Gear ratio: 120:1
No-load speed @ 6V: 160 rpm
No-load speed @ 3V: 60 rpm
No-load current @ 6V: 0.17A
No-load current @ 3V: 0.14A
Max Stall current: 2.8A
Max Stall torque: 0.8kgf.cm
Rated torque: 0.2kgf.cm
Encoder operating voltage: 4.5~7.5V
Motor operating voltage: 3~7.5V (Rated voltage 6V)
Operating ambient temperature: -10~+60
Pin Description
Grade
Name
1
2
Motor power supply pin +
Motor power supply pin -
3
Encoder A phase output
4
Encoder B phase output
5
6
Encoder supply GND
Encoder supply +
Functional Description
3-7.5V,Rated voltage6V
Changes square wave with the output frequency of
Motor speed
Motor speed(interrupt port)
4.5-7.5V
Tutorial
Ready to work
hardware
DFRduino UNO x1
DC power supply x1
L298 x1
software
Arduino IDE Download Arduino IDE https://www.arduino.cc/en/Main/Software
Wiring Diagram
This tutorial is intended to use the encoder, Select D2 pin and D3 pin, Wherein D2 as an interrupt
port, D3 as an input pin. In practice, two pins need to ensure that one of pins must be an interrupt
pin, and the other definable (see the interrupt port with different board).
Notcie: attachInterrupt()
If using an Arduino UNO and you want to use interrupt port 0 (Int.0), you need to connect digital pin
D2 on the board. The following code is only used in UNO and Mega2560. If you want to use Arduino
Leonardo, you should change digital pin D3 instead of digital pin D2.
See the link for details http://arduino.cc/en/Reference/AttachInterrupt
//The sample code for driving one way motor encoder
const byte encoder0pinA = 2;//A pin -> the interrupt pin 0
const byte encoder0pinB = 3;//B pin -> the digital pin 3
byte encoder0PinALast;
int duration;//the number of the pulses
boolean Direction;//the rotation direction
void setup()
Serial.begin(57600);//Initialize the serial port
EncoderInit();//Initialize the module
void loop()
Serial.print("Pulse:");
Serial.println(duration);
duration = 0;
delay(100);
void EncoderInit()
Direction = true;//default -> Forward
pinMode(encoder0pinB,INPUT);
attachInterrupt(0, wheelSpeed, CHANGE);
void wheelSpeed()
int Lstate = digitalRead(encoder0pinA);
if((encoder0PinALast == LOW) && Lstate==HIGH)
int val = digitalRead(encoder0pinB);
if(val == LOW && Direction)
Direction = false; //Reverse
else if(val == HIGH && !Direction)
Direction = true;
//Forward
encoder0PinALast = Lstate;
if(!Direction)
else
duration++;
duration--;
Code 1 Expected Output:
Explanation: Here you can see serial data. When the motor turns forward, the digital output value is
> 0. When the motor reverses direction, digital output < 0. The faster the motor's speed, the greater
the value of the number.
PID control: PID algorithm to control the motor speed by L298P DC motor driver board
1. Motor power port is connected to the L298 drive motor M1 port
2. Download and install Arduino PID https://github.com/br3ttb/Arduino-PID-Library/
#include
int E_left =5; //The enabling of L298PDC motor driver board connection to the
digital interface port 5
int M_left =4; //The enabling of L298PDC motor driver board connection to the
digital interface port 4
double duration,abs_duration;//the number of the pulses
boolean result;
double val_output;//Power supplied to the motor PWM value.
double Setpoint;
double Kp=0.6, Ki=5, Kd=0;
PID myPID(&abs_duration, &val_output, &Setpoint, Kp, Ki, Kd, DIRECT);
void setup()
Serial.begin(9600);//Initialize the serial port
pinMode(M_left, OUTPUT);
oard for the output mode
//L298P Control port settings DC motor driver b
pinMode(E_left, OUTPUT);
Setpoint =80;
//Set the output value of the PID
myPID.SetMode(AUTOMATIC);//PID is set to automatic mode
myPID.SetSampleTime(100);//Set PID sampling frequency is 100ms
void loop()
advance();//Motor Forward
abs_duration=abs(duration);
result=myPID.Compute();//PID conversion is complete and returns 1
if(result)
Serial.print("Pluse: ");
duration = 0; //Count clear, wait for the next count
void EncoderInit()
void wheelSpeed()
Direction = true;
//Forward
if(!Direction)
else
duration++;
duration--;
void advance()//Motor Forward
digitalWrite(M_left,LOW);
analogWrite(E_left,val_output);
void back()//Motor reverse
digitalWrite(M_left,HIGH);
void Stop()//Motor stops
digitalWrite(E_left, LOW);
Code 2 Expected Behaviour:
The code PID value has been set as 80, so the motor will stabilize at about 80 rpm. If outside forces
such as changes in motor drive voltage, the motor's resistance, etc affect the speed, the program will
adjust the PWM value to stabilize the rotational speed at 80.
More
Motor dimension drawing
https://github.com/Arduinolibrary/DFRobot_Micro_DC_Geared_Motor_with_Encoder/raw/ma
ster/FIT0458%20Micro%20DC%20Motor%20with%20Encoder-SJ02.pdf
https://www.dfrobot.com/wiki/index.php/Micro_DC_Motor_with_Encoder-SJ02_SKU:_FIT0458
Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1458.html 4-27-17
很抱歉,暂时无法提供与“FIT0458”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+75.624961+9.83100
