Metal DC Geared Motor - 6V 133RPM 4.5kg.cm
SKU:FIT0473
INTRODUCTION
This is a metal DC geared motor, 45:1 metal reducer. It has a small size and large torque. The maximum torque could arrive 4.5
kg.cm. It is stable and durable!
SPECIFICATION
Rated Voltage: 6 V
Weight: 90 g
Operating Voltage Range 2~7.5V
Gear reduction ratio: 45:1
D output shaft diameter: 4 mm
No-load speed: 133 RPM @ 6 v
No-load current: 0.13 A
Locked-rotor torque: 4.5 kg.cm
Locked-rotor current: 2.3 A
Operating Temperature: -20~60Ԩ
DOCUMENTS
Dimension https://github.com/Arduinolibrary/DFRobot_Metal_DC_Geared_Motor/raw/master/FIT0473%20GA25Y370%20Dimension.pdf
SHIPPING LIST
Metal DC Geared Motor - 6V 133RPM 4.5kg.cm x1
Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1476.html 4-27-17
很抱歉,暂时无法提供与“FIT0473”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+150.169281+19.42441
