Micro Metal Gear Motor with Connector (75:1)
SKU:FIT0457
INTRODUCTION
This motor has a long (0.365"/9.27 mm) D profile metal output shaft that matches the 42x19mm and 32x7mm dimensions of the
Pololu wheel. The brass faceplate has two mounting holes threaded for M1.6 screws (1.6mm diameter, 0.35mm thread pitch), or
you can use the mounting bracket or extended mounting bracket, which are specifically designed to securely mount the gear
motor while enclosing the exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as
the 42×19mm wheel.
The motor comes with PH2.0 port which is easy to connect and solderless. An integrated circuit enhances its anti-jamming
capability.
Compatible with 2WD MiniQ Robot Chassis
SPECIFICATION
Operating Voltage: 1.0~6.0V
Motor Speed: 290 + 10% rpm@6V
Gear Ratio: 75:1
Rated Speed: 220 + 10% rpm@6V
Rated Current: 70mA@6V
Stall Current: 1000mA@6V
Stall Torque: 0.8kg*cm@6V
Weight: 15g
DOCUMENTS
Motor Dimensions
https://github.com/Arduinolibrary/DFRobot_DC_gearmotor_with_connector/raw/master/N20%20Dimension.pdf
SHIPPING LIST
Micro Metal Gear Motor (75:1) with connector x1
Double PH-2.0 cable x1
Single PH-2.0 cable x1
Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1410.html 4-27-17
很抱歉,暂时无法提供与“FIT0457”相匹配的价格&库存,您可以联系我们找货
