FIT0467
FIT0467
    DFROBOT
    MICROMETALGEARMOTORWITHCONN
FIT0467 数据手册
  Micro Metal Gear Motor with Connector (30:1) SKU:FIT0467 INTRODUCTION This motor has a long (0.365"/9.27 mm) D profile metal output shaft that matches the 42x19mm and 32x7mm dimensions of the Pololu wheel. The brass faceplate has two mounting holes threaded for M1.6 screws (1.6mm diameter, 0.35mm thread pitch), or you can use the mounting bracket or extended mounting bracket, which are specifically designed to securely mount the gear motor while enclosing the exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as the 42×19mm wheel. The motor comes with PH2.0 port which is easy to connect and solderless. An integrated circuit enhances its anti-jamming capability. Compatible with MiniQ Robot Chassis SPECIFICATION         Operating Voltage: 1.0~6.0V Motor Speed: 500 rpm@6V Gear Ratio: 30:1 Rated Speed: 443 rpm@6V Rated Current: 40mA@6V Stall Current: 100mA@6V Stall Torque: 1.2kg*cm@6V Weight: 15g DOCUMENTS Motor Dimensions https://github.com/Arduinolibrary/DFRobot_DC_gearmotor_with_connector/raw/master/N20%20Dimension.pdf  SHIPPING LIST    Micro Metal Gear Motor with connector (30:1) x1 Double PH-2.0 cable x1 Single PH-2.0 cable x1 Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1409.html 4-27-17
FIT0467
物料型号:FIT0467 器件简介:DFRobot的微型金属齿轮电机,具有长9.27mm的D型金属输出轴,适配42x19mm和32x7mm尺寸的Pololu轮。
电机配有易于连接且无需焊接的PH2.0端口,以及增强其防堵转能力的集成电路。
引脚分配:电机带有PH2.0端口,用于连接。
参数特性: - 工作电压:1.0~6.0V - 转速:500 rpm@6V - 齿轮比:30:1 - 额定转速:443 rpm@6V - 额定电流:40mA@6V - 堵转电流:100mA@6V - 堵转扭矩:1.2kgcm@6V - 重量:15g 功能详解:电机具有长金属输出轴,适配特定尺寸的轮子,可使用特定设计的安装支架固定。
电机的PH2.0端口易于连接,且电机具备防堵转能力。
应用信息:兼容MiniQ机器人底盘。
封装信息:电机尺寸详情可参考提供的链接。
以上信息摘自DFRobot提供的PDF文档。
FIT0467 价格&库存
很抱歉,暂时无法提供与“FIT0467”相匹配的价格&库存,您可以联系我们找货
