FIT0468
FIT0468
    DFROBOT
    MICROMETALGEARMOTORWITHCONN
FIT0468 数据手册
  Micro Metal Gear Motor with Connector (50:1) SKU:FIT0468 INTRODUCTION This motor has a long (0.365"/9.27 mm) D profile metal output shaft that matches the 42x19mm and 32x7mm dimensions of the Pololu wheel. The brass faceplate has two mounting holes threaded for M1.6 screws (1.6mm diameter, 0.35mm thread pitch), or you can use the mounting bracket or extended mounting bracket, which are specifically designed to securely mount the gear motor while enclosing the exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as the 42×19mm wheel. The motor comes with PH2.0 port which is easy to connect and solderless. An integrated circuit enhances its anti-jamming capability. Compatible with 2WD miniQ Robot Chassis. SPECIFICATION        Operating Voltage: 1.0~6.0V Motor Speed: 260 rpm@6V Gear Ratio: 50:1 Rated Current: 30mA@6V Stall Current: 350mA@6V Stall Torque: 0.39kg*cm@6V Weight: 15g DOCUMENTS Motor Dimensions https://github.com/Arduinolibrary/DFRobot_DC_gearmotor_with_connector/raw/master/N20%20Dimension.pdf   SHIPPING LIST    Micro Metal Gear Motor with connector (50:1) x1 Double PH-2.0 cable x1 Single PH-2.0 cable x1 Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1418.html 4-27-17
FIT0468
物料型号为FIT0468的微型金属齿轮电机具有以下特点:
- 器件简介:该电机配备了长9.27毫米的D型金属输出轴,与Pololu轮的42x19毫米和32x7毫米尺寸相匹配。
电机的黄铜面板有两个用于M1.6螺丝的安装孔,或者可以使用专门设计的安装支架或加长安装支架来固定电机并保护外露齿轮。
- 引脚分配:电机带有PH2.0端口,易于连接且无需焊接。
- 参数特性: - 工作电压:1.0~6.0V - 转速:260转/分钟@6V - 齿轮比:50:1 - 额定电流:30mA@6V - 堵转电流:350mA@6V - 堵转扭矩:0.39公斤厘米@6V - 重量:15克 - 功能详解:电机具有集成电路,增强了其抗堵转能力,并且与2WD miniQ机器人底盘兼容。
- 应用信息:适用于需要精确控制转速和扭矩的应用场景。
- 封装信息:电机尺寸详细信息可参考提供的链接。
此外,购买时会附带一个微型金属齿轮电机连接器(50:1),一根双PH-2.0电缆和一根单PH-2.0电缆。
FIT0468 价格&库存
很抱歉,暂时无法提供与“FIT0468”相匹配的价格&库存,您可以联系我们找货
FIT0468
  • 1+123.868471+16.10250
  • 3+109.265033+14.20410
库存:3
