FIT0487
FIT0487
    DFROBOT
    MICROMETALGEAREDMOTORW/ENCOD
FIT0487 数据手册
  Micro Metal Geared motor w/Encoder - 6V 41RPM 380:1 SKU:FIT0487 INTRODUCTION A new micro metal gear motor with a difference! This motor comes with a built-in encoder which measures the motor's speed in real time. The average output number of pulses can reach up to 7*2*380 pulses per revolution. The motor has a long (0.354"/9.0 mm) D profile metal output shaft that is compatible with the 42x19mm and 32x7mm dimensions of the Pololu wheel. The brass faceplate has two mounting holes threaded for M1.6 screws (1.6mm diameter, 0.35mm thread pitch), or you can use the mounting bracket or extended mounting bracket which are specifically designed to securely mount the gear motor while enclosing the exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as the 42×19mm wheel. The hall sensor of new version has 7 pole pairs, so the encoder resolution will be increased by 7-fold. Compatible with 2WD miniQ Robot Chassis. SPECIFICATION             Rated Voltage: 6.0 V Motor Speed: 15000 RPM Gear Reduction Ratio: 380:1 Reducer Length: 9.0 mm No-Load Speed: 41 rpm@6v No-Load Current: 60 mA Rated Torque: 2.5 kg.cm Rated Speed: 24 rpm@6V Current Rating: 170 mA Instant Torque:
FIT0487
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
FIT0487 价格&库存
很抱歉,暂时无法提供与“FIT0487”相匹配的价格&库存,您可以联系我们找货
