C5784.41.01
C5784.41.01
    GENERALCABLE
    CABLE COAXIAL RG59 20AWG 1000'
C5784.41.01 数据手册
Coaxial Cable Electronics RG 59/U Type Product Construction: Conductors: Jacket: Applications: • Premium PVC compound Packaging: • Copper-clad steel per ASTM B-869 • Please contact Customer Service for packaging and color options Insulation/Core: • Foam polyethylene (PE) design Shield: • Aluminum braid • Flexfoil® shield CATALOG NUMBER AWG SIZE NOM. DCR C5770 RG 59/U Type UL CL2, CATV, CM CSA CMG 1354 22 Ga. Solid Copper-Clad Steel 73.4 Ω/Mft. C5780 RG 59/U Type MATV UL CL2, CATV, CM CSA CMG 1354 20 Ga. Solid Copper-Clad Steel 45.9 Ω/Mft. C5830 RG 59/U Type Tri-Shield UL CL2, CATV, CM c(UL) CM 20 Ga. Solid Copper-Clad Steel 45.9 Ω/Mft. C5784 RG 59/U Type Quad-Shield UL CL2, CATV, CM CSA CMG 1354 20 Ga. Solid Copper-Clad Steel 45.9 Ω/Mft. 103 INSULATION MATERIAL INCHES mm Foam PE 0.144 3.66 Foam PE 0.144 3.66 Foam PE 0.144 3.66 Foam PE 0.144 3.66 • Suitable for RF signal transmission • CATV • MATV • Drop cable • Local Area Network • Monitor/VDT display • See Coax Connector Cross Reference, pages 192-199 NOMINAL SHIELD O.D. COVERAGE NOM SHLD DCR INCHES mm NOMINAL NOMINAL VELOCITY OF NOMINAL CAPACITANCE PROPAGATION, IMPEDANCE, ATTENUATION pF/ft pF/m MHz dB/100' % Ω 100% Flexfoil® Bonded + 40% Aluminum Braid 11.0 Ω/Mft. 16.00 52.50 78 80 1 10 50 100 200 500 1000 1450 1800 2200 3000 0.50 1.00 2.30 3.30 4.10 6.50 9.40 11.32 12.61 13.94 16.28 16.20 53.15 85 75 1 10 50 100 200 500 1000 1450 1800 2200 3000 0.60 1.20 1.95 2.70 3.70 5.70 8.12 9.78 10.89 12.04 14.06 16.20 53.15 85 75 1 10 50 100 200 500 1000 1450 1800 2200 3000 0.60 1.20 1.95 2.70 3.70 5.70 8.12 9.78 10.89 12.04 14.06 16.20 53.15 85 75 1 10 50 100 200 500 1000 1450 1800 2200 3000 0.60 1.20 1.95 2.70 3.70 5.70 8.12 9.78 10.89 12.04 14.06 100% Flexfoil® Bonded + 40% Aluminum Braid 11.0 Ω/Mft. 100% Flexfoil® Bonded + 95% Aluminum Braid + 100% Flexfoil® 3.0 Ω/Mft. 100% Flexfoil® 1st Bonded (1) 67% (2) 46% Aluminum Braids 4.1 Ω/Mft. Black PVC 0.231 5.87 Black PVC 0.234 5.94 Black PVC 0.242 6.15 Black PVC 0.270 6.86
C5784.41.01 价格&库存
很抱歉,暂时无法提供与“C5784.41.01”相匹配的价格&库存,您可以联系我们找货
