181CVQ60.E2.02
181CVQ60.E2.02
    GENERALCABLE
    CABLE COAXIAL 18AWG
181CVQ60.E2.02 数据手册
VIDEO CABLE The visual image is the core of any home theater or video system. Modern high-resolution and High Definition video formats now demand an even greater degree of quality and bandwidth from the cable interconnect system. To bring a higher level of performance to residential video applications, Sheer Wire video cables are made using the same techniques and materials used in professional, studio-grade video coax. Every Sheer Wire video cable is built to exacting electrical and mechanical specifications then comprehensively tested and verified. As a result, the video image is transmitted with minimal loss or errors delivering exceptionally true and clear images. Through precision, Sheer Wire video cables deliver your clearest vision. BROADBAND COAX BROADBAND COAX: PLENUM HIGH DEFINITION COAX HIGH DEFINITION COAX: PLENUM HIGH DEFINITION COAX: FLEXIBLE HIGH DEFINITION COAX: MINIATURE CCTV COAX CCTV COAX: PLENUM CCTV COAX W/ POWER: JACKETED CCTV COAX W/ POWER: ZIP COMPONENT VIDEO: MINIATURE COMPONENT VIDEO: MINIATURE PLENUM COMPONENT VIDEO: EXTRA-FLEX MINIATURE COMPONENT VIDEO: LOW-LOSS RG6 COMPONENT VIDEO W/ 2 AUDIO PAIRS COMPONENT VIDEO W/ 2 AUDIO PAIRS: PLENUM COMPONENT VIDEO W/ 4 AUDIO & 4 POWER COMPONENT VIDEO W/ 4 AUDIO & 4 POWER: PLENUM COMPONENT VIDEO W/ CATEGORY 5E COMPONENT VIDEO W/ CATEGORY 5E: PLENUM SVHS DUAL MINIATURE COAX TOTAL HOME HYBRID HDMI CABLE ASSEMBLIES DVI CABLE ASSEMBLIES HDMI TO DVI CABLE ASSEMBLIES HDMI AND DVI ADAPTERS High Definition Bandwidth All Sheer Wire video cables are certified to 3, 2.4, or 1GHz to ensure clear and accurate transmission of High Definition digital or high-resolution analog video signals. Low-loss, Gas-injected Dielectric Sheer Wire proprietary nitrogen-injected dielectric lowers the attenuation, provides precision mechanical specifications, and is exceptionally crush resistant. Precision Characteristic Impedance Every Sheer Wire coaxial cable is produced to an exacting impedance to virtually eliminate cable-induced reflections, jitter, and bit-errors in the video signal. Certified Specifications and 100% Swept Test Each reel is comprehensively tested to verify all critical electrical and mechanical specifications and ensure consistent performance. Time Saving Features Features such as easy-to-strip jackets, footage markers, and flexible packaging allow for quick and simplified installation. VIDEO Broadband Coax Pre c i s i o n 7 5: C o a x fo r Broadband, MATV, and CATV 2.4GHz Bandwidth Precision 756 Impedance Copper-clad Steel Conductor Dual- or Quad-shield Versions UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD 181CV6 1 .272” Conductor Insulation (Type, OD) Shield Jacket Type Jacket Colors UL Type Approx. Weight 18 AWG Copper-clad Steel Gas-injected Foam PE, .180” 60% AL Braid, 100% Foil PVC Black CM 26 lbs/Mft 18 AWG Copper-clad Steel Gas-injected Foam PE, .180” 60% AL Braid, 100% Foil PVC Black CM 52 lbs/Mft 18 AWG Copper-clad Steel Gas-injected Foam PE, .180” 40% AL Braid, 100% Foil 60% AL Braid, 100% Foil PVC Black CM 30 lbs/Mft RG6 Broadband Coax 182CV6 2 181CVQ6 1 .272” x .550” RG6 Broadband: Dual Zip .298” RG6 Broadband Coax: Quad Shield Electrical Specifications Impedance Return Loss (100kHz-1GHz), (1GHz-3GHz) Capacitance 75 6 (+/-3) >20dB, >17dB 16.2 pF/ft Cond. DCR per Mft/Shield DCR per Mft Vel. of Prop. 31.9 6/ 9.0 6(60% Shield) 83% 5.3 6(Quad Shield) Broadband Coax: Plenum Attenuation (dB per 100 ft) 1 10 50 100 200 400 700 900 MHz MHz MHz MHz MHz MHz MHz MHz 1 GHz 1.2 GHz 1.45 GHz 2.4 GHz 0.24 6.15 6.81 7.56 9.90 0.65 1.39 1.92 2.65 3.78 3.98 5.83 Pre c i s i o n 7 5: C o a x fo r Broadband, MATV, and CATV 2.4GHz Bandwidth Precision 756 Impedance Copper-clad Steel Conductor Dual- or Quad-shield Versions UL Plenum Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD Conductor Insulation (Type, OD) Shield Jacket Type Jacket Colors UL Type Approx. Weight IP181CV9 1 .237” 18 AWG Copper-clad Steel Foam FEP, .170” 90% AL Braid, 100% Foil Plenum PVC White CMP 24 lbs/Mft 18 AWG Copper-clad Steel RG6 Broadband Coax: Plenum Quad Shield Foam FEP, .170” 40% AL Braid,100% Foil 60% AL Braid,100% Foil Plenum PVC White CMP 30 lbs/Mft RG6 Broadband Coax: Plenum IP181CVQ6 1 .257” Electrical Specifications Impedance Max Return Loss (1-455MHz), (455MHz-2.4GHz) Capacitance Cond. DCR per Mft 75 6 (+/-3) >21dB, >15dB 16.0 pF/Ft 31.9 6 Shield DCR per Mft Attenuation (dB per 100 ft) Vel. 1 10 50 100 200 400 700 900 1 1.2 1.45 2.4 of Prop. MHz MHz MHz MHz MHz MHz MHz MHz GHz GHz GHz GHz 7.2 6(90% Shield) 84% 5.5 6(Quad Shield) 0.30 0.70 1.50 2.10 3.10 4.50 6.00 6.90 7.30 8.08 8.97 12.0 15 www.sheerwire.com VIDEO High Definition Coax Pre c i s i o n 7 5: C o a x f o r Un c o mp res s ed HDTV Vid eo 3GHz Bandwidth for HDTV Low Attenuation Precision 756 Impedance Gas-injected Polyethylene Dielectric UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD 181VT9 1 .272” Conductor Insulation (Type, OD) Shield Jacket Type Jacket Colors UL Type Approx. Weight 18 AWG Solid BC Gas-injected Foam PE, .180” 95% TC Braid, 100% Foil PVC Black CM FT-4 41 lbs/Mft 20 AWG Solid BC Gas-injected Foam PE, .146” 95% TC Braid, 100% Foil PVC Black CM FT-4 35 lbs/Mft RG6 HDTV/DTV Digital Coax 201VT9 1 .242” RG59 HDTV/DTV Digital Coax Electrical Specifications Cond. DCR Capacitance per Mft Shield DCR per Mft Nominal Attenuation (dB per 100 ft) Vel. 1 3.6 10 71.5 135 270 360 720 1 1.5 2.25 of Prop. MHz MHz MHz MHz MHz MHz MHz MHz GHz GHz GHz 3 GHz Part # Impedance Return Loss (100kHz-3GHz) 181VT9 75 6(+/-3) >17dB 16.3 pF/ft 6.4 6 2.8 6 83% 0.22 0.43 0.70 1.60 2.10 2.96 3.40 4.95 5.87 7.30 201VT9 75 6(+/-3) >17dB 16.3 pF/ft 10.2 6 3.5 6 83% 0.28 0.53 0.86 2.05 2.71 3.80 4.38 6.40 7.57 9.29 11.57 13.36 High Definition Coax: Plenum 9.13 10.65 Pre c i s i o n P l e n u m R a t e d 7 5: C o a x fo r Un c o mp res s ed HDTV Vid eo 3GHz Bandwidth for HDTV Low Attenuation Precision 756 Impedance Gas-injected Teflon Dielectric UL Plenum Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD Conductor Insulation (Type, OD) Shield Jacket Type Jacket Colors UL Type Approx. Weight IP181VT9 1 .237” 18 AWG Solid BC Gas-injected Foam FEP, .170” 95% TC Braid, 100% Foil Plenum PVC White, others by special order CMP 40 lbs/Mft RG6 HDTV/DTV Digital Coax: Plenum 20 AWG 1 .200” Solid BC IP201VT9 Gas-injected Foam FEP, .135” 95% TC Braid, 100% Foil Plenum PVC White, others by special order CMP 32 lbs/Mft RG59 HDTV/DTV Digital Coax: Plenum Electrical Specifications Nominal Attenuation (dB per 100 ft) Cond. DCR Capacitance per Mft Shield DCR per Mft Vel. of Prop. 1 3.6 10 71.5 135 270 360 720 1 1.5 MHz MHz MHz MHz MHz MHz MHz MHz GHz GHz 2.25 GHz 3 GHz Part # Impedance Return Loss (100kHz-3GHz) IP181VT9 75 6 (+/-2) >23dB, >21dB 16.0 pF/ft 6.4 6 2.8 6 84% 0.22 0.45 0.73 1.72 2.35 3.36 3.98 6.08 7.23 9.13 11.52 13.64 IP201VT9 75 6 (+/-2) >23dB, >21dB 16.0 pF/ft 10.2 6 3.5 6 84% 0.28 0.55 0.88 2.10 2.85 4.10 4.85 7.24 9.00 11.42 14.75 17.50 16 www.sheerwire.com VIDEO Prec is io n Extra - flexib le 7 5 : C o a x fo r Un c o mp res s ed HDTV Vid eo High Definition Coax: Flexible Extra-flexible Jacket 3GHz Bandwidth for HDTV Precision 756 Impedance Gas-injected Dielectric UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD 201FVT9 1 .242” Conductor Insulation (Type, OD) Shield 20 AWG Solid BC Gas-injected Foam PE, .146” 95% TC Braid, 100% Foil Jacket Type Jacket Colors UL Type Approx. Weight PVC Black, Red, Green, Blue CMX 36 lbs/Mft RG59 HDTV/DTV Digital Coax: Extra-flexible Electrical Specifications Impedance Return Loss (100kHz-3GHz) 75 6(+/-3) >17dB Capacitance Cond. DCR per Mft Shield DCR per Mft Nominal Attenuation (dB per 100 ft) Vel. 1 3.6 10 71.5 135 270 360 720 1 1.5 2.25 of Prop. MHz MHz MHz MHz MHz MHz MHz MHz GHz GHz GHz 16.3 pF/ft 10.2 6 3.5 6 83% High Definition Coax: Miniature 3 GHz 0.28 0.53 0.86 2.05 2.71 3.80 4.38 6.40 7.57 9.29 11.57 13.36 Pre c i s i o n M i n i a t u r e 7 5: C o a x fo r Un c o mp res s ed HDTV Vid eo Miniature 25 Gage Conductor 3GHz Bandwidth for HDTV Precision 756 Impedance Gas-injected Dielectric UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD 251VT9 1 .115” Conductor Insulation (Type, OD) Shield 25 AWG Solid BC Gas-injected Foam PE, .074” 95% TC Braid, 100% Foil Jacket Type Jacket Colors UL Type Approx. Weight PVC Black, Brown, Red, Orange, Yellow, Green, Blue, Violet, Gray, White CM 13 lbs/Mft Miniature 25 AWG HDTV/DTV Digital Coax Electrical Specifications Impedance Return Loss (100kHz-1GHz) (1GHz -3GHz) 75 6 (+/-3) >15dB, Capacitance Cond. DCR per Mft/Shield DCR per Mft Attenuation (dB per 100 ft) Vel. of 1 3.6 10 71.5 135 270 360 720 Prop. MHz MHz MHz MHz MHz MHz MHz MHz 1 GHz 2.25 GHz 3 GHz 17 pF/ft 31 6/8 6 81% 15.4 24.0 27.5 .50 1.23 1.80 4.30 5.65 7.72 9.00 12.9 17 www.sheerwire.com VIDEO CCTV Coax L o w - l o s s 7 5: C o a x fo r C C TV Vid eo 1GHz Bandwidth Bare Copper Conductor & Shield Precision 756 Impedance Gas-injected Dielectric UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD IR181VB9 1 .272” Conductor Insulation (Type, OD) Shield Jacket (Type, Colors) UL Type Approx. Weight 18 AWG Solid BC Gas-injected Foam PE, .180” 95% BC Braid PVC, Black or White CMR 44 lbs/Mft 20 AWG Solid BC Gas-injected Foam PE, .146” 95% BC Braid PVC, Black or White CMR 29 lbs/Mft RG6 Type CCTV Coax IR201V59 1 .242” RG59 Type CCTV Coax Electrical Specifications Nominal Attenuation (dB per 100 ft) Part # Impedance Return Loss (100kHz-1GHz), (455 MHz-1GHz) Capacitance Cond DCR per Mft/ Shield DCR per Mft Vel. of Prop 1 MHz 10 MHz 50 MHz 100 MHz 200 MHz 400 MHz 700 MHz 900 MHz 1 GHz IR181VB9 75 6 (+/-3) >17dB,>15dB 16.2 pF/ft 6.4 6/2.7 6 83% 0.19 0.64 1.48 2.15 3.09 4.51 6.12 7.00 7.40 IR201V59 75 6 (+/-3) >17dB,>15dB 16.2 pF/ft 10.2 6/2.7 6 83% 0.23 0.78 1.79 2.56 3.70 5.34 7.10 8.01 8.51 CCTV Coax: Plenum L o w - l o s s 7 5: P len u m C o a x fo r C C TV Vi de o 1GHz Bandwidth Bare Copper Conductor & Shield Precision 756 Impedance Gas-injected Dielectric UL Plenum Rated for Permanent Installation Mechanical Specifications Part # IP201V59 # of Cond. Nominal OD 1 .200” Insulation (Type, OD) Conductor Shield Jacket (Type, Colors) UL Type Approx. Weight 20 AWG Solid BC Foam FEP, .135” 95% BC Braid Plenum PVC, White CMP 30 lbs/Mft 18 AWG Solid BC Foam FEP, .170” 95% BC Braid Plenum PVC, White CMP 38 lbs/Mft RG59 CCTV Coax: Plenum IP181VB9 1 .237” RG6 CCTV Coax: Plenum Electrical Specifications Part # Impedance Return Loss (100kHz-455MHz), (455MHz-1GHz) Capacitance Cond. DCR per Mft IP201V59 75 6 (+/-3) >17dB, >15dB 16.0 pF/ft 10.2 6 75 6 (+/-3) >17dB, >15dB 16.0 pF/ft IP181VB9 6.4 6 Attenuation (dB per 100 ft) Shield DCR per Mft Vel. of Prop. 1 10 50 100 200 400 700 900 1 MHz MHz MHz MHz MHz MHz MHz MHz GHz 2.9 6 84% 0.24 0.85 2.04 2.92 4.20 6.27 8.92 10.60 11.49 2.2 6 84% 0.21 0.65 1.40 2.04 2.94 4.46 5.89 7.47 8.02 18 www.sheerwire.com VIDEO CCTV Coax with Power: Jacketed L o w - l o s s 7 5: C o a x w i t h Po w er C o n d u c to rs fo r C C TV Vid eo Overall Jacket 1GHz Bandwidth Gas-injected Dielectric 18 AWG x 2 Power Conductors UL Rated for Permanent Installation Mechanical Specifications Part # I59UPNT # of Cond. Nominal OD 1 Coax 2 Power .285” x .355” Conductor Insulation (Type, OD) 20 AWG Solid BC Gas-injected Foam PE, .146” Shield 95% BC Braid Power Pair Construction Jacket (Type, Colors) UL Type Approx. Weight (2) 18 AWG (7x26) Stranded BC, .008” PVC Insulation Black PVC Coax Jacket, White or Black Overall Jacket CM 24 lbs/Mft RG59 CCTV Coax with Power Conductors: Overall Jacket Electrical Specifications Impedance Return Loss (100kHz-1GHz), (455 MHz-1GHz) 75 6 (+/-3) >17dB,>15dB Nominal Attenuation (dB per 100 ft) Capacitance Cond DCR per Mft/ Shield DCR per Mft Vel. of Prop 1 MHz 10 MHz 50 MHz 100 MHz 200 MHz 400 MHz 700 MHz 900 MHz 1 GHz 16.2 pF/ft 10.2 6/2.7 6 83% 0.23 0.78 1.79 2.56 3.70 5.34 7.10 8.01 8.51 CCTV Coax with Power: Zip L o w - l o s s 7 5: C o a x w i t h Po w er C o n d u c to rs fo r C C TV Vid eo Dual Zip Construction 1GHz Bandwidth Gas-injected Dielectric 18 AWG x 2 Power Conductors UL Rated for Permanent Installation Mechanical Specifications Part # I59PTSI # of Cond. Nominal OD 1 Coax 2 Power .242” x .482” Conductor Insulation (Type, OD) 20 AWG Solid BC Gas-injected Foam PE, .146” Shield 95% BC Braid Power Pair Construction Jacket (Type, Colors) UL Type Approx. Weight (2) 18 AWG (7x26) Stranded BC, .008” PVC Insulation PVC, Black or White CM 26 lbs/Mft RG59 CCTV Coax with Power Conductors: Dual-zip Electrical Specifications Impedance Return Loss (100kHz-1GHz), (455 MHz-1GHz) 75 6 (+/-3) >17dB,>15dB Nominal Attenuation (dB per 100 ft) Capacitance Cond DCR per Mft/ Shield DCR per Mft Vel. of Prop 1 MHz 10 MHz 50 MHz 100 MHz 200 MHz 400 MHz 700 MHz 900 MHz 1 GHz 16.2 pF/ft 10.2 6/2.7 6 83% 0.23 0.78 1.79 2.56 3.70 5.34 7.10 8.01 8.51 19 www.sheerwire.com VIDEO Component Video: Miniature Solid M i n i a t u r e R G B S n a ke f o r C o m p o n e n t V i d e o Solid Conductors 3GHz Bandwidth Gas-injected Dielectric Double Shielded UL Rated for Permanent Installation Mechanical Specifications (Series) Conductors Insulation (Type, OD) Shield Coax Jacket (Type, OD) Master Jacket UL Type 25 AWG Solid BC Gas-injected Foam PE, .074” 95% TC Braid, 100% Foil PVC, .115” PVC, Black CMR Mechanical Specifications (Individual) Part # # of Coaxials Color Code Nominal OD Approx. Weight 253VT9 3 Red, Green, Blue .325” 68 lbs/Mft 255VT9 5 Red, Green, Blue, Yellow, White .405” 90 lbs/Mft 256VT9 6 Red, Green, Blue, Yellow, White, Black .440” 105 lbs/Mft Electrical Specifications Impedance Return Loss (100kHz-1GHz) 75 6 (+/-3) >15dB Capacitance Cond. DCR per Mft/Shield DCR per Mft Vel. of Prop. 17.0 pF/ft 31 6/8 6 81% Component Video: Miniature Plenum Attenuation (dB per 100 ft) 1 MHz 3.6 MHz 10 MHz 71.5 MHz 135 MHz 270 MHz 360 MHz 720 MHz 1 2.25 3 GHz GHz GHz .50 1.23 1.80 4.30 5.65 7.72 9.00 12.9 15.4 24.0 27.5 M i n i a t u r e R G B S n a ke f o r C o m p o n e n t V i d e o Flexible Plenum PVC Jacket 1GHz Bandwidth Gas-injected Dielectric Double Shielded UL Plenum Rated for Permanent Installation Mechanical Specifications Part # 265SVT9P # of Coaxials 5 Nominal OD .310” Conductors Insulation (Type, OD) Shield Coax Jacket (Type, OD) Coax Color Code Master Jacket 26 AWG (7x34) Stranded TC Foam FEP, .072” 100% Foil, 95% TC Spiral Serve Flouropolymer, .102” Red, Green, Blue, Yellow, White Plenum PVC, White UL Type Approx. Weight CL2P 80 lbs/Mft Electrical Specifications Impedance Return Loss (1MHz-455MHz), (455MHz-1GHz) Capacitance 75 6 (+/-3) >20dB, >15dB 16.0 pF/ft Cond. DCR per Mft/Shield DCR per Mft Vel. of Prop. 38.5 6/ 18.0 6 85% Attenuation (dB per 100 ft) 1 MHz 3.6 MHz 10 MHz 71.5 MHz 135 MHz 270 MHz 360 MHz 720 MHz 1 GHz .90 1.40 2.08 4.90 6.65 9.45 11.0 16.7 20.5 20 www.sheerwire.com VIDEO Component Video: Extra-flexible Miniature M i n i a t u r e R G B S n a ke f o r C o m p o n e n t V i d e o Extra-flexible 1GHz Bandwidth Gas-injected Dielectric Double Shielded UL Rated for Permanent Installation Mechanical Specifications (Series) Conductors Insulation (Type, OD) Shield Coax Jacket (Type, OD) Master Jacket UL Type 25 AWG (7x33) Stranded BC Gas-injected Foam PE, .099” 95% TC Braid, 100% Foil PVC, .154” Flexible TPE, Black CM Mechanical Specifications (Individual) Part # # of Coaxials Color Code Nominal OD Approx. Weight 253SVT9 3 Red, Green, Blue .440” 75 lbs/Mft 255SVT9 5 Red, Green, Blue, Yellow, White .505” 125 lbs/Mft 256SVT9 6 Red, Green, Blue, Yellow, White, Black .525” 150 lbs/Mft Electrical Specifications Impedance Return Loss (100kHz-1GHz) 75 6 (+/-3) >15dB Attenuation (dB per 100 ft) Capacitance Cond. DCR per Mft/Shield DCR per Mft Vel. of Prop. 1 MHz 3.6 MHz 10 MHz 71.5 MHz 135 MHz 270 MHz 360 MHz 720 MHz 16.5 pF/ft 30.0 6/4.8 6 82% 0.47 0.91 1.43 3.45 4.61 6.46 7.48 10.80 12.80 Component Video: Low-loss RG6 1 GHz Low-loss RG6 Component Video Cable Flexible TPE Jacket 3GHz Bandwidth Gas-injected Dielectric Double Shielded UL Rated for Permanent Installation Mechanical Specifications (Series) Conductors Insulation (Type, OD) Shield Coax Jacket (Type, OD) Master Jacket UL Type 18 AWG Solid BC Gas-injected Foam PE, .180” 95% TC Braid, 100% Foil PVC, .272” TPE, Black CM Mechanical Specifications (Individual) Part # # of Coaxials Color Code Nominal OD Approx. Weight 183VT9 3 Red, Green, Blue .735” 182 lbs/Mft 184VT9 4 Red, Green, Blue, Yellow .790” 230 lbs/Mft 185VT9 5 Red, Green, Blue, Yellow, White .845” 295 lbs/Mft Electrical Specifications Impedance Return Loss (100kHz-1GHz), (1GHz-3GHz) 75 6(+/-3) >23dB, >21dB Attenuation (dB per 100 ft) Capacitance Cond. DCR per Mft/Shield DCR per Mft Vel. of Prop. 1 3.6 10 71.5 135 270 360 720 1 1.5 2.25 3 MHz MHz MHz MHz MHz MHz MHz MHz GHz GHz GHz GHz 16.3 pF/ft 6.4 6/2.8 6 83% 0.22 0.43 0.70 1.60 2.10 2.96 3.40 4.95 5.87 7.30 9.13 10.65 21 www.sheerwire.com VIDEO Component Video with 2 Audio Pairs Hyb rid Vid eo a n d A u d io C o mp o s ite C a bl e Extra-flexible TPE Jacket 3GHz Coaxial Bandwidth 6 Coaxial Elements 2 Audio Pairs UL Rated for Permanent Installation Overall Specifications Part # 266VT9A2 # of Coaxials # of Audio Pairs Overall Jacket (Type, OD) UL Type Approx. Weight 6 2 Flexible TPE, .430” CM 85 lbs/Mft Coaxial Element Specifications Conductors (Type, DCR) Insulation (Type, OD) Shield 26 AWG Solid BC 40.5 6/Mft Gas-injected Foam PE, .074” 100% Foil 95% TC Braid Jacket (Type, OD) PVC, .114” Color Code Impedance Velocity of Propagation Red, Green, Blue, Black, Yellow, White 756 80% Audio Pair Specifications Conductors (Type, DCR) Insulation (Type, OD) 24 AWG (7x32) Stranded TC 23.8 6/Mft PE, .040” Insulation Color Code Shield Red & Black White & Black 100% Foil with 24 AWG (7x32) TC Drain Wire Component Video with 2 Audio Pairs: Plenum Jacket (Type, OD) Jacket Color Code One Red One Black PVC, .130” Hyb rid Vid eo a n d A u d io C o mp o s ite C a bl e Flexible Plenum PVC Jacket 1GHz Coaxial Bandwidth 6 Coaxial Elements 2 Audio Pairs UL Plenum Rated for Permanent Installation Overall Specifications Part # 266SVT9A2P # of Coaxials # of Audio Pairs Overall Jacket (Type, OD) UL Type Approx. Weight 6 2 Plenum PVC, .370” CL2P 68 lbs/Mft Coaxial Element Specifications Conductors (Type, DCR) Insulation (Type, OD) Shield 26 AWG (7x34) Stranded TC 38.5 6/Mft Foam FEP, .072” 100% Foil 95% TC Braid Jacket (Type, OD) Plenum PVC, .102” Color Code Impedance Velocity of Propagation Red, Green, Blue, Black, Yellow, White 756 85% Audio Pair Specifications Conductors (Type, DCR) Insulation (Type, OD) Insulation Color Code Shield Jacket (Type, OD) Jacket Color Code 22 AWG (7x30) Stranded TC 15.3 6/Mft Plenum PVC, .044” Red & Black White & Black 100% Foil with 26 AWG (7x30) TC Drain Wire Plenum PVC, .102” One Red One Black * See 265SVT9P for detailed Coaxial Electrical Specifications 22 www.sheerwire.com VIDEO Component Video with 4 Audio & 4 Power Hyb rid Vid eo , A u d io , a n d Po w er C o mp o s it e Cabl e Extra-flexible TPE Jacket 3GHz Coaxial Bandwidth 6 Coaxial Elements 4 Balanced Audio Pairs 4 Power Conductors Overall Specifications Part # 266VT9A4P4 # of Coaxials # of Audio Pairs # of Power Conductors Overall Jacket (Type, OD) UL Type Approx. Weight 6 4 4 Flexible TPE, .475” CM 125 lbs/Mft Coaxial Element Specifications Conductors (Type, DCR) Insulation (Type, OD) Shield Jacket (Type, OD) 26 AWG Solid BC, 40.5 6/Mft Gas-injected Foam PE, .074” 100% Foil 95% TC Braid PVC, .114” Audio Pair Specifications Conductors (Type, DCR) 26 AWG (7x34) Stranded TC 38.5 6/Mft Color Code Impedance Velocity of Propagation Red, Green, Blue, Black, Yellow, White 756 80% Power Conductor Specifications Insulation (Type, OD, Color) Jacket (Type, OD) Shield 100% Foil with 26 AWG (7x34) TC Drain Wire PVC, .033”, Black & Red PVC, .090” Component Video with 4 Audio & 4 Power: Plenum Jacket Color Code Conductors (Type, DCR) Insulation (Type, OD) Brown, Red, Orange, Yellow 20 AWG (7x28) Stranded TC, 10.1 6/Mft PVC, .053” Color Code Red, White, Black, Green Hyb rid Vid eo , A u d io , a n d Po w er C o mp o s it e Cabl e Flexible Plenum PVC Jacket 1GHz Bandwidth Gas-injected Dielectric Double Shielded UL Plenum Rated for Permanent Installation Overall Specifications Part # 266SVT9A4P4P # of Coaxials # of Audio Pairs # of Power Conductors Overall Jacket (Type, OD) UL Type Approx. Weight 6 4 4 Plenum PVC, .415” CL2P 105 lbs/Mft Coaxial Element Specifications Conductors (Type, DCR) Insulation (Type, OD) Shield 26 AWG (7x34) Stranded TC, 38.5 6/Mft Foam FEP, .072” 100% Foil 95% TC Serve Jacket (Type, OD) Plenum PVC, .102” Impedance Velocity of Propagation Red, Green, Blue, Black, Yellow, White 756 85% Power Conductor Specifications Audio Pair Specifications Conductors (Type, DCR) Insulation (Type, OD, Color ) Shield 26 AWG (7x34) Stranded TC, 38.5 6/Mft Plenum PVC, .033”, Black & Red 100% Foil with 26 AWG (7x34) TC Drain Wire * See 265SVT9P for detailed Coaxial Electrical Specifications www.sheerwire.com Color Code Jacket (Type, OD) Plenum PVC, .090” Jacket Color Code Conductors (Type, DCR) Insulation (Type, OD) Brown, Red, Orange, Yellow 20 AWG (7x28) Stranded TC, 10.1 6/Mft Plenum PVC, .053” Color Code Red, White, Black, Green 23 VIDEO Component Video with Category 5E E x t r a - f l ex i b l e C o m p o n e n t V i d e o w ith C a teg o ry 5 E UTP Extra-flexible TPE jacket Coaxial & Cat5E Elements 3GHz Coaxial Bandwidth 350 MHz Cat5E Bandwidth UL Rated for Permanent Installation Overall Specifications # of Coaxials # of Category 5E Elements Overall Jacket (Type, OD) UL Type Approx. Weight 256VT9C5 6 1 TPE, .535” CM 125 lbs/Mft 256VT9C52 6 2 TPE, .560” CM 138 lbs/Mft Part # Coaxial Element Specifications Conductors (Type, DCR) Insulation (Type, OD) Shield 25 AWG Solid BC, 31 6/Mft Gas-injected Foam PE, .074” 100% Foil 95% TC Braid Jacket (Type, OD) PVC, .115” Color Code Impedance Velocity of Propagation Red, Green, Blue, Black, Yellow, White 756 81% Category 5E Specifications Conductors (Type, DCR) 24 AWG Solid BC, 28.6 6/Mft Insulation Insulation Color Code PE White/Blue & Blue White/Orange & Orange White/Green & Green White/Brown & Brown Jacket (Type, OD) Bandwidth Standards PVC, .210” 350 MHz Meets or Exceeds TIA/EIA-568-B.2 Cat5e, ISO/IEC 11801 See 244CAT5E360 (page 32) for detailed electrical specifications Component Video with Category 5E: Plenum Plenum Rated Component Video w ith C a teg o ry 5 E UTP Flexible Plenum PVC Jacket 1GHz Coaxial Bandwidth 6 Coaxial Elements 1 Cat 5E Element UL Plenum Rated for Permanent Installation Overall Specifications Part # 266SVT9C5P # of Coaxials # of Category 5E Elements Overall Jacket (Type, OD) UL Type Approx. Weight 6 1 Plenum PVC, .460” CL2P 67 lbs/Mft Coaxial Element Specifications Conductors (Type, DCR) Insulation (Type, OD) 26 AWG (7x34) Stranded TC, 38.5 6/Mft Foam FEP, .072” Shield Jacket (Type, OD) Color Code Impedance Velocity of Propagation 100% Foil 95% TC Serve Plenum PVC, .102” Red, Green, Blue, Black, Yellow, White 756 85% Category 5E Specifications Conductors (Type, DCR) 24 AWG Solid BC 28.6 6/Mft Insulation Insulation Color Code Plenum Thermoplastic White/Blue & Blue White/Orange & Orange White/Green & Green White/Brown & Brown 24 Jacket (Type, OD) Bandwidth Standards Plenum PVC, .180” 350 MHz Meets or Exceeds TIA/EIA-568-B.2 Cat5e, ISO/IEC 11801 See 244CAT5E360P (page 32) for detailed electrical specifications www.sheerwire.com VIDEO SVHS Dual Miniature Coax D u a l M i n i a t u r e 7 5: C o a x fo r H i g h Res o l u t i o n S V H S A p p l i c a t i o n s Dual-zip Construction 1GHz Bandwidth Flexible PVC Jacket Low-loss Design Gas-injected Dielectric Mechanical Specifications Part # # of Cond. Nominal OD Conductor Insulation (Type, OD) Shield Jacket Type Jacket Colors Approx. Weight 252SVT9 2 .154” x .315” 25 AWG (7x33) Solid BC Gas-injected Foam PE, .099” 95% TC Braid, 100% Foil Flexible Matte PVC Black 33 lbs/Mft Dual Miniature SDI or SVHS Coax Electrical Specifications Impedance Return Loss (100kHz-1GHz) 75 6 (+/-3) >21dB Attenuation (dB per 100 ft) Capacitance Cond. DCR per Mft/Shield DCR per Mft Vel. of Prop. 1 3.6 10 71.5 135 270 360 720 MHz MHz MHz MHz MHz MHz MHz MHz 16.5 pF/ft 30.0 6/4.8 6 82% 0.47 Total Home Hybrid 0.91 1.43 3.45 1 GHz 4.61 6.46 7.48 10.80 12.80 1.5 GHz 2.25 GHz 3 GHz ---- ---- ---- Hyb rid C a b le fo r Sma rt Ho me Video and Network Distribution Cat5E Elements RG6Q Coax Elements Multi-mode Fiber (Optional) Common Outer Jacket for Easy Pulling UL Rated for Permanent Installation Mechanical Specifications Part # Cat5e Elements (#, Color) RG6Q Elements (#, Color) Muli-mode Fiber Elements (#, Color) Master Jacket (Type, Color) Overall Diameter UL Type Weight DV5E6U02 1, Gray 1, Black N/A PVC, Blue .485” CMG/CMR 89 lbs/Mft DV5E6U03 2, Gray & White 1, Black N/A PVC, Blue .575” CMG/CMR 121 lbs/Mft DV5E6U04 2, Gray & White 2, Black & White N/A PVC, Blue .660” CMG/CMR 156 lbs/Mft 2, Black & White 1, (2 Fiber Distribution), Orange PVC, Blue .670” CMG/CMR 175 lbs/Mft DV5E6U04F 2, Gray & White Cat5e ELEMENT SPECIFICATIONS, See Page #32 (pn#244CAT5E360) RG6Q ELEMENT SPECIFICATIONS, See Page #15 (pn#181CVQ6) Multi-mode Fiber ELEMENT SPECIFICATIONS, See Page #34 (pn#FMD2R) 25 www.sheerwire.com VIDEO HDMI Cable Assemblies Dig ita l Vid eo HDMI C a b le A s s emb lies fo r Un c o mp res s ed HDTV Vid e o Ultra-low Loss HDX24 Series Cable with 24 AWG Primary Conductors Pre-terminated with HDMI Male Connectors Flexible Jacket All-metal Connector Shells with Integrated Strain Relief Certified for Extended Distances - up to 48' (15m) at 1080i Specifications Part # Description Length HDX/HDMI-(length in feet) HDMI Male Connector (both ends) 8'(2.5m), 15'(5m), 25'(7.5m), 33'(10m), 48'(15m) Cable (Type, Diameter) Primary Gage Max. Distance UL Type HDX24, .390" 24 AWG HDMI certified for 1080i up to 15m VW-1 Extended Distance HDMI Digital Video Cable Note: Actual measured length is in meters. Length listed in feet is for reference only. Two cables cannot be combined to achieve a distance greater than the maximum certified length. DVI Cable Assemblies Dig ita l Vid eo DV I- D C a b le As s emb lies f o r H i g h Res o l u t i o n a n d H D T V V i d e o Ultra-low Loss HDX24 Series Cable with 24 AWG Primary Conductors Pre-terminated with DVI-D Connectors Flexible Jacket All-metal Connector Shells with Integrated Strain Relief Certified for Extended Distances - up to 48' (15m) at 1080i Specifications Part # Description Length HDX/DVI-(length in feet) DVI-D Single Link Male Connector (both ends) 8'(2.5m), 15'(5m), 25'(7.5m), 33'(10m), 48'(15m) Cable (Type, Diameter) HDX24, .390" Primary Gage Max. Distance UL Type 24 AWG Up to 15 Meters at 1920x1080 (interleaved 60Hz) VW-1 Extended Distance DVI-D Digital Video Cable Note: Actual measured length is in meters. Length listed in feet is for reference only. Two cables cannot be combined to achieve a distance greater than the maximum certified length. 26 www.sheerwire.com VIDEO HDMI to DVI Cable Assemblies Dig ita l Vid eo HDMI to DV I- D A d a p ter As s emb ly fo r Hig h Res o lu tio n a n d HDT V V i de o Ultra-low Loss HDX24 Series Cable with 24 AWG Primary Conductors Pre-terminated with HDMI and DVI-D Connectors Flexible Jacket All-metal Connector Shells with Integrated Strain Relief Certified for Extended Distances - up to 48' (15m) at 1080i Specifications Part # Description HDX/ADAP-(length in feet) DVI-D Single Link Male to HDMI Male Cable (Type, Diameter) Length 8'(2.5m), 15'(5m), 25'(7.5m), 33'(10m), 48'(15m) HDX24, .390" Primary Gage Max. Distance UL Type 24 AWG Up to 15 Meters at 1920x1080 (interleaved 60Hz) VW-1 Extended Distance HDMI to DVI Adapter Cable Note: Actual measured length is in meters. Length listed in feet is for reference only. Two cables cannot be combined to achieve a distance greater than the maximum certified length. A d a p ters fo r DV I a n d HDMI C o n n ec to rs HDMI and DVI Adapters Metal Shells (Most Types) Gender Conversion Connector Format Interfacing Tested and Certified Specifications Part # Description Shell Type Contents HDA-HF-DM HDMI Female to DVI Male Adapter Metal Gold Plated HDA-HF-HF HDMI Female to HDMI Female Adapter Plastic Gold Plated HDA-DF-DF DVI Female to DVI Female Adapter Metal Gold Plated 27 www.sheerwire.com
181CVQ60.E2.02 价格&库存
很抱歉,暂时无法提供与“181CVQ60.E2.02”相匹配的价格&库存,您可以联系我们找货
