RSF200JB-73-0R68
RSF200JB-73-0R68
    YAGEO(国巨)
    AXIAL-D5X15.5MM
    插件电阻 - 680mΩ ±5% 2W -
RSF200JB-73-0R68 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET METAL OXIDE FILM RESISTORS General Purpose, Flameproof RSF Series ±2%, ±5% 1/4W to 5W Product specification – August 16, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Metal Oxide Film Resistors Product Specification ORDERING INFORMATION Part number of the metal oxide film resistor is identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value. PART NUMBER APPLICATIONS  All general purpose applications  Power applications RSF 100 J T - 73- 100R (1) (2) (3) (4) (5) (6) (7) (1) SERIES RSF Series (2) POWER RATING -50 = 1/2W 3WS = 3W 1WS = 1W 300 = 3W FEATURES 100 = 1W 5WS = 5W  Wide resistance range 2WS = 2W 5SS = 5W 200 = 2W 500 = 5W  High stability  Flameproof coating equivalent to UL-94V-0  RoHS compliant and halogen free 3WM = 3W (3) TOLERANCE G = ±2% J = ±5% (4) PACKAGING R = Reel Pack B = Bulk T = Box Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (6) FORMING 26- = 26mm FFK = F-form Kink 52- = 52.4mm FKK = FKK Type 73- = 73mm FT = FT Type Forming 91- = 91mm MT = MT Type Forming M = M-Type Forming PN = PANAsert MB = M-form W/flat AV = AVIsert F = F Type FK = FK Type (7) RESISTANCE VALUE E24 Series Example: 1R=1Ω, 100R= 100Ω, 1K = 1,000Ω www.yageo.com Aug. 16, 2021 V.0 2 19 RSF Through Hole Resistors Metal Oxide Film Resistors Product Specification RSF DIMENSIONS Unit: mm Normal Miniature L ψD H ψd RSF-50 RSF1WS 9.0 ± 0.5 3.3 ± 0.3 26 ± 2.0 0.55 ± 0.05 RSF100 RSF2WS 11.5 ± 1.0 4.5 ± 0.5 35 ± 2.0 0.8 ± 0.05 RSF200 RSF3WS 15.5 ± 1.0 5.0 ± 0.5 33 ± 2.0 0.8 ± 0.05 RSF3WM RSF5SS 17.5 ± 1.0 6.5±1.0 32 ± 2.0 0.8 ± 0.05 RSF300 RSF5WS 24.5 ± 1.0 8.5 ± 1.0 38 ± 2.0 0.8 ± 0.05 RSF500 - 24.5 ± 1.0 8.5 ± 1.0 38 ± 2.0 0.8 ± 0.05 155 235 DERATING CURVE Rated Power (%) 100 80 60 48 40 20 70 Ambient Temperature (°C) www.yageo.com Aug. 16, 2021 V.0 3 19 Through Hole Resistors Metal Oxide Film Resistors Product Specification RSF ELECTRICAL CHARACTERISTICS CHARACTERISTICS RSF-50 RSF100 RSF200 RSF3WM RSF300 RSF500 Power Rating at 70 °C 1/2W 1W 2W 3W 3W 5W Maximum working voltage 250V 350V 350V 450V 500V 750V Maximum overload voltage 400V 600V 600V 700V 800V 1000V Voltage Proof on Insulation 350V 500V 500V 500V 500V 500V Resistance Range 1Ω – 1MΩ for E24 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. Below 10Ω and over 100K(excluded) are using alloy film. CHARACTERISTICS RSF1WS RSF2WS RSF3WS RSF5SS RSF5WS Power Rating at 70 °C 1W 2W 3W 5W 5W Maximum working voltage 300V 350V 350V 500V 700V Maximum overload voltage 500V 600V 600V 800V 900V Voltage Proof on Insulation 400V 500V 500V 500V 500V Resistance Range 1Ω – 1MΩ for E24 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. Below 10Ω and over 100K(excluded) are using alloy film. www.yageo.com Aug. 16, 2021 V.0 4 19 Through Hole Resistors Metal Oxide Film Resistors Product Specification RSF TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE APPRAISE 2.5 times RCWV for 5 sec. ±1%+0.05Ω for normal style (Not more than maximum overload ±2%+0.05Ω for miniature style voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings Marking and markings Robustness of IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction ≥2.5Kg(24.5N) of the terminal leads IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. ±2.0%+0.05Ω on,25 Sec. off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, ±5.0%+0.05Ω loaded with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., ±5.0%+0.05Ω whichever less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±1.0%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to ±1.0 %+0.05Ω a point 3±0.5mm from the body Accidental Overload IEC 60115-1 4.26 4 times RCWV for 1 Min. Test No evidence of flaming or arcing Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Aug. 16, 2021 V.0 5 19 Through Hole Resistors Metal Oxide Film Resistors Product Specification RSF PULSE DIAGRAMS RSF1WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time RSF100 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration www.yageo.com Aug. 16, 2021 V.0 6 19 Through Hole Resistors Metal Oxide Film Resistors Product Specification RSF RSF2WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time RSF200 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration www.yageo.com Aug. 16, 2021 V.0 7 19 Through Hole Resistors Metal Oxide Film Resistors Product Specification RSF RSF3WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 16, 2021 V.0 8 19 Through Hole Resistors Metal Oxide Film Resistors Product Specification RSF AXIAL / REEL TAPE SPECIFICATION Unit: mm Normal Miniature a A B1-B2 (Max.) S (spacing) RSF-50 RSF1WS 6 ± 0.5 52.4 ± 1.5 1.2 5 73.0 ± 1.5 1.5 RSF100 RSF2WS 6 ± 0.5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 RSF200 RSF3WS T (max. deviation of spacing) 5 6 ± 0.5 10 RSF3WM RSF5SS 6 ± 0.5 73.0 ± 1.5 1.5 10 RSF300 RSF5WS 6 ± 0.5 91.0 ± 1.5 1.5 10 RSF500 - 6 ± 0.5 91.0 ± 1.5 1.5 10 1 mm per 10 spacing, 0.5 mm per 5 spacing www.yageo.com Aug. 16, 2021 V.0 9 19 Through Hole Resistors Metal Oxide Film Resistors Product Specification 19 RSF TAPE ON REEL PACKING TYPE Unit: mm/piece Normal Miniature Across Flange(A) B Quantity Per Reel RSF-50 RSF1WS 66.5 75.5 2,500 RSF100 RSF2WS 87 96 2,000 RSF200 RSF3WS 87 96 1,000 RSF3WM RSF5SS 87 96 1,000 www.yageo.com Aug. 16, 2021 V.0 10 Through Hole Resistors Metal Oxide Film Resistors Product Specification 19 RSF TAPE ON BOX PACKING TYPE DIMENSIONS Unit: mm/piece Normal Miniature A B C Quantity Per Box RSF-50 RSF1WS 73 45 258 1,000 RSF100 RSF2WS 81 91 260 1,000 RSF100 RSF2WS 103 78 260 1,000 RSF200 RSF3WS 81 91 260 1,000 RSF200 RSF3WS 103 94 260 1,000 RSF3WM RSF5SS 103 78 260 500 RSF300 RSF5WS 116 79 255 250 RSF500 - 116 79 255 250 BULK PACKING Normal Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag RSF-50 RSF1WS 5,000 5 1,000 RSF100 RSF2WS 2,000 4 500 RSF200 RSF3WS 1,000 2 500 RSF3WM RSF5SS 1,000 2 500 RSF300 RSF5WS 500 10 50 RSF500 - 500 10 50 www.yageo.com Aug. 16, 2021 V.0 11 Through Hole Resistors Metal Oxide Film Resistors Product Specification 19 RSF FORMING M TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd P H RSF-50 RSF1WS 9.0 ± 0.5 3.3± 0.3 0.55 ± 0.05 12.5 ± 1 10.0 ± 1 RSF100 RSF2WS 11.5 ± 1.0 4.5 ± 0.5 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 RSF200 RSF3WS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 RSF3WM RSF5SS 17.5 ± 1.0 6.5 ± 1.0 0.8 ± 0.05 25.0 ± 1 15.0 ± 1 RSF300 RSF5WS 24.5 ± 1.0 8.5 ± 1.0 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 www.yageo.com Aug. 16, 2021 V.0 12 Through Hole Resistors Metal Oxide Film Resistors Product Specification 19 RSF MB TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd P H1 H2 t RSF-50 - 9.0 ± 0.5 3.3± 0.3 0.55 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 - RSF1WS 9.0 ± 0.5 3.3± 0.3 0.8 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 RSF100 RSF2WS 11.5 ± 1.0 4.5 ± 0.5 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 RSF200 RSF3WS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 RSF3WM RSF5SS 17.5 ± 1.0 6.5 ± 1.0 0.8 ± 0.05 25.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 RSF300 RSF5WS 24.5 ± 1.0 8.5 ± 1.0 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 RSF500 - 24.5 ± 1.0 8.5 ± 1.0 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 www.yageo.com Aug. 16, 2021 V.0 13 Through Hole Resistors Product Specification Metal Oxide Film Resistors 14 19 RSF MHA TYPE TYPE DIMENSIONS Normal Miniature RSF-50 RSF1WS Unit: mm L ψD ψd B H0 HI P P0 9.0±0.5 3.3±0.3 0.55±0.05 17.5Max 19.0±1.0 4.0±1.0 30.0±1.0 15.0±0.3 P1 P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.5 7.5±0.5 18.0±0.5 5.0Min 9.0±0.5 4.0±0.2 MHB TYPE TYPE Normal DIMENSIONS Miniature L 15.5±1.0 RSF200 RSF3WS P 30.0±1.0 Unit: mm ψD ψd B 5.0±0.5 0.8±0.05 P0 15.0±0.3 H H0 HI H2 H3 21.0Max. 30Max. 18.0±1.0 5.5(Ref.) 8.0±1.5 16Max. PI P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.8 7.5±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.3 www.yageo.com Aug. 16, 2021 V.0 Through Hole Resistors Product Specification Metal Oxide Film Resistors 19 RSF MHC TYPE TYPE DIMENSIONS Normal Miniature L RSF200 RSF3WS Unit: mm ψD ψd B H HI P P0 15.5±1.0 5.0±0.5 0.8±0.05 21.0Max. 19.0±1.0 5.25±1.0 30.0±1.0 15.0±0.3 F W W0 W1 ΨD0 10.0±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.2 F TYPE FK TYPE TYPE FFK TYPE FKK TYPE DIMENSIONS Unit: mm H HI E Max. Max. 5±1 18.5 3.5 3.5±1 24 5±1 20 3.5 3.5±1 28 5± 1 25 3.5 3.5±1 Normal Miniature L ψD ψd P h RSF-50 RSF1WS 9.0±0.5 3.3±0.3 0.55±0.05 6±1 8±1 22 RSF100 RSF2WS 11.5±1 4.5±0.5 0.8±0.05 6±1 8±1 RSF200 RSF3WS 15.5±1 5.0±0.5 0.8±0.05 8±1 8±1 Max. hl e www.yageo.com Aug. 16, 2021 V.0 15 Through Hole Resistors Metal Oxide Film Resistors Product Specification 19 RSF PN TYPE (Taping Pack) AV TYPE (Taping Pack) TYPE DIMENSIONS Unit: mm TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. Normal Miniature H1 Max. H2 Max. H3 Max. RSF-50 RSF1WS 17 25.5 8.5 RSF-50 RSF1WS 14.5 23 8.5 RSF100 RSF2WS 19 27.5 8.5 RSF100 RSF2WS 17.5 26 8.5 FT TYPE (Taping Pack) TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. RSF-50 RSF1WS 13 21.5 8.5 RSF100 RSF2WS 16 24.5 8.5 www.yageo.com Aug. 16, 2021 V.0 16 Through Hole Resistors Product Specification Metal Oxide Film Resistors 19 RSF MARKING 4-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω TOLERANCE ± 2% ( G ) ±5%(J) www.yageo.com Aug. 16, 2021 V.0 17 Through Hole Resistors Metal Oxide Film Resistors Product Specification 19 RSF REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version 0 Aug.16 , 2021 - DESCRIPTION - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 16, 2021 V.0 18 Through Hole Resistors Metal Oxide Film Resistors Product Specification 19 RSF LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 16, 2021 V.0 19
RSF200JB-73-0R68 AI解析
物料型号:RSF系列,包括不同的功率等级如RSF-50、RSF100、RSF200、RSF3WM、RSF300和RSF500。
器件简介:这是一系列通用金属氧化物膜电阻器,具有±2%和±5%的容差,功率范围从1/4W到5W,符合RoHS标准且无卤素。
引脚分配:文档中没有提供具体的引脚分配信息,通常这类电阻器为直插式,两端引脚用于连接。
参数特性: - 宽电阻范围 - 高稳定性 - 阻燃涂层符合UL-94V-0标准 - 符合RoHS标准和无卤素 - 电阻的温度系数为±300ppm/°C - 工作温度范围为-55°C至+155°C
功能详解:文档中没有提供具体的功能详解,但通常这类电阻器用于限制电流、分压、负载均衡等。
应用信息:适用于所有通用目的的应用和电源应用。
封装信息:提供了不同尺寸的电阻器的详细尺寸信息,包括外径(OD)、高度(H)、带宽度(wd)等。
*介绍内容由AI识别生成
RSF200JB-73-0R68 价格&库存
很抱歉,暂时无法提供与“RSF200JB-73-0R68”相匹配的价格&库存,您可以联系我们找货
