CFR-25JB-52-1M
CFR-25JB-52-1M
    YAGEO(国巨)
    插件,D2.4xL6.3mm
    插件电阻 - 1MΩ ±5% 1/4W -1500ppm/℃
CFR-25JB-52-1M 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET CARBON FILM RESISTORS General Purpose CFR Series ±2%, ±5% 1/6W to 3W Product specification – August 13, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Carbon Film Resistors Product Specification ORDERING INFORMATION Part number of the general purpose carbon film resistor are identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value. PART NUMBER APPLICATIONS  All general purpose applications  Power applications CFR 200 J T - 73- 100R (1) (2) (3) (4) (5) (6) (7) (1) SERIES NAME CFR Series (2) POWER RATING -12 = 1/6W -50 = 1/2W 200 = 2W 25S = 1/4W 100 = 1W 3WS = 3W FEATURES -25 = 1/4W 2WS = 2W 1WS = 1W  AEC-Q200 qualified 50S = 1/2W  Wide resistance range (3) TOLERANCE  High stability  PPAP ready (CFR-25/CFR50S)  RoHS compliant & halogen-free G = ±2% J = ±5% (4) PACKAGING R = Reel Pack B = Bulk T = Box Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec , please refer to page 4 Table 2 . (6) FORMING 26- = 26mm 52- = 52.4mm M = M-Type Forming MT = MT Type Forming 73- = 73mm MB = M-form W/flat FT = FT Type Forming 73G = 73mm, Φd≧0.6mm 26A = 26mm, Φd=0.4±0.02mm 26C = 26mm, Φd=0.5±0.02mm 26G = 26mm, Φd≧0.6mm 52A = 52.4mm, Φd=0.4±0.02mm 52B = 52.4mm, Φd=0.45±0.02mm F = F Type FK = FK Type FFK = F-form Kink FKK = FKK Type PN = PANAsert AV = AVIsert 52C = 52.4mm, Φd=0.5±0.02mm 52G = 52.4mm, Φd≧0.6mm 52H = 52.4mm, non-painting on welding spot (7) RESISTANCE VALUE E24 Series Example: 100R = 100Ω, 10K = 10,000Ω, 1M = 1,000,000Ω www.yageo.com Aug. 13, 2021 V.0 2 16 CFR Through Hole Resistors Product Specification Carbon Film Resistors CFR DIMENSIONS Unit: mm Normal Miniature L ψD H ψd CFR-12 CFR 25S 3.4 ± 0.3 1.9 ± 0.2 28 ± 2.0 0.45 ± 0.05 CFR -25 CFR 50S 6.3 ± 0.5 2.4 ± 0.2 28 ± 2.0 0.55 ± 0.05 CFR -50 CFR 1WS 9.0 ± 0.5 3.3 ± 0.3 26 ± 2.0 0.55 ± 0.05 CFR 100 CFR 2WS 11.5 ± 1.0 4.5 ± 0.5 35 ± 2.0 0.8 ± 0.05 CFR 200 CFR 3WS 15.5 ± 1.0 5.0 ± 0.5 33 ± 2.0 0.8 ± 0.05 DERATING CURVE Rated Power (%) 100 80 60 40 20 20 40 70 100 155 Ambient Temperature (°C) ELECTRICAL CHARACTERISTICS TABLE 1 CHARACTERISTICS CFR -12 CFR 25S CFR -25 CFR 50S CFR -50 CFR 1WS CFR 100 CFR 2WS CFR 200 CFR 3WS Power Rating at 70 °C 1/6W 1/4W 1/4W 1/2W 1/2W 1W 1W 2W 2W 3W Maximum Working Voltage 150V 200V 250V 300V 350V 400V 500V 500V 500V 500V Maximum Overload Voltage 300V 400V 500V 600V 700V 800V 1000V 1000V 1000V 1000V Voltage Proof on Insulation 300V 400V 500V 500V 500V 700V 1000V 1000V 1000V 1000V Resistance Range 1Ω ~ 10MΩ for E24 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient see Table 2 Note: For resistance value out of above range is by request. www.yageo.com Aug. 13, 2021 V.0 3 16 Through Hole Resistors Carbon Film Resistors Product Specification CFR TABLE 2 TEMPERATURE COEFFICIENT Temp. Coefficient ppm/°C TYPE CFR100, CFR200, CFR2WS CFR3WS CFR-12 , CFR-25 , CFR-50 CFR25S , CFR50S , CFR1WS Under 100KΩ 100K ~ 1MΩ 1M ~ 10MΩ ± 350 -500~0 -1500~0 -700~0 -1500~0 - 500 ~ +350 TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE APPRAISE 2.5 times RCWV for 5 sec.(Not more than ±0.75%+0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.39 4 times RCWV(or Umax., whichever less) ±1.0%+0.05Ω 10,000 cycles (1 Sec. on, 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±3.0%+0.05Ω with 0.1 times RCWV (or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±3.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C ±1.0%+0.05Ω  Room Temp.(5 cycles) Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body www.yageo.com Aug. 13, 2021 V.0 4 16 Through Hole Resistors Carbon Film Resistors Product Specification CFR Note:. RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) PULSE DIAGRAMS CFR-25~3WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 13, 2021 V.0 5 16 Through Hole Resistors Carbon Film Resistors Product Specification CFR AXIAL / REEL TAPE SPECIFICATION Unit: mm Normal Miniature a CFR-12 CFR25S 6 ± 0.5 CFR-25 CFR50S CFR1WS 6 ± 0.5 CFR100 CFR2WS 6 ± 0.5 CFR200 CFR3WS A B1-B2 (Max.) 52.4 ± 1.5 1.2 26.0 ± 1.5 1.0 52.4 ± 1.5 1.2 26.0 ± 1.5 1.0 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 S (spacing) T (max. deviation of spacing) 5 6 ± 0.5 CFR-50 5 5 1 mm per 10 spacing, 0.5 mm per 5 spacing 5 6 ± 0.5 10 www.yageo.com Aug. 13, 2021 V.0 6 16 Through Hole Resistors Carbon Film Resistors Product Specification CFR TAPE ON REEL PACKING TYPE Unit: mm/piece Normal Miniature Across Flange(A) B Quantity Per Reel CFR-12 CFR25S 66.5 75.5 5,000 CFR-25 CFR50S 66.5 75.5 5,000 CFR-50 CFR1WS 66.5 75.5 2,500 CFR100 CFR2WS 87 96 2,000 CFR200 CFR3WS 87 96 1,000 www.yageo.com Aug. 13, 2021 V.0 7 16 Through Hole Resistors Carbon Film Resistors Product Specification CFR TAPE ON BOX PACKING TYPE Unit: mm/piece DIMENSIONS Normal Miniature A B C Quantity Per Box CFR-12 CFR25S 48 102 255 5,000 CFR-12 CFR25S 81 70 260 5,000 CFR-25 CFR50S 48 102 255 5,000 CFR-25 CFR50S 81 104 260 5,000 CFR-50 CFR1WS 73 45 258 1,000 CFR100 CFR2WS 81 91 260 1,000 CFR100 CFR2WS 103 78 260 1,000 CFR200 CFR3WS 81 91 260 1,000 CFR200 CFR3WS 103 94 260 1,000 BULK PACKING Normal Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag CFR-12 CFR25S 10,000 10 1,000 CFR-25 CFR50S 10,000 10 1,000 CFR-50 CFR1WS 5,000 5 1,000 CFR-100 CFR2WS 2,000 4 500 CFR200 CFR3WS 1,000 2 500 www.yageo.com Aug. 13, 2021 V.0 8 16 Through Hole Resistors Carbon Film Resistors Product Specification CFR FORMING M TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd CFR-12 CFR25S 3.4± 0.3 1.9 ± 0.2 0.45 ± 0.05 6.0 ± 1 10.0 ±1 CFR-25 CFR50S 6.3 ± 0.5 2.4 ± 0.2 0.55 ± 0.05 10.0 ± 1 10.0 ± 1 CFR-50 CFR1WS 9.0 ± 0.5 3.3± 0.3 0.55 ± 0.05 12.5 ± 1 10.0 ± 1 CFR100 CFR2WS 11.5 ± 1.0 4.5 ± 0.5 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 CFR200 CFR3WS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 P H MB TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd P H1 H2 t CFR-25 CFR50S 6.3 ± 0.5 2.4 ± 0.2 0.55 ± 0.05 10.0 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 CFR-50 - 9.0 ± 0.5 3.3± 0.3 0.55 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 - CFR1WS 9.0 ± 0.5 3.3± 0.3 0.8 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 CFR100 CFR2WS 11.5 ± 1.0 4.5± 0.5 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 CFR200 CFR3WS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 www.yageo.com Aug. 13, 2021 V.0 9 16 Through Hole Resistors Product Specification Carbon Film Resistors 10 16 CFR MHA TYPE TYPE Normal CFR-50 DIMENSIONS Miniature CFR1WS Unit: mm L ψD ψd B H0 HI P P0 9.0±0.5 3.3±0.3 0.55±0.05 17.5Max 19.0±1.0 4.0±1.0 30.0±1.0 15.0±0.3 P1 P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.5 7.5±0.5 18.0±0.5 5.0Min 9.0±0.5 4.0±0.2 www.yageo.com Aug. 13, 2021 V.0 Through Hole Resistors Product Specification Carbon Film Resistors 16 CFR MHB TYPE TYPE Normal DIMENSIONS Miniature L 15.5±1.0 CFR200 CFR3WS P 30.0±1.0 Unit: mm ψD ψd B 5.0±0.5 0.8±0.05 P0 15.0±0.3 H H0 HI H2 H3 21.0Max. 30Max. 18.0±1.0 5.5(Ref.) 8.0±1.5 16Max. PI P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.8 7.5±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.3 MHC TYPE TYPE Normal CFR200 DIMENSIONS Miniature L CFR3WS Unit: mm ψD ψd B H HI P P0 15.5±1.0 5.0±0.5 0.8±0.05 21.0Max. 19.0±1.0 5.25±1.0 30.0±1.0 15.0±0.3 F W W0 W1 ΨD0 10.0±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.2 www.yageo.com Aug. 13, 2021 V.0 11 Through Hole Resistors Carbon Film Resistors F TYPE Product Specification 16 CFR FK TYPE TYPE FFK TYPE FKK TYPE DIMENSIONS Unit: mm H HI E Max. Max. 5±1 18.5 3.5 3.5±1 24 5±1 20 3.5 3.5±1 28 5± 1 25 3.5 3.5±1 Normal Miniature L ψD ψd P h CFR-50 CFR1WS 9.0±0.5 3.3±0.3 0.55±0.05 6±1 8±1 22 CFR100 CFR2WS 11.5±1 4.5±0.5 0.8±0.05 6±1 8±1 CFR200 CFR3WS 15.5±1 5.0±0.5 0.8±0.05 8±1 8±1 Max. hl e www.yageo.com Aug. 13, 2021 V.0 12 Through Hole Resistors Carbon Film Resistors Product Specification 16 CFR FT TYPE (Taping Pack) MT TYPE (Taping Pack) Rated Watts : 1/6W,1/4WS TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. CFR-25 CFR50S 10 18.5 8.5 CFR-50 CFR1WS 13 21.5 8.5 CFR100 CFR2WS 16 24.5 8.5 PN TYPE (Taping Pack) AV TYPE (Taping Pack) TYPE DIMENSIONS Unit: mm TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. Normal Miniature H1 Max. H2 Max. H3 Max. CFR-25 CFR50S 13 21.5 8.5 CFR-25 CFR50S 11.5 20 8.5 CFR-50 CFR1WS 17 25.5 8.5 CFR-50 CFR1WS 14.5 23 8.5 CFR100 CFR2WS 19 27.5 8.5 CFR100 CFR2WS 17.5 26 8.5 www.yageo.com Aug. 13, 2021 V.0 13 Through Hole Resistors Product Specification Carbon Film Resistors 16 CFR MARKING 4-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω TOLERANCE ± 2% (G) ±5% (J) www.yageo.com Aug. 13, 2021 V.0 14 Through Hole Resistors Carbon Film Resistors Product Specification 16 CFR REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 13, 2021 V.0 15 Through Hole Resistors Carbon Film Resistors Product Specification 16 CFR LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 13, 2021 V.0 16
CFR-25JB-52-1M
物料型号:CFR系列,包括不同的封装尺寸和功率等级,如CFR-12、CFR-25、CFR-50、CFR100、CFR200和CFR3WS等。
器件简介:CFR系列是一般用途的碳膜电阻器,适用于所有通用应用和功率应用。
引脚分配:文档中未明确提及引脚分配,但通常这类电阻器为轴向引脚。
参数特性: - 公差:±2%(G)和±5%(J)。 - 功率等级:从1/6W到3W不等。 - 包装:卷装(R)、盒装(T)和散装(B)。 - 温度系数:基于规格,请参考第4页表格2。 - 成型:提供多种成型尺寸和直径选项。
功能详解: - AEC-Q200认证。 - 宽电阻范围。 - 高稳定性。 - PPAP准备(CFR-25/CFR50S)。 - 符合RoHS标准和无卤素。
应用信息:适用于一般用途和功率应用。
封装信息:提供详细的尺寸信息,包括正常和微型尺寸,以及不同封装类型的尺寸数据。
CFR-25JB-52-1M 价格&库存
很抱歉,暂时无法提供与“CFR-25JB-52-1M”相匹配的价格&库存,您可以联系我们找货
CFR-25JB-52-1M
    CFR-25JB-52-1M
    • 1+0.878651+0.11030
    • 10+0.2974710+0.03734
    • 25+0.2485625+0.03121
    • 50+0.2153250+0.02703
    • 100+0.18992100+0.02384
    • 250+0.16036250+0.02013
    • 500+0.14234500+0.01787
    • 1000+0.126761000+0.01592
    • 5000+0.099035000+0.01243
    库存:36284
    CFR-25JB-52-1M
      库存:903
      CFR-25JB-52-1M
        • 14000+0.06530
        库存:20000
