無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。
DATA SHEET
WIREWOUND RESISTORS
High Power
PNP Series
±1%, ±5%
1W to 4W
Product specification – August 16, 2021 V.0
RoHS compliant & Halogen Free
Through Hole Resistors
Wirewound Resistors
Product Specification
ORDERING INFORMATION
Part number of the high power wirewound resistor are identified by the
series, power rating, tolerance, packing, temperature coefficient, forming
and resistance value.
PART NUMBER
APPLICATIONS
Power applications
PNP
200
F
T
F
73-
10R
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(1) SERIES
PNP Series
Home appliance
Industry
(2) POWER RATING
100 = 1W
300 = 3W
200 = 2W
400 = 4W
FEATURES
Ultra miniature size
Wide resistance range
Stable performance and high
reliability
Flameproof coating equivalent
to UL-94V-0
RoHS compliant & halogen
free
(3) TOLERANCE
F = ±1%
J = ±5%
(4) PACKAGING TYPE
R = Reel Pack
B= Bulk
T= Box Pack
(5) TEMPERATURE COEFFICIENT OF RESISTANCE
F=±100ppm/°C
- = Based on spec.
(6) FORMING
52- = 52.4mm
FFK = F-form Kink
73- = 73mm
FKK = FKK Type
M = M-Type Forming
FT = FT Type Forming
MB = M-form W/flat
PN = PANAsert
F = F Type
AV = AVIsert
FK = FK Type
(7) RESISTANCE VALUE
E24 & E96 Series
Example:
1R = 10Ω, 10R = 10Ω, 100R = 100Ω
www.yageo.com
Aug. 16, 2021
V.0
2
17
PNP
Wirewound Resistors
PNP
DIMENSIONS
Unit: mm
Ultra
Miniature
L
ψD
H
ψd
PNP100
6.3 ± 0.5
2.5 ± 0.3
28 ± 2.0
0.55 ± 0.05
PNP200
9.0 ± 0.5
3.5 ± 0.3
26 ± 2.0
0.55 ± 0.05
PNP300
11.5 ± 1.0
4.6 ± 0.5
35 ± 2.0
0.8 ± 0.05
PNP400
15.5 ± 1.0
5.2 ± 0.5
33 ± 2.0
0.8 ± 0.05
DERATING CURVE
Rated Power (%)
100
80
60
40
36
200
275
Ambient Temperature (°C)
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS
PNP100
PNP200
PNP300
PNP400
Power Rating at 70 °C
1W
2W
3W
4W
Resistance Range (±1%)
0.22Ω~130Ω
0.1Ω~820Ω
0.1Ω~2.2KΩ
0.1Ω~2.8KΩ
Resistance Range (±5%)
0.1Ω~130Ω
0.1Ω~820Ω
0.1Ω~2.2KΩ
0.1Ω~2.8KΩ
Voltage Proof on Insulation
300V
Maximum working voltage
√(P X R)
Operating Temp. Range
- 40°C to +200°C
Temperature Coefficient
±100ppm/°C , ±100ppm/°C
Note: For resistance value out of above range is by request.
www.yageo.com
Aug. 16, 2021
V.0
3
17
Wirewound Resistors
PNP
TEST AND REQUIRMENTS
TEST
TEST METHOD
Short Time Overload
IEC 60115-1 4.13
10 times rated power for 5 Sec.
±2%+0.05Ω
Voltage Proof on
IEC 60115-1 4.7
In V-Block for 60 sec. test voltage as
No Breakdown
Insulation
PROCEDURE
APPRAISE
above table
IEC 60115-1 4.8
Between -40°C to +155°C
By Type
Insulation Resistance
IEC 60115-1 4.6
>100MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
Marking
coatings and markings
Robustness of
IEC 60115-1 4.16
Terminations
Damp Heat Steady State
Direct load for 10 Sec. in the direction of
≥2.5Kg(24.5N)
the terminal leads
IEC 60115-1 4.24
40±2°C,90-95% RH for 56 days, loaded
±5.0%+0.05Ω
with 0.1 times RCWV(or Umax.,
whichever less)
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV(or Umax., whichever
±5.0%+0.05Ω
less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off)
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp.
±1.0%+0.05Ω
+200°C Room Temp.(5 cycles)
Resistance to Soldering
IEC 60115-1 4.18
Heat
260±3°C for 10±1 Sec., immersed to a
±1.0%+0.05Ω
point 3±0.5mm from the body
Accidental Overload Test
IEC 60115-1 4.26
4 times RCWV for 1 Min.
No evidence of flaming
or arcing
Note:.
RCWV (Rated Continuous Working Voltage ):
The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following
formula:
V=√(P X R)
or max. working voltage whichever is less
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω)
www.yageo.com
Aug. 16, 2021
V.0
4
17
Wirewound Resistors
PNP
PULSE DIAGRAMS
PNP100 Series: Pmax.: Maximum permissible peak pulse power
ti: Pulse duration
tp: Pulse repetition time
PNP200 Series: Pmax.: Maximum permissible peak pulse power
ti: Pulse duration
www.yageo.com
Aug. 16, 2021
V.0
5
17
Wirewound Resistors
PNP
PNP300 Series: Pmax.: Maximum permissible peak pulse power
ti: Pulse duration
PNP400 Series: Pmax.: Maximum permissible peak pulse power
ti: Pulse duration
www.yageo.com
Aug. 16, 2021
V.0
6
17
Wirewound Resistors
PNP
AXIAL / REEL TAPE SPECIFICATION
Unit: mm
Ultra Miniature a
A
B1-B2 (Max.)
S (spacing)
PNP100
6 ± 0.5
52.4 ± 1.5
1.2
5
PNP200
6 ± 0.5
52.4 ± 1.5
1.2
5
PNP300
6 ± 0.5
73.0 ± 1.5
1.5
52.4 ± 1.5
1.2
73.0 ± 1.5
1.5
52.4 ± 1.5
1.2
PNP400
6 ± 0.5
5
T (max. deviation of spacing)
1 mm per 10 spacing,
0.5 mm per 5 spacing
10
www.yageo.com
Aug. 16, 2021
V.0
7
17
Wirewound Resistors
PNP
TAPE ON REEL PACKING
TYPE
Unit: mm/piece
Ultra Miniature
Across Flange(A)
B
Quantity Per Reel
PNP100
66.5
75.5
5,000
PNP200
66.5
75.5
2,500
PNP300
87
96
2,000
PNP400
87
96
1,000
www.yageo.com
Aug. 16, 2021
V.0
8
17
Wirewound Resistors
PNP
TAPE ON BOX PACKING
TYPE
DIMENSIONS
Ultra Miniature
A
B
C
Quantity Per Box
PNP100
81
104
260
5,000
PNP200
73
45
258
1,000
PNP300
81
91
260
1,000
PNP300
103
78
260
1,000
PNP400
81
91
260
1,000
PNP400
103
94
260
1,000
Unit: mm/piece
BULK PACKING
Ultra Miniature
Piece/Per Inner Box
Bag/Per Inner Box
Piece Per Bag
PNP100
10,000
10
1,000
PNP200
5,000
5
1,000
PNP300
2,000
4
500
PNP400
1,000
2
500
www.yageo.com
Aug. 16, 2021
V.0
9
17
Wirewound Resistors
17
PNP
FORMING
M TYPE
TYPE
DIMENSIONS
Ultra Miniature
L
ψD
ψd
P
H
PNP100
6.3 ± 0.5
2.5 ± 0.3
0.55 ± 0.05
10.0 ± 1
10.0 ± 1
PNP200
9.0 ± 0.5
3.5± 0.3
0.55 ± 0.05
12.5 ± 1
10.0 ± 1
PNP300
11.5 ± 1.0
4.6± 0.5
0.8 ± 0.05
15.0 ± 1
12.5 ± 1
PNP400
15.5 ± 1.0
5.2 ± 0.5
0.8 ± 0.05
20.0 ± 1
15.0 ± 1
Unit: mm
MB TYPE
TYPE
DIMENSIONS
Ultra
Miniature
L
ψD
ψd
P
H1
H2
t
PNP100
6.3 ± 0.5
2.5± 0.3
0.55 ± 0.05
10.0 ± 1
6.0 ± 1
5.0 ± 1
1.2 ± 0.2
PNP200
9.0 ± 0.5
3.5± 0.3
0.8 ± 0.05
12.5 ± 1
6.0 ± 1
5.0 ± 1
1.4 ± 0.2
PNP300
11.5 ± 1.0
4.6 ± 0.5
0.8 ± 0.05
15.0 ± 1
6.0 ± 1
5.0 ± 1
1.4 ± 0.2
PNP400
15.5 ± 1.0
5.2 ± 0.5
0.8 ± 0.05
20.0 ± 1
10.0 ± 1
5.0 ± 1
1.4 ± 0.2
Unit: mm
www.yageo.com
Aug. 16, 2021
V.0
10
Wirewound Resistors
17
PNP
MHA TYPE
TYPE
DIMENSIONS
Miniature
L
ψD
ψd
B
H0
HI
P
P0
9.0±0.5
3.5±0.3
0.55±0.05
17.5Max
19.0±1.0
4.0±1.0
30.0±1.0
15.0±0.3
P1
P2
F
W
W0
W1
ΨD0
7.5±1.0
3.75±0.5
7.5±0.5
18.0±0.5
5.0Min
9.0±0.5
4.0±0.2
PNP200
Unit: mm
www.yageo.com
Aug. 16, 2021
V.0
11
Wirewound Resistors
17
PNP
MHB TYPE
TYPE
DIMENSIONS
Miniature L
PNP400
Unit: mm
ψD
ψd
B
15.5±1.0
5.2±0.5
0.8±0.05
P
P0
30.0±1.0
15.0±0.3
H
H0
HI
H2
H3
21.0Max. 30Max.
18.0±1.0
5.5(Ref.)
8.0±1.5
16Max.
PI
P2
F
W
W0
W1
ΨD0
7.5±1.0
3.75±0.8
7.5±0.5
18.0±0.5
5.0Min.
9.0±0.5
4.0±0.3
MHC TYPE
TYPE
DIMENSIONS
Miniature
L
ψD
ψd
B
H
HI
P
P0
15.5±1.0
5.2±0.5
0.8±0.05
21.0Max.
19.0±1.0
5.25±1.0
30.0±1.0
15.0±0.3
F
W
W0
W1
ΨD0
10.0±0.5
18.0±0.5
5.0Min.
9.0±0.5
4.0±0.2
PNP400
Unit: mm
www.yageo.com
Aug. 16, 2021
V.0
12
Wirewound Resistors
F TYPE
17
PNP
FK TYPE
FFK TYPE
TYPE
DIMENSIONS
Ultra
Miniature
L
ψD
ψd
P
h
PNP200
9.0±0.5
3.5±0.3
0.55±0.05
6±1
8±1
22
PNP300
11.5±1
4.6±0.5
0.8±0.05
6±1
8±1
PNP400
15.5±1
5.2±0.5
0.8±0.05
8±1
8±1
FKK TYPE
Unit: mm
PN TYPE (Taping Pack)
H
HI
E
Max.
Max.
5±1
18.5
3.5
3.5±1
24
5±1
3.5±1
28
5± 1
25
3.5
3.5±1
Max.
hl
DIMENSIONS
H3
Max.
Ultra
Miniature
H1
Max.
H2
Max.
H3
Max.
21.5
8.5
PNP100
11.5
17
25.5
8.5
PNP200
14.5
23
8.5
19
27.5
8.5
PNP300
17.5
26
8.5
DIMENSIONS
Ultra
Miniature
H1
Max.
H2
Max.
PNP100
13
PNP200
PNP300
e
AV TYPE (Taping Pack)
TYPE
TYPE
Unit: mm
Unit: mm
www.yageo.com
Aug. 16, 2021
V.0
13
Wirewound Resistors
17
PNP
FT TYPE (Taping Pack)
TYPE
DIMENSIONS
Ultra
Miniature
H1
Max.
H2
Max.
H3
Max.
PNP100
10
18.5
8.5
PNP200
13
21.5
8.5
PNP300
16
24.5
8.5
Unit: mm
www.yageo.com
Aug. 16, 2021
V.0
14
Wirewound Resistors
17
PNP
MARKING
5-BAND-CODE
±5%
COLOR
BLACK
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GREY
WHITE
GOLD
SILVER
1st BAND
2nd BAND
3rd BAND
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
8
9
MULTIPLIER
1Ω
10Ω
100Ω
1KΩ
10KΩ
100KΩ
1MΩ
10MΩ
TOLERANCE
0.1Ω
0.01Ω
±5 % (J)
±1 % (F)
PNP Series
±1%
6-BAND-CODE
www.yageo.com
Aug. 16, 2021
V.0
15
Wirewound Resistors
17
PNP
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 0
Aug.2, 2021
- First issue of this specification
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as
the products itse lf are unchanged. Any product change will be announced by PCN.”
www.yageo.com
Aug. 16, 2021
V.0
16
Wirewound Resistors
17
PNP
LEGAL DISCLAIMER
Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors,
inaccuracies or incompleteness contained in any product related information, including but not limited to product
specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or
improvements to product related information at any time and without notice.
Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular
purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo
disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability,
including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties,
including warranties of fitness for a particular purpose, non-infringement and merchantability.
Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s
knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are
neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a
specific customer application or use. They are intended for use only by customers with requisite knowledge and
experience for determining whether Yageo products are the correct products for their application or use. In
addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or
use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective
safeguard measures to ensure that product failure would not result in personal injury or property damage.
Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for
any other application or use in which the failure of Yageo products could result in personal injury or death.
Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at
their own risk and agree to fully indemnify Yageo and hold Yageo harmless.
Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this
content without further notification, as long as products are unchanged. Any product change will be announced by PCN.
www.yageo.com
Aug. 16, 2021
V.0
17
