CH6,BK
CH6,BK
    SERPAC
    BOX ABS BLACK 2.39"L X 1.74"W
CH6,BK 数据手册
NOTES: 1) When machine or I-plates modifications are required, use the center of the enclosure to dimension. CH6 1.313 Insert Area .755 1.717 A .185 .247 1.963 Insert Area 2.390 .310 DETAIL B corner detail B Top .030 Bottom A .390 .065 typ. R.150 typ. Enclosure can hold either a 0.032" PCB or a 0.063 PCB PCB dimensions are: (PCB drawings on page 2) 0.032" [.8mm] PCB 2.16" X 1.52" (0.20" center hole) 0.063" [1.6mm] PCB 2.12" X 1.48" (0.26" center hole) PART NO. DESCRIPTION 1103 CH6 TOP 1104 CH6 BOTTOM 6007 SCREW 2x3/4” PHILFLAT H/L (1) ACCSESSORIES PART NO. 55 DESCRIPTION KEY HOLDER .305(-1 /sd) 4X @ ribs .030 @ perimeter to trap 0.032" thk PCB .005 Top Bottom SECTION A-A .247 for 0.063" PCB .186 for 0.032" PCB .065 @ 4 corners to trap 0.065" thk PCB ALL DIMENSIONS ARE ± .010" 7/19/12 2009 Wright Ave., La Verne, CA 91750 Ph. (626) 331-0517 Fx. (626) 331-8584 www.serpac.com CIRCUIT BOARD CH6 .03 1.52 .065 1.48 2.12 2.16 .20 .26 .032 board .065 board NOTES: These are suggested dimensions. Plastic parts have a 0.010" manufacturing tolerance. 7/18/12 (626) 331-0517 2009 Wrignt Ave., La Verne, CA 91750 Fax (626) 331-8584 http://www.serpac.com.
CH6,BK 价格&库存
很抱歉,暂时无法提供与“CH6,BK”相匹配的价格&库存,您可以联系我们找货
