Through-hole resistors
Precision Type
Metal Film Resistors
Normal & Miniature Style [ MFP Series ]
FEATURES
Power Rating
1/6W, 1/4W, 0.4W, 1/2W, 0.6W, 1W, 2W, 3W
Resistance Tolerance
±0.1%, ±0.25%, (±0.02%, ±0.05% on request)
T.C.R.
±15ppm/°C, ±25ppm/°C, (±5ppm/°C, ±10ppm/°C on request)
DERATING CURVE
For resistors operated in ambient temperatures above 70°C, power rating must be derated
in accordance with the curve below.
INTRODUCTION
The MFP Series Metal Film Precision Resistors
are manufactured using a vacuum sputtering
system to deposit multiple layers of mixed metal
alloys and passivative materials onto a carefully
treated high grade ceramic substrate. After a
helical groove has been cut in the resistive layer,
tinned connecting leads of electrolytic copper
are welded to the end-caps. The resistors are
coated with layers of blue color lacquer. Ultra
high precision resistors, ultra high stability, ultra
low temperature coefficient.
70
Rated Load (%)
155 °C
100
80
60
40
60
80
100 120 140 160
Ambient Temperature (°C)
DIMENSIONS
Unit: mm
STYLE
ød
H
L
øD
DIMENSION
Normal
Miniature
L
øD
H
ød
MFP-12
MFP25S
3.4±0.3
1.9±0.2
28±2.0
0.45±0.05
MFP204
3.4±0.3
1.9±0.2
28±2.0
0.45±0.05
MFP-25
MFP50S
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
MFP207
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
MFP-50
MFP1WS
9.0±0.5
3.3±0.3
26±2.0
0.55±0.05
MFP100
MFP2WS
11.5±1.0
4.5±0.5
35±2.0
0.8±0.05
MFP200
MFP3WS
15.5±1.0
5.0±0.5
33±2.0
0.8±0.05
7
Note:
ELECTRICAL CHARACTERISTICS
STYLE
MFP-12 MFP25S MFP204 MFP-25 MFP50S
MFP207 MFP-50
MFP1WS
Power Rating at 70°C
1/6W
1/4W
0.6W
1/2W
1W
Maximum Working Voltage
150V
200V
250V
350V
400V
500V
Maximum Overload Voltage
300V
400V
500V
700V
800V
1,000V
Voltage Proof on Insulation
300V
700V
1,000V
Resistance Range
10Ω - 1 MΩ for E192 series value
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
0.4W
1/4W
1/2W
600V
500V
MFP100 MFP2WS
MFP200 MFP3WS
2W
3W
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±0.25%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -55°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>10,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±1.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±1.5%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±1.5%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±0.75%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±0.25%+0.05Ω
Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“MFP-25BRD52-180R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+1.363075000+0.17049
- 10000+1.2711510000+0.15900
- 15000+1.2239515000+0.15309
- 25000+1.1705625000+0.14641
- 35000+1.1407635000+0.14269
- 国内价格 香港价格
- 1+5.269581+0.65911
- 10+3.3827310+0.42311
- 25+2.8744725+0.35953
- 50+2.5549050+0.31956
- 100+2.28430100+0.28572
- 250+1.98799250+0.24866
- 500+1.80211500+0.22541
- 1000+1.644231000+0.20566
