NOTICE
Ref Nr: LR-20161228
Date: 2016.12.28
TO: All customers
Leaded-R Quality Assurance Dept.
HEREWITH YOU ARE INFORMED OF BELOW.
DESCRIPTION:
1. 因原材料供貨因素,FRM 系列已不再生產,全面改用特性規格更高階之FKN系列。
FRM series is phased out due to raw material discontinued, alternative one is FKN
series with superior characteristics.
2. 生效日期:自2017年7月1日起生效。
Effective date: from Jul.1, 2017.
3. FRM & FKN 比較
Comparison table of FRM and FKN:
Series
FRM
Fusible Metal Film Resistors
FKN
Fusible Wirewound Resistors
Power Range
1/4W~3W
1/4W~7W
Function
Safety function to protect circuit board
Resistance Element
Comparison
FKN is with wider power range
Same funtion
Metal Film
Alloy Wire
TCR
±200 ppm /℃
±300 ppm /℃
(Standard, low T.C.R is on request)
Different technics
FKN is flexible for customized requirment
Resistance Range
1Ω~560Ω
0.1Ω~1KΩ
FKN Series is with wider resistance range
Fusing
Characteristics
1Ω≦R≦2.0Ω Fusing time within 30
seconds at 25 times of rated power
R≧2.2Ω Fusing time within 30 seconds
at 16 times of rated power
Surge Voltage
Low
High (on request)
FKN is capabile to withstand higher surge
voltage at the same conditions.
Detail as comparison table
Load Life
Common
Excellent
FKN performs better in Load Life stability.
R≤2.0 Ω Fusing time within 60 seconds
FRM cut off with shorter time at the same
at 36 times of rated power;
R>2.0 Ω Fusing time within 60 seconds at conditions.
See attached table
25 times of rated power;
Fusing Time and Surge withstanding Voltage difference at the same conditions.
Yageo PN
Power / Value
Fusing Test
Method
Appraise
Fusing
Voltage
current
Fusing time
surge
Voltage
FRM3WSJT-73-1R
3W / 1R
25 times of
rated power
within 30s
8.66V
8.66A
2.5s~4.7s
400V
FKN3WSJT-73-1R
3W / 1R
25 times of
rated power
within 60s
8.66V
8.66A
21s~24s
1KV
FRM3WSJT-73-22R
3W / 22R
25 times of
rated power
within 30s
40.6V
1.85A
0.7s~1.5s
500V
FKN3WSJT-73-22R
3W / 22R
25 times of
rated power
within 60s
40.6V
1.85A
12s~15s
1.5KV
NOTICE
SUGGESTION FOR ALTERNATIVE PRODUCTS: Not applicable
Quality Manager
Signature:
Product Manager
Nane. Zhou.
Date: Sep.22,2016 Dec. 28, 2016
Sales Manager
Signature:
Flora Shen
Signature:
Ken Hsu
Date:
Dec. 28, 2016
Date:
Dec. 28, 2016
FOR MORE INFORMATION, CONTACT: Flora Shen e-mail: flora.shen@yageo.com
RETURN YOUR COMMENTS BEFORE: Jan.31, 2017
Remarks:
Comments
Date:
Dec. 28, 2016
Function:
Marketing
Signature:
Ken Hsu
很抱歉,暂时无法提供与“FRM-50JT-52-100R”相匹配的价格&库存,您可以联系我们找货
