Through-hole resistors
Fusible &
Flame-Proof Type
Wirewound Resistors
Normal & Miniature Style [ FKN Series ]
FEATURES
Power Rating
1/2W, 1W, 2W, 3W, 4W, 5W, 7W
Resistance Tolerance
±1%, ±5%
T.C.R.
±350ppm/°C
Flameproof Multi-layer Coating Meets
UL-94V-0
Flameproof Feature Meets Overload Test
UL-1412
DERATING CURVE
INTRODUCTION
The resistor element is a resistive wire which
is wound in a single layer on a ceramic rod,
with tinned connecting wires of electrolytic
copper welded to the end-caps. The ends of
the resistive wire are connected to the caps by
welding. The resistors are coated with layers
of green color flame-proof lacquer. Overload
protection without risk of fire. Wide range of
overload currents.
For resistors operated in ambient temperatures above 40°C, power rating must be derated
in accordance with the curve below.
Rated Load (%)
40 70
155
275 °C
100
3W-7WS
1/2WS-3WS
80
60
40
Ambient Temperature (°C)
100 150 200 250 300
FUSING CHARACTERISTICS
R≤2.0Ω Fusing time within 60 seconds at 36 times of rated power
R>2.0Ω Fusing time within 60 seconds at 25 times of rated power
Fusing residual resistive value at least 100 times rated resistance
DIMENSIONS
Unit: mm
ød
H
L
øD
5th color code: white
STYLE
DIMENSION
Normal
Miniature
L
øD
H
ød
FKN50S/FKN1SS
6.3±0.5
2.5±0.3
28±2.0
0.55±0.05
FKN-50
FKN1WS/FKN2SS 9.0±0.5
3.5±0.3
26±2.0
0.55±0.05
FKN100
FKN2WS
11.5±1.0
4.6±0.5
35±2.0
0.8±0.05
FKN200
FKN3WS
15.5±1.0
5.2±0.5
33±2.0
0.8±0.05
FKN5WS
17.5±1.0
6.2±0.5
32±2.0
0.8±0.05
FKN7WS
24.5±1.0
8.2±0.5
38±2.0
0.8±0.05
FKN300
FKN400
FKN500
Note: FKN1WS ( for MB Type ) ød = 0.8±0.05 mm
47
ELECTRICAL CHARACTERISTICS
Normal STYLE
STYLE
FKN-50
FKN100
FKN200
Power Rating at 40°C
Power Rating at 70°C
1/2W
Maximum working voltage
PxR
Voltage Proof on Insulation
300V
Resistance Range (±1%)
Resistance Range (±5%)
0.5Ω - 47Ω
Operating Temp. Range
-40°C to +155°C
Temperature Coefficient
±350ppm/°C
FKN300
FKN400
FKN500
3W
4W
5W
1W
2W
0.5Ω - 100Ω
0.47Ω - 150Ω
0.56Ω - 330Ω
1Ω - 620Ω
0.5Ω - 100Ω
0.47Ω - 150Ω
0.56Ω - 330Ω
1Ω - 620Ω
Note: Special value is available on request
MINIATURE STYLE
STYLE
FKN50S
FKN1WS/FKN1SS
FKN2WS/FKN2SS
FKN3WS
1/2W
PxR
200V
2.5Ω - 22Ω
-40°C to +155°C
±350ppm/°C
1W
FKN5WS
FKN7WS
5W
7W
2W
3W
0.47Ω - 100Ω
0.47Ω - 150Ω
0.47Ω - 240Ω
0.56Ω - 330Ω
1Ω - 620Ω
0.47Ω - 100Ω
0.47Ω - 150Ω
0.47Ω - 240Ω
0.56Ω - 330Ω
1Ω - 620Ω
300V
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
10 times rated power for 5 Sec.
±2.0%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -40°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>100MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±5.0%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±1.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±1.0%+0.05Ω
Accidental Overload Test
IEC 60115-1 4.26
4 times RCWV for 1 Min.
No evidence of flaming
or arcing
Note: Rated Continuous Working Voltage (RCWV) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“FKN1WSJR-52-15R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.029151+0.26252
- 10+1.3157410+0.17022
- 25+1.1094125+0.14353
- 50+0.9784850+0.12659
- 100+0.86816100+0.11232
- 250+0.74647250+0.09658
- 500+0.67035500+0.08673
- 1000+0.605611000+0.07835
- 国内价格 香港价格
- 2500+0.534682500+0.06918
- 5000+0.490285000+0.06343
- 7500+0.467457500+0.06048
- 12500+0.4416512500+0.05714
- 17500+0.4262717500+0.05515
- 25000+0.4112425000+0.05321
