Through-hole resistors
Axial Lead Type
Cement Resistors
Normal Style [ SQP Series ]
Non-Inductive Style [ NSP Series ]
FEATURES
Power Rating
1W, 2W, 3W, 5W, 7W, 10W, 15W, 20W, 25W, 30W, 40W
Resistance Tolerance
Wirewound:±1%, ±5%, Film:±5%
T.C.R.
Wirewound:±100ppm/°C, ±300ppm/°C, Film:±300ppm/°C
DERATING CURVE
25 40 70
Rated Load
The materials used and the construction
techniques ensure excellent flame resistance,
arc resistance and moisture resistance as well
as self-extinguishing capabilities. They will
withstand the most rigorous loading test.
155
275 °C
100
15W-40W
3W-5W
7W-10W
1W-2W
80
60
40
(°C)
As resistors in radio and television receivers,
hazardous conditions such as smoking and
redheat can be completely prevented by the
proper choice of power resistors.
Temperature Rise
INTRODUCTION
TEMPERATURE RISE
300
40W
15W
10W
250
200
7W
5W
150
3W
100
2W
50
1W
100 150 200 250 300
60
80
Ambient Temperature (°C)
100 120
Rated Load (%)
DIMENSIONS
Unit: mm
STYLE
32±3
W
ød
L
C
h
C
Φd
B 9
E
9
E
SQP40A, NSP40A
H
W
H
L
32±3
DIMENSION
Normal
Non-Inductive
L
W
H
ød
SQP100
NSP100
13±1.0
5.5±1.0
5.5±1.0
0.6±0.05
SQP200
NSP200
18±1.0
7.0±1.0
7.0±1.0
0.65±0.05
SQP300
NSP300
22±1.5
8.0±1.0
8.0±1.0
0.8±0.05
SQP5WS
25±1.5
6.0±1.0
6.0±1.0
0.65±0.05
SQP500
NSP500
22±1.5
9.5±1.0
9.0±1.0
0.8±0.05
SQP700
NSP700
35±1.5
9.5±1.0
9.0±1.0
0.8±0.05
SQP10A
NSP10A
48±1.5
9.5±1.0
9.0±1.0
0.8±0.05
SQP15A
NSP15A
48±1.5
12.5±1.0
12.5±1.0
0.8±0.05
SQP20A
NSP20A
60±5.0
12.5±1.0
12.5±1.0
0.8±0.05
SQP25A
NSP25A
60±5.0
14.0±1.5
13.0±1.5
0.8±0.05
SQP30A
NSP30A
77±5.0
18.0±1.5
17.0 +2.5
-1.0
0.8±0.05
STYLE
Normal
DIMENSION
Non-Ind. L
SQP40A NSP40A 90±5.0
W
H
h
B
C
E
ød
19.0±1.5
20.5±1.5
19.5±1.5
15.0±1.0
32±3
9.0±0.5
0.8±0.05
55
ELECTRICAL CHARACTERISTICS
Normal Style
STYLE
SQP100
SQP200
SQP300
SQP5WS
SQP500
SQP700
SQP10A
Power Rating at 25°C
Power Rating at 40°C
3W
5W
7W
SQP15A
SQP20A
SQP25A
SQP30A
SQP40A
15W
20W
25W
30W
40W
10W
Power Rating at 70°C
1W
2W
Maximum Working Voltage
200V
250V
350V
500V
1,000V
Maximum Overload Voltage
500V
500V
700V
1,000V
2,000V
Voltage Proof on Insulation
500V
500V
700V
1,000V
2,000V
Resistance Range (Wirewound) 0.1Ω - 27Ω 0.03Ω - 36Ω 0.015Ω - 68Ω 0.015Ω - 130Ω
0.05Ω - 330Ω 0.08Ω - 510Ω 0.1Ω - 680Ω 0.15Ω - 1KΩ
Resistance Range (Film)
30Ω - 47KΩ 39Ω - 1MΩ 75Ω - 1MΩ 150Ω - 1MΩ
360Ω - 100kΩ 560Ω -100KΩ -
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
NSP700
NSP15A
NSP20A
NSP25A
NSP30A
NSP40A
15W
20W
25W
30W
40W
NON-INDUCTIVE STYLE
STYLE
NSP100
NSP200
NSP300
NSP500
NSP10A
3W
1W
5W
7W
10W
2W
PxR
PxR
500V
500V
700V
1,000V
Resistance Range (Wirewound) 0.08Ω - 10Ω 0.08Ω - 10Ω 0.1Ω - 30Ω
-55°C to +155°C
±300ppm/°C
2,000V
0.1Ω - 40Ω 0.15Ω - 65Ω 0.25Ω - 100Ω 0.25Ω - 120Ω 0.36Ω - 160Ω
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±2.0%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -40°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>1,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±2.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±5.0%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±2.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±1.0%+0.05Ω
Note: Rated Continuous Working Voltage (RCWV) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“SQP10AJB-1K2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+5.76927
- 125+5.64222
- 250+5.52350
- 国内价格
- 500+2.52848
- 1000+2.46600
- 国内价格 香港价格
- 1+4.753011+0.59436
- 10+3.9273810+0.49112
- 25+3.6389225+0.45505
- 40+3.3268540+0.41602
- 80+2.7359380+0.34213
- 230+2.51011230+0.31389
- 500+2.20958500+0.27631
