SQP10AJB-18R
SQP10AJB-18R
    YAGEO(国巨)
    插件,48x9.5mm
    插件电阻 - 18Ω ±5% 10W -
SQP10AJB-18R 数据手册
Through-hole resistors Axial Lead Type Cement Resistors Normal Style [ SQP Series ] Non-Inductive Style [ NSP Series ] FEATURES Power Rating 1W, 2W, 3W, 5W, 7W, 10W, 15W, 20W, 25W, 30W, 40W Resistance Tolerance Wirewound:±1%, ±5%, Film:±5% T.C.R. Wirewound:±100ppm/°C, ±300ppm/°C, Film:±300ppm/°C DERATING CURVE 25 40 70 Rated Load The materials used and the construction techniques ensure excellent flame resistance, arc resistance and moisture resistance as well as self-extinguishing capabilities. They will withstand the most rigorous loading test. (%) 155 275 °C 100 15W-40W 3W-5W 7W-10W 1W-2W 80 60 40 (°C) 20 0 -50 As resistors in radio and television receivers, hazardous conditions such as smoking and redheat can be completely prevented by the proper choice of power resistors. Temperature Rise INTRODUCTION TEMPERATURE RISE 0 50 300 40W 15W 10W 250 200 7W 5W 150 3W 100 2W 50 1W 100 150 200 250 300 20 40 60 80 Ambient Temperature (°C) 100 120 Rated Load (%) DIMENSIONS Unit: mm STYLE 32±3 W ød L C h C Φd B 9 E 9 E SQP40A, NSP40A H W H L 32±3 DIMENSION Normal Non-Inductive L W H ød SQP100 NSP100 13±1.0 5.5±1.0 5.5±1.0 0.6±0.05 SQP200 NSP200 18±1.0 7.0±1.0 7.0±1.0 0.65±0.05 SQP300 NSP300 22±1.5 8.0±1.0 8.0±1.0 0.8±0.05 SQP5WS - 25±1.5 6.0±1.0 6.0±1.0 0.65±0.05 SQP500 NSP500 22±1.5 9.5±1.0 9.0±1.0 0.8±0.05 SQP700 NSP700 35±1.5 9.5±1.0 9.0±1.0 0.8±0.05 SQP10A NSP10A 48±1.5 9.5±1.0 9.0±1.0 0.8±0.05 SQP15A NSP15A 48±1.5 12.5±1.0 12.5±1.0 0.8±0.05 SQP20A NSP20A 60±5.0 12.5±1.0 12.5±1.0 0.8±0.05 SQP25A NSP25A 60±5.0 14.0±1.5 13.0±1.5 0.8±0.05 SQP30A NSP30A 77±5.0 18.0±1.5 17.0 +2.5 -1.0 0.8±0.05 STYLE Normal DIMENSION Non-Ind. L SQP40A NSP40A 90±5.0 W H h B C E ød 19.0±1.5 20.5±1.5 19.5±1.5 15.0±1.0 32±3 9.0±0.5 0.8±0.05 55 ELECTRICAL CHARACTERISTICS Normal Style STYLE SQP100 SQP200 SQP300 SQP5WS SQP500 SQP700 SQP10A Power Rating at 25°C Power Rating at 40°C 3W 5W 7W SQP15A SQP20A SQP25A SQP30A SQP40A 15W 20W 25W 30W 40W 10W Power Rating at 70°C 1W 2W Maximum Working Voltage 200V 250V 350V 500V 1,000V Maximum Overload Voltage 500V 500V 700V 1,000V 2,000V Voltage Proof on Insulation 500V 500V 700V 1,000V 2,000V Resistance Range (Wirewound) 0.1Ω - 27Ω 0.03Ω - 36Ω 0.015Ω - 68Ω 0.015Ω - 130Ω 0.05Ω - 330Ω 0.08Ω - 510Ω 0.1Ω - 680Ω 0.15Ω - 1KΩ Resistance Range (Film) 30Ω - 47KΩ 39Ω - 1MΩ 75Ω - 1MΩ 150Ω - 1MΩ 360Ω - 100kΩ 560Ω -100KΩ - - Operating Temp. Range -55°C to +155°C Temperature Coefficient Wirewound:±100ppm/°C, ±300ppm/°C, Film:±300ppm/°C NSP700 NSP15A NSP20A NSP25A NSP30A NSP40A 15W 20W 25W 30W 40W NON-INDUCTIVE STYLE STYLE NSP100 NSP200 NSP300 NSP500 NSP10A Power Rating at 25°C Power Rating at 40°C Power Rating at 70°C 3W 1W Maximum Working Voltage Voltage Proof on Insulation 5W 7W 10W 2W PxR PxR 500V 500V 700V 1,000V Resistance Range (Wirewound) 0.08Ω - 10Ω 0.08Ω - 10Ω 0.1Ω - 30Ω Operating Temp. Range -55°C to +155°C Temperature Coefficient ±300ppm/°C 2,000V 0.1Ω - 40Ω 0.15Ω - 65Ω 0.25Ω - 100Ω 0.25Ω - 120Ω 0.36Ω - 160Ω Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage) ±2.0%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -40°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥2.5kg (24.5N) Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±2.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±5.0%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±2.0%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±1.0%+0.05Ω Note: Rated Continuous Working Voltage (RCWV) =  Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
SQP10AJB-18R
1. 物料型号: - 型号名称:XXXXX - 制造商:XXXXX
2. 器件简介: - 这是一个用于XXXXX的集成电路,具有XXXXX功能。
3. 引脚分配: - 引脚1:XXXXX - 引脚2:XXXXX - (以此类推)
4. 参数特性: - 工作电压:XXXXX - 最大电流:XXXXX - 工作温度:XXXXX
5. 功能详解: - 功能一:XXXXX - 功能二:XXXXX - (以此类推)
6. 应用信息: - 应用场景:XXXXX - 使用案例:XXXXX
7. 封装信息: - 封装类型:XXXXX - 封装尺寸:XXXXX
SQP10AJB-18R 价格&库存
很抱歉,暂时无法提供与“SQP10AJB-18R”相匹配的价格&库存,您可以联系我们找货
SQP10AJB-18R
  • 1+7.217691+0.93288
  • 10+4.7010810+0.60761
  • 25+4.0074125+0.51796
  • 50+3.5743550+0.46199
  • 100+3.20634100+0.41442
  • 250+2.80174250+0.36213
  • 500+2.54872500+0.32942
  • 1000+2.333471000+0.30160
  • 5000+1.950315000+0.25208
库存:896
