BK/GMA-V-7A
BK/GMA-V-7A
    EATON(伊顿)
    插件,D5.54xL21.1mm
    一次性保险丝(熔断) 7A 125V
BK/GMA-V-7A 数据手册
5mm x 20mm Fuses GMA Series, Fast Acting, Glass Tube Description • Fast acting, low breaking capacity • Optional axial leads available • 5mm x 20mm physical size • Glass tube, nickel-plated brass endcap construction • Designed to UL/CSA 248-14 RoHS 2002/95/EC ELECTRICAL CHARACTERISTICS Rated Current % of Amp Rating Opening Time 100% None 63mA - 10A 135% 60 minutes maximum 200% 2 minutes maximum Agency Information • UL Listed, Guide JDYX, File E19180, 63mA-6A • UL Recognized Card: (7A-15A) Guide JDYX2, File E19180 • CSA Certified, Class 1422-01, File E65063, 63mA-6A • MITI Approval, 1A-15A • CCC Approval, 63mA-6A Ordering • Specify packaging, product, and option code • For -R option, drop mA or A from product code (i.e. GMA-2-R) Dimensions ⁄(inches) mm 38.10mm 10mm (± ±.38) 38) 5.54mm (±.20) (± 21.10mm 0mm (±.81) (± 5.2mm (+0.1/-0.2) 38.10mm 0mm (±.38) 38) 0.65mm (REF) • Ratings above 6.3A have a 0.8mm diameter lead • With TR2 packaging code, lead wire length is 19.05mm SPECIFICATIONS Product Code GMA-63mA GMA-100mA GMA-125mA GMA-200mA GMA-250mA GMA-300mA GMA-315mA GMA-500mA GMA-600mA GMA-750mA GMA-800mA GMA-1A GMA-1.25A GMA-1.5A GMA-1.6A GMA-2A GMA-2.5A GMA-3A GMA-3.15A GMA-3.5A GMA-4A GMA-5A GMA-6A GMA-7A GMA-8A GMA-10A GMA-15A * ** † ‡ Voltage Rating AC 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 125V 125V 125V 125V 125V 125V 125V 125V 125V AC Interrupting Rating* 250V 125V 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 10,000A 35A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 10,000A 10,000A 10,000A 10,000A 10,000A 200A 200A 200A 150A Typical DC Cold Resistance (ohms)** 0.454 0.256 0.186 0.170 0.163 0.122 0.090 0.080 0.066 0.046 0.039 0.036 0.030 0.026 0.021 0.017 0.012 0.009 0.006 0.004 Typical Pre-Arc I2t AC† 0.00024 0.0001 0.0024 0.001 0.018 0.019 0.019 0.15 0.32 0.47 0.70 0.48 0.84 1.6 2.0 3.1 4.9 8.8 9.7 13 19 29 45 150 280 280 950 Maximum Voltage Drop (mV)‡ 4700 4300 2600 3400 2200 470 450 230 200 200 180 300 290 270 260 250 240 215 210 210 205 200 180 110 110 110 100 Interrupting ratings: Interrupting ratings for 63mA - 6A were measured at 70% - 80% power factor on AC. The interrupting ratings for 7A - 15A were measured at 100% power factor on AC. DC Cold Resistance (Measured at
BK/GMA-V-7A 价格&库存
很抱歉,暂时无法提供与“BK/GMA-V-7A”相匹配的价格&库存,您可以联系我们找货
