BK/GMD-630MA
BK/GMD-630MA
    EATON(伊顿)
    D5.2xL20mm
    一次性保险丝(熔断) 630mA 250V
BK/GMD-630MA 数据手册
5mm x 20mm Fuses GMD Series, Time Delay, Glass Tube Description • Time delay, low breaking capacity • Optional axial leads available • 5mm x 20mm physical size • Glass tube, nickel-plated brass endcap construction • Designed to UL/CSA 248-14 RoHS 2002/95/EC ELECTRICAL CHARACTERISTICS Rated Current % of Amp Rating Opening Time 100% None 135% 60 minutes maximum 100mA - 4A 5 seconds minimum 200% 2 minutes maximum Dimensions mm ⁄(inches) 38.10mm (±.38) 5.54mm (±.20) Agency Information • UL Listed, Guide JDYX, File E19180, 125mA-3A • UL Recognition Card: (4A) Guide JDYX2, File E19180 • CSA Certified, Class 1422-01, File E65063 Ordering • Specify packaging, product, and option code • For -R option, drop mA or A from product code (i.e. GMD-3-R) 21.10mm (±.81) (± ( 0.5) 5.2mm (+0.1/-0.2) (±.38) 0.65mm (REF) • With TR2 packaging code, lead wire length is 19.05mm SPECIFICATIONS Product Code GMD-125mA GMD-150mA GMD-200mA GMD-250mA GMD-300mA GMD-315mA GMD-375mA GMD-400mA GMD-500mA GMD-600mA GMD-630mA GMD-750mA GMD-800mA GMD-1A GMD-1.2A GMD-1.25A GMD-1.5A GMD-1.6A GMD-2A GMD-2.5A GMD-3A GMD-4A * ** † ‡ Voltage Rating AC 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V AC Interrupting Rating* 250V 125V 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 200A 10,000A Typical DC Cold Resistance (ohms)** - Typical Pre-Arc I2t AC† 0.043 0.046 0.20 0.40 0.65 0.89 0.89 1.2 1.4 3.1 3.1 4.7 6.6 12 16 16 25 27 42 94 145 300 Maximum Voltage Drop (mV)‡ 1600 1200 1100 950 800 750 650 600 550 450 450 410 380 310 280 245 240 220 200 195 190 190 Interrupting ratings: Interrupting ratings for 125mA - 3A were measured at 70% - 80% power factor on AC. The interrupting ratings for 4A were measured at 100% power factor on AC. DC Cold Resistance (Measured at
BK/GMD-630MA 价格&库存
很抱歉,暂时无法提供与“BK/GMD-630MA”相匹配的价格&库存,您可以联系我们找货
