BK/1A5018-10-R
BK/1A5018-10-R
    EATON(伊顿)
    BK/1A5018-10-R
BK/1A5018-10-R 数据手册
Effective June 2022 Supersedes August 2021 Technical Data 2131 1AXXXX PCB Fuse-clips for ATC/ATM Blade, 5 mm, 1/4” & 13/32” diameter fuses For 1/4” diameter fuses End stops Without end stops 1A1119 Family Angled-In leads Dimensions - in (mm) .187" (4.8mm) 1A1120 Family Angled-in leads Dimensions - in (mm) .132" Catalog number1,3 (3.4mm) Clip material2 1A1119-04-R Cu clad steel .320" (8.13mm) 1A1119-05 .312" (7.9mm) Cu clad steel 1A1119-10-R Cartridge brass Finish 0.187” [4.75] 0.312” [7.92] Bright tin Silver Bright tin Catalog number1,3 Ø 0.130”±.003 [3.3mm±0.08] 1A1120-05 0.272” [6.91] Clip material2 Cu clad steel Finish Silver 1A1120-06-R Cu clad steel Bright tin 1A1120-09-R Cartridge brass Bright tin .420" (10.7mm) 0.250” [6.35] .250" (6.35mm) .080" .290" .155" (7.4mm) (3.9mm) 0.080” [2.03] 0.320” [8.13] .360" (2.03mm) (9.14mm) 1A1907 Family Straight leads Dimensions - in (mm) .155" (2.6mm) Catalog number1,3 .255" (6.5mm) Clip material2 1A1907-02-R Cartridge brass .280" (7.1mm) 0.400”±.010 [10.16±0.25] 0.155”±.010 [3.94±0.25] 0.290”±.010 [7.37±0.25] 0.363”±.003 [9.22±0.08] 1A3398 Family Straight leads Dimensions - in (mm) (3.94mm) .102" Dia. C L .245" .155" Finish Bright dipped 1A1907-03-R High performance Cu Bright tin (6.2mm) 1A1907-05 High performance Cu Silver Bright tin 1A1907-06-R Cartridge brass .410" (10.4mm) (3.94mm) .102" Dia. (2.6mm) .280" Catalog number1,3 Clip material2 1A3398-07-R Cartridge brass Bright tin Finish (7.1mm) .255" (6.5mm) .410" (10.4mm) UL recognized file number: E14853 .060" (1.5mm) .320" .140" (3.6mm) .060" .280" (1.5mm) (7.1mm) .320" (8.13mm) 1A4534 Family Angled out leads Dimensions - in (mm) .155" (3.94mm) .320" (8.13mm) .102" Catalog number1,3 (2.6mm) Clip material2 1A4534-01-R Cu clad steel 1A4534-06-R Cartridge brass .280" (7.11mm) .155" Finish Bright tin Bright tin (3.94mm) .320" (8.13mm) .280" (7.11mm) .150" Clip material2 Finish 1A4533-01-R Cu clad steel Bright tin 1A4533-06-R Cartridge brass Bright tin (6.2mm) .410" (3.81mm) Catalog number1,3 .245" .410" (10.4mm) .060" .102" (2.6mm) (6.2mm) .255" (1.5mm) .280" (7.1mm) 1A4533 Family Angled out leads Dimensions - in (mm) .245" (6.5mm) .140" (3.6mm) (8.13mm) (10.4mm) .226" .255" (5.74mm) (6.5mm) .321" .060" (8.15mm) (1.5mm) .150" (3.81mm) .226" (5.79mm) .321" (8.20mm) Notes: 1. All part numbers shown are RoHS compliant 2. Add -BK prefix to part number for bulk packaging  Technical Data 2131 Effective June 2022  For 5 mm diameter fuses 1A5601 Family Dimensions - in (mm) 1A3399 and 1A5018 Family With straight leads Dimensions - in (mm) 1A5601 .062" .115" (1.6mm) (2.9mm) .254" .237" (6.5mm) Clip material2 1A5601-01 Spring brass 1A5601 1A5601-01 Nominal current Finish maximum Cartridge brass Bright tin 7 A Catalog number1,3 Bright tin (6.0mm) Clip material 1A3399-01 Beryllium Cu 1A3399-10-R 1A3399-04-R .125" (5.72mm) .060" .125" (1.5mm) (3.2mm) .180" .230" (5.84mm) .219" (5.57mm) .500" .250" (12.70mm) (6.35mm) .140" (3.56mm) Catalog number1,3 1A5602 Clip material2 Cartridge brass .188" High Profile Catalog number1,2 Clip material 1A5018-07 Spring bronze 1A5018-10-R .140" .180" (3.7mm) (4.6mm) Notes: Finish Bright tin .093" (2.36mm) .047" .216" LEGS TO FIT IN .052" (1.3mm) DIA. HOLES ON CENTER 1. (1.19mm) For 13/32” diameter fuses 1A3400 Family With end stops & straight leads Dimensions - in (mm) BK-1A3400-09 Specifications: Catalog Clip Finish number1,2 material BK-1A3400-09-R Cartridge brass Bright tin 1A3400-12-R Cartridge brass Bright tin UL recognized file number: E14853 2 www.eaton.com/electronics All part numbers shown are RoHS compliant 2. Add -BK prefix to part number for bulk (5.48mm) 1A3400-12 Notes: 1. All part numbers shown are RoHS compliant 2. Add -BK prefix to part number for bulk packaging Bright tin Silver (4.8mm) .440" .047" Beryllium Cu .030" (11.2mm) (1.2mm) Bright tin (0.762mm) (4.57mm) 1A5602 Family (
BK/1A5018-10-R 价格&库存
很抱歉,暂时无法提供与“BK/1A5018-10-R”相匹配的价格&库存,您可以联系我们找货
BK/1A5018-10-R
  • 1+3.544831+0.45878
  • 5+2.968265+0.38416
  • 10+2.7355010+0.35404
  • 50+2.2708350+0.29390
  • 100+2.09530100+0.27118
  • 250+1.88423250+0.24386
  • 500+1.73802500+0.22494
  • 1000+1.603001000+0.20747
  • 5000+1.326525000+0.17168
库存:56702
