422C-330SSH-CKP
422C-330SSH-CKP
    WAKEFIELD-VETTE
    WEDGELOCK3.30"HARDANODIZE
422C-330SSH-CKP 数据手册
8 7 6 4 5 1 2 3 .290 EXPANDED MIN 7.37 F F VIEW OF ASSEMBLY EXPANDED .19 4.9 ASSY LENGTH (SEE P/N CODE SHEET 2) .225 5.72 E E VIEW OF ASSEMBLY RELAXED .230 MAX 5.84 MAX .225 5.72 COLD PLATE D D SERIES 422C WEDGLOCK ROLL PIN REAR WEDGE PC BOARD RECOMMENDED GAP: .250 [6.35] + PC BOARD THICKNESS C C INTERMEDIATE WEDGE CENTER WEDGE FEATURES B • • • • • • • DESIGNED FOR HEAVY SHOCK AND VIBRATION. UNIFORM CLAMPING FORCE AND HIGH THERMAL TRANSFER. NARROW WIDTH FOR MAXIMUM PCB COMPONENT AREA. LOW PROFILE DESIGN ALLOWS FOR DECREASED SLOT PITCH. CAPTIVATED REAR WEDGE. LIGHT WEIGHT = ASSEMBLY LENGTH X .080 OZ [2.27 G] OR [.89 G/CM]. SPECIAL LENGTHS, FINISH, AND OTHER DESIGN OPTIONS AVAILABLE UPON REQUEST. FRONT WEDGE B MOUNTING BAR FLAT WASHER LOCK WASHER MATERIAL MOUNTING BAR AND WEDGES: ALUMINUM 6063-T6. ALL OTHER HARDWARE: 18-8 STAINLESS STEEL, PASSIVATED. A DRIVE SCREW UNLESS OTHERWISE SPECIFIED: PARTS ARE SHIPPED AS COMPLETE ASSEMBLY IN RELAXED STATE EXCEPT FOR RIVET MOUNT OPTION. PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF WAKEFIELD-VETTE. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF WAKEFIELD-VETTE IS PROHIBITED. RECOMMENDED DRIVE SCREW TORQUE IS 6 IN-LBS [68 N-CM]. DIMENSIONS ARE IN INCHES TOLERANCES: 63 MACHINED SURFACES 1 ANGULAR TWO PLACE DECIMAL .02 THREE PLACE DECIMAL .005 DRAWN NAME DATE RSB 25 JAN 2013 CHECKED TITLE: APPR. THIRD ANGLE PROJECTION INTERPRET GEOMETRIC TOLERANCING PER: ASME Y-14.5M SIZE DO NOT SCALE DRAWING MATERIAL SEE PART DETAILS FINISH CAGE CODE SEE FINISH TABLE 8 7 6 5 4 3 WEDGELOCK DATASHEET .225 X .225 PROFILE 2 3E7UB DWG. NO. C 422C-DS SCALE: NONE REV 08/13 SHEET 1 OF 2 1 A 8 7 6 4 5 1 2 3 .33 8.4 F E F [LLL] LENGTH TABLE ASSY LENGTH [H] MTG [C] OPTION [LLL] X X/2 280 0.900 0.450 330 1.400 0.700 380 1.900 0.950 430 2.400 1.200 480 2.900 1.450 530 3.400 1.700 PART#1 EXAMPLE: 422C-480UMG 4.80" LENGTH, M2 MOUNT HOLES, METRIC M2.5 SOCKET HEAD, GOLD CHEM FILM PART#2 EXAMPLE: 422C-480UMG-CP SAME AS ABOVE PLUS CENTER MOUNTING HOLE AND LOCK PATCH OPTIONS .225 5.72 PART NUMBER CODE PART DEFINITION (REQUIRED) 580 3.900 1.950 OTHER LENGTHS AVAILABLE UPON REQUEST .225 5.72 PART NUMBER OPTIONS (NOT REQUIRED) 'V' OPTION VISUALLY CONFIRMS LOCKED IN PLACE WHEN RED SCREW HEAD IS CONCEALED 422C - [LLL] [H] [D] [F] - [C] [K] [P] [V] SERIES PART NO E ADD 'V' FOR OPTIONAL VISUAL INDICATOR LENGTH (EX. 480 = 4.80") .10 2.5 ADD 'P' FOR OPTIONAL LOCK PATCH [H] MOUNTING TABLE D DASH NO A DESCRIPTION NO MOUNTING HOLES .068/.073 THRU 100 X .213 R T #0-80 UNF-2B THREADS S #2-56 UNC-2B THREADS U M2 X .4-6H THREADS M M2.5 X .45-6H THREADS ADD 'K' FOR OPTIONAL CAPTIVE SCREW FEATURE MOUNTING HOLE (SEE MOUNTING TABLE) DRIVE SCREW 'M' FOR M2.5 HEX 'S' FOR 3/32 HEX D .25 MIN 6.4 MIN 'P' OPTION NYLON PATCH PER MIL-F-18240 PROVIDES ADDITIONAL RESISTANCE TO SHOCK AND VIBRATION ADD 'C' FOR OPTIONAL CENTER MOUNTING HOLE FINISH (SEE FINISH TABLE) C C 'K' OPTION 3/32 OR M2.5 ACROSS FLATS CAPTIVATES SCREW BY FREE-SPINNING WHEN WEDGELOCK IS IN RELAXED POSITION [x] FINISH TABLE B DASH NO DESCRIPTION B .19 4.9 A NONE C CHEM FILM PER MIL-DTL-5541, CLASS 1A, TYPE I (CLEAR) G CHEM FILM PER MIL-DTL-5541, CLASS 1A, TYPE I (GOLD) B BLACK ANODIZE PER MIL-A-8625, TYPE II, CLASS 2 H HARD BLACK ANODIZE PER MIL-A-8625, TYPE III, CLASS 2 N NICKEL PLATE PER QQ-N-290, CLASS 1, GRADE G, BRIGHT E ELECTROLESS NICKEL PER MIL-C-26074, CLASS 4, GRADE B, BRIGHT T TRIVALENT CHEM FILM PER MIL-DTL-5541, CLASS 1A, TYPE II (CLEAR), RoHS COMPLIANT X .80 20.3 ASSY LENGTH (L.LLL) ALL THREADS ARE GAUGED PRIOR TO PLATING A X/2 ('C' OPTION) A BOTTOM VIEW SIZE DWG. NO. C 422C-DS 7 6 5 4 3 2 08/13 SHEET 2 OF 2 SCALE: NONE 8 REV 1
422C-330SSH-CKP 价格&库存
很抱歉,暂时无法提供与“422C-330SSH-CKP”相匹配的价格&库存,您可以联系我们找货
