Description
Body
Pin
Insulation
Crimp Ring
Boyd Chuck
Heat Shrink
Material
Brass
Brass
PTFE
Brass
BE CU
Polyolefin
Finish
Gold
Gold
N/A
Gold
Gold
Black
REVISIONS
REV
HEAT SHRINK
Ø0.197
[5.00]
SIDE VIEW
0.3x3.9x5 GROOVE
APPV
B
Added new title block and heat shrink; Updated instructions 12-JUL-12
SAH
C
Updated Body finish description, Assembly Instruction 4
and Note 3
CLL
2-NOV-17
PIN
Ø0.148
[3.75]
Ø0.102
[2.60]
0.126
[3.20]
DATE
0.787
[20.00]
BOYD CHUCK
0.165
[4.20]
DESCRIPTION
CRIMP RING
Ø0.020
[0.5]
Ø0.197
(5.00)
Ø0.019
[0.48]
0.232
[5.90]
Ø0.154
[3.90]
Ø0.037
[0.95]
0.276
[7.00]
0.197
[5.00]
0.488
[12.40]
CONMCX007 ASSEMBLY INSTRUCTIONS
1.
2.
3.
4.
5.
6.
Strip cable to recommended dimensions.
Slip heat shrink and crimp ring onto stripped cable.
Solder the pin to the center conductor.
Insert the pin and center conductor into the body
until the pin snaps in.
Wrap the braid around the tail of the body and crimp the ring with a
0.128” hex crimp tool (or one labeled for use with RG-174 cable).
Use heat shrink to cover crimp.
RECOMMENDED CABLE STRIPPING DIMENSIONS
0.079 0.079
[2.00] [2.00]
0.217
[5.50]
RG-174 Cable
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE
MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY
HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE
SOURCED MATERIALS.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
159 ORT LANE
MERLIN, OR 97532
TITLE:
MCX MALE CABLE END CRIMP
FOR RG174 CABLE
SIZE DWG. NO.
DRAWN: B.MURPHY DT: 12-JUL-12
ENGR: S.HOGAN
DT: 12-JUL-12 SCALE: 2:1
REV
CONMCX007
DO NOT SCALE DRAWING
C
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONMCX007”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+55.67400
- 200+22.21560
- 500+21.47040
- 1000+21.11400
