ITEM
Q'TY
1
1
CPCI-220X
PART NUMBER
220mm Card Guide, SEE SHEET 2 TABLE 1
PART DESCRIPTION
2
X
CPCI-ESD1
CPCI ESD Clips, PCB Grounding, SEE SHEET 2 TABLE 1
3
X
CPCI-ESD2
CPCI ESD Clips, Extractor Grounding, SEE SHEET 2 TABLE 1
REV.
B
DESCRIPTION
Engineering Release.
DATE
APPROVED
11/20/14
J. C.
0.12 [3.0mm]
0.31 [7.9mm]
ESD Grounding
Polarity Keys
8.24 [209.2mm]
REF.
2X 0.20 [5.1mm]
0.79 [20.0mm]
SLOT WIDTH
0.110 [2.8mm]
SLOT DEPTH
0.08 [2.0mm]
0.31 [7.9mm]
MAX.
2X 0.45 [11.5mm]
7.69 [195.4mm]
0.40 [10.2mm]
2X 0.26 [6.6mm]
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
ANGULAR
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: 220mm CPCI CARD GUIDE
WITH ESD CLIPS
2. MATERIAL: POLYCARBONATE, GLASS FILLED 20%
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DESIGNED:
Alex Wright
CHECKED:
Brian Oliver
DATE:
08/21/14
DATE:
08/21/14
PART NO:
REVISION:
CPCI-220X-ESDXX
CAGE CODE : 32559
B
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
CPCI-ESD2
EJECTOR GROUNDING
3
TABLE 1
ASSEMBLY CONFIGURATIONS
ASSEMBLY PART
NUMBERS
ITEM QTY
CARD GUIDE
COLOR
CPCI-220-ESD1
2
2
GREY
CPCI-220-ESD2
3
2
GREY
CPCI-220-ESD12
3
2
2
2
GREY
CPCI-220X
CPCI-220Y-ESD1
2
2
YELLOW
1
CPCI-220Y-ESD2
3
2
YELLOW
CPCI-220Y-ESD12
3
2
2
2
YELLOW
CPCI-220R-ESD1
2
2
RED
CPCI-220R-ESD2
3
2
RED
CPCI-220R-ESD12
2
3
2
2
RED
CPCI-220G-ESD1
2
2
GREEN
CPCI-220G-ESD2
3
2
GREEN
CPCI-220G-ESD12
2
3
2
2
GREEN
NOTE: ESD CLIPS COME PRE-ASSEMBLED
2
CPCI-ESD1
PCB BOARD EDGE GROUNDING
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
WITH ESD CLIPS
DESIGNED:
Alex Wright
CHECKED:
Brian Oliver
DATE:
08/21/14
DATE:
08/21/14
PART NO:
REVISION:
CPCI-220X-ESDXX
CAGE CODE : 32559
B
SHEET # 2 OF 2
很抱歉,暂时无法提供与“CPCI-220-ESD12”相匹配的价格&库存,您可以联系我们找货
