CP-AD-515
CP-AD-515
    CINCH
    ADAPTER BNC PLUG TO RCA JACK
CP-AD-515 数据手册
5 PART NUMBER 25-7510 ITEM 1 BODY ITEM 2 CONTACT BRASS BRASS NICKEL PLATED GOLD PLATED 4 ITEM 3 INSULATOR DELRIN 3 2 1 DRAWING NO. ITEM 4 NUT ZINC NICKEL PLATED 25-7510 REVISIONS A B RELEASE FOR QUOTATION 03-28-06 Y U W T ADD NOTE 4&5 11-15-06 Y U W T Thomas Chow D 2006.11.17 08:31:48 +08'00' D 4 O 5.0 3 1 2 O 1.35 O 3.3 O 8.35 O 9.3 C C O 13.8 6.6 O 14.5 14.8 27.5u0.5 B B NOTES: 1. ELECTRICAL SPECIFICATIONS IMPEDANCE: 50 OHMS NOMINAL FREQUENCY RANGE: 0-4 GHz WORKING VOLTAGE: 500 Vrms MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 1500 vrms AT SEA LEVEL CORONA LEVEL:375 VOLTS MINIMUM AT 70,000 FEET CONTACT RESISTANCE: OUTER-0.2 MILLIOHMS MAXIMUM CENTER-2.1 MILLIOHMS MAXIMUM INSULATION RESISTANCE: 5000 MEGOHMS MINIMUM 2. MECHANICAL SPECIFICATIONS DURABILITY: 500 CYCLES MIN 3. ENVIRONMENTAL SPECIFICATIONS RECOMMENDED TEMPERATURE RANGE: -55 ℃ TO +85℃ MOISTURE RESISTANCE: MIL-STD-202 A THIS DRAWING TO BE INTERPRETED PER ANSI Y 14.5M - 1994 COMPANY CONFIDENTIAL 4. PRODUCT SHOULD BE RoHS COMPLIANCE 5. PACKAGING REQUIREMENT FOLLOWS ENGINEERING DOCUMENT P/N 836-40200001XX TOLERANCE UNLESS DRAWN BY OTHERWISE SPECIFIED BETTY.YU DATE DECIMALS DATE X X.X X.XX ANGLES mm CHECKED BY +- 0.5 +- 0.2 +- 0.1 +- 0.5v IVON.W 11-14-06 APPROVED BY DATE THOMAS U/M 4 3 2 TITLE ADAPTER RCA JACK TO BNC PLUG 11-14-06 mm THIS DRAWING WAS PRODUCED BY COMPUTER, DO NOT SCALE DRAWING OR UPDATE MANUALLY. 5 Connectivity Solutions 11-14-06 SHEET 1 OF 1 DRAWING NO. 25-7510 1 SIZE C A
CP-AD-515 价格&库存
很抱歉,暂时无法提供与“CP-AD-515”相匹配的价格&库存,您可以联系我们找货
