USB 2.0 to Serial ATA (SATA) and IDE Adapter
for 2.5in / 3.5in / 5.25in Hard Drives
MODEL NUMBER: U238-000-1
Highlights
Easily transfer between SATA
and IDE drives via USB
Ideal for configuring hard drives
without having to install them
first
USB 2.0 and SATA 1.0a
compliant
Compatible with 2.5" / 3.5" /
5.25" SATA and IDE drives
Includes J-Micron backup and
restore software
Compatible with Windows, Mac,
and Linux
System Requirements
Ideal for home or business applications that require individual or simultaneous connection to either a
Serial ATA or IDE drive to format hard drives, salvage data off old drives or add more external storage.
2.5" / 3.5" / 5.25" SATA and/or
IDE drive
Computer with an available USB
port
J-Micron software compatible
with Windows OS up to 10
U238-000-1 compatible with
Windows, Mac, and Linux
Description
Tripp Lite's USB 2.0 to SATA / IDE Adapter allows individual or simultaneous connection to either a Serial
ATA or IDE drive (2.5" / 3.5" / 5.25"). You can also transfer data between a SATA and an IDE drive over
the adapter. It provides a convenient, efficient way to format hard drives or transfer files without having to
install them first. With the U238-000-1, any SATA or IDE drive can be conveniently turned into an external
USB 2.0 storage drive. J-Micron software is included to allow you to quickly backup and restore files. The
backup button on the unit allows for quick backup of your files with the press of a button. J-Micron is
compatible with Windows OS up to 10. The U238-000-1 is compatible with Windows, Mac, and Linux.
Features
USB 2.0 and SATA 1.0a Compliant
Operates with one IDE and one SATA drive simultaneously
Supports Plug-n-Play
USB Mass Storage Class Bulk-Only Transport specification
40-pin and 44-pin IDE connectors, and a 22-Pin SATA Data + Power connector
Compatible with 2.5" / 3.5" / 5.25" SATA and IDE drives
Includes J-Micron backup and restore software, and features a button for one touch backup
Compatible with Windows, Mac, and Linux
Specifications
OVERVIEW
UPC Code
037332173379
Technology
USB 2.0 (High Speed); SATA/eSATA
1/2
Package Includes
USB 2.0 to SATA/IDE Combo
Adapter
USB 2.0 Cable - 5-Pin Mini B
Male to A Male
4-Pin Molex Power Cable
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.8A; Output:
12V, 2A)
Backup Software CD
Owner's Manual
POWER
AC Adapter
Input: 100-240V, 50/60Hz, 0.8A; Output: 12V, 2A
PHYSICAL
Color
Black
Shipping Dimensions (hwd / cm)
13.46 x 7.37 x 12.19
Shipping Dimensions (hwd / in.)
5.30 x 2.90 x 4.80
Shipping Weight (kg)
0.32
Shipping Weight (lbs.)
0.70
CONNECTIONS
Side A - Connector 1
USB MINI-B 5-PIN (FEMALE)
Side B - Connector 1
22 PIN SATA + POWER (FEMALE)
Side B - Connector 2
40 POS. SOCKET (FEMALE)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U238-000-1”相匹配的价格&库存,您可以联系我们找货
