MCX 50 Ohm
End Launch Jack Receptacle Round Contact
INCHES (MILLIMETERS)
CUSTOMER DRAWINGS AVAILABLE UPON REQUEST
BOARD THICKNESS
GOLD PLATED
NICKEL PLATED
"A"
"B"
.042 (1.07)
133-3701-811
133-3701-816
.048 (1.22)
.068 (1.73)
Cinch Connectivity Solutions
299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
MCX - 50 Ohm Connectors
Specifications
ELECTRICAL RATINGS
Impedance: 50 Ohms
Frequency Range: Connectors .............................................. 0-6 GHz
Dummy loads .......................................... 0-1 GHz
VSWR: (f = GHz)
Straight Cabled
Right Angle
Connectors Cabled Connectors
RG-178 cable ................................... 1.17 + .04f
1.07 + .06f
RG-316 and .086 semi-rigid cable ... 1.13 + .04f
1.07 + .04f
Adapters .............................................................................. 1.13 + .04f
Uncabled receptacles, Dummy loads ............................................ N/A
Working Voltage: (Vrms maximum)†
Connectors for Cable Type
Sea Level
70K Feet
RG-178 ................................................... 250
65
RG-316, .086 semi-rigid uncabled
uncabled receptacles, adapters ............ 335
85
Dummy loads ............................................................................. N/A
Dielectric Withstanding Voltage: (VRMS minimum at sea level)
Connectors for RG-178 .............................................................. 750
Connectors for RG-316, .086 semi-rigid,
uncabled receptacles, adapters ............................................ 1000
Corona Level: (Volts minimum at 70,000 feet)
Connectors for RG-178 .............................................................. 190
uncabled receptacles, adapters .............................................. 250
Insertion Loss: (dB maximum, tested at 1 GHz)
Straight cable connectors and adapters ................................. 0.1 dB
Right angle cable connectors ................................................. 0.2 dB
Uncabled receptacles, dummy loads ......................................... N/A
Insulation Resistance: 10,000 megohms minimum
After
Contact Resistance: (milliohms maximum)
Initial Environmental
Center contact (straight cabled connectors,
uncabled receptacles and adapters) ................. 5.0
8.0
Center contact (right angle cabled connectors) .... 5.0
15.0
Outer contact ........................................................ 1.0
1.5
Braid to body (gold plated connectors) ................. 1.0
N/A
Braid to body (nickel plated connectors) ...............2.5
N/A
RF Leakage: (dB typical tested at 2.5 GHz)
Cable connectors .................................................................. -55 dB
Uncabled receptacles and adapters, dummy loads ................... N/A
Avoid user injury due to misapplication. See safety advisory definitions on page 2.
** All gold plated parts include a .00005" min. nickel underplate barrier layer.
RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4
and 7 MHz)
Connectors for RG178 ............................................................... 500
Connectors for RG316 and adapters ......................................... 700
.086 semi-rigid ............................................................................ 670
Uncabled receptacles ................................................................. 600
Power Rating (Dummy Load): 0.5 watt @ +25°C, derated to 0.25 watt
@ +125°C
MECHANICAL RATINGS
Engagement Design: Compatible with CECC 22220, Series MCX
Engagement Force: 5.6 pounds maximum axial force
Disengagement Force: 8 pounds maximum axial force, 1 pound min.
Contact Retention: 2.3 pounds min. axial force (captivated contacts)
1 inch-ounce min. torque (uncabled receptacles)
Cable Retention:
Axial Force*
Torque
(pounds)
(in-oz)
Connectors for RG178 ................................ 10
N/A
Connectors for RG316 ................................ 20
N/A
Connectors for RG316DS ........................... 25
N/A
Connectors for .086 semi-rigid .................... 30
16
* or cable breaking strength whichever is less.
ENVIRONMENTAL RATINGS (Meets or exceed the applicable
paragraph of MIL-C-39012)Durability: 500 cycles minimum
Temperature Range:Connectors ............................... - 65°C to + 165°C
Dummy loads .......................... - 65°C to + 125°C
Thermal Shock: MIL-STD-202, Method 107, Condition F (N/A dummy
loads)
Corrosion: MIL-STD-202, Method 101, Condition B (N/A dummy loads)
Shock: MIL-STD-202, Method 213, Condition B (N/A dummy loads)
Vibration: MIL-STD-202, Method 204, Condition B (N/A dummy loads)
Moisture Resistance: MIL-STD-202, Method 106 (N/A dummy loads)
MATERIAL SPECIFICATIONS
Bodies: Brass per QQ-B-626 or zinc per ASTM B86-71, gold plated**
per MIL-G-45204 .00001” min or nickel plated per QQ-N-290 or
bright tin plated
Contacts: Male - brass per QQ-B-626, gold plated per MIL-G-45204
.00003" min.
Female - beryllium copper per QQ-C-530, gold plated per MIL-G45204 .00003" min.
Insulators: PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457
Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204
.00001" min. or nickel plated per QQ-N-290
Crimp Sleeves: Copper per WW-T-799, gold plated per MIL-G-45204
Mounting Hardware: Brass (nuts) per QQ-B-626 or phosphor bronze
(lockwashers) QQ-B-750, gold plated per MIL-G-45204 .00001" min.
MATING ENGAGEMENT FOR MCX SERIES COMPATIBLE WITH CECC 22220
JACK
JACK
PLUG
PLUG
NOTES
1. ID of contact to meet VSWR mating characteristics and connector
durability when mated with a dia. .019-.021 (0.48-0.53) male contact.
2. Must meet the force to engage and disengage when mated with
mating part.
很抱歉,暂时无法提供与“133-3701-811”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+70.64531
- 45+69.38846
- 90+68.09895
- 国内价格 香港价格
- 1+126.381321+16.38143
- 10+107.4001410+13.92111
- 25+100.6735925+13.04922
- 50+95.8664750+12.42612
- 100+91.29182100+11.83316
- 250+85.58001250+11.09280
- 500+81.49921500+10.56385
- 1000+77.614211000+10.06028
