MCPK-8-T
MCPK-8-T
    SAMTEC(申泰)
    6件套 MCPK-8-T
MCPK-8-T 数据手册
DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] REVISION B MCPK-8-X PLUG KIT SIZE CN-30-8 END (SEE NOTE 7) -T: TERMINAL -S: SOCKET CC-30-8 CG-30-8 SPC-30-8 SUB-MCR-8-12 12 POSITION -S: SOCKET FIG 1 MCPK-8-S SHOWN ALIGNMENT ARROW 37.30 1.469 REF 01 DO NOT SCALE FROM THIS PRINT 03 CN-30-8 07 04 CC-30-8 10 08 CG-30-8 15.00 .591 REF 12 11 SPR-30-8 12 POSITION -T: TERMINAL ALIGNMENT ARROW CR-30-8 39.50 1.555 REF 03 01 SUB-MCP-8-12 FIG 2 MCPK-8-T SHOWN NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. COMPONENTS TO BE PACKAGED PER PACKAGING STANDARDS, REFERENCE PACKAGING MANUAL. 3. TORQUE SPECIFICATION FOR CN-30-8 (CABLE NUT): 0.5 Nm [4.4 IN-LBS] 4. CABLE DIAMETER RANGE SPECIFICATION: 6.20[.244] - 7.00[.276] 5. -T (TERMINAL): REFERENCE DCA-MCP-8 PRINT FOR TERMINAL DUSTCAP -S (SOCKET): REFERENCE DCA-MCR-8 PRINT FOR SOCKET DUSTCAP 6. PLACE HDRL-07 (LABEL) ON BAG. LABEL TO HAVE THE FOLLOWING PRINTED IN ARIAL FONT SIZE 9: LINE 1 - "FOR ASSEMBLY INSTRUCTIONS SEE" LINE 2 - "WWW.SAMTEC.COM/MCPKFTK" LINE 3 - PART NUMBER "XXXXXX" LINE 4 - SHOP ORDER NUMBER "XXXXXXX" 7. -T (TERMINAL): REFERENCE TC114-XXXX-X-X PRINT FOR TERMINALS. -S (SOCKET): REFERENCE CC393-XXXX-X-X PRINT FOR CONTACTS. 04 07 08 10 12 11 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 2 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] MATERIAL: 15.50 .610 REF PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATORS, CABLE NUT, C-RING: PPS GASKET, O-RING: SILICONE SPRING: STAINLESS STEEL COUPLING RING, SPACER: PBT CABLE CLAMP: POM c:\enterprisevault\DWG\MISC\MKTG\MCPK-8-X-MKT.SLDDRW SHEET SCALE: 1:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MINI CIRC. CABLE KIT DWG. NO. MCPK-8-X BY: J. BORGELT 4/15/13 SHEET 1 OF 1
MCPK-8-T 价格&库存
很抱歉,暂时无法提供与“MCPK-8-T”相匹配的价格&库存,您可以联系我们找货
MCPK-8-T
    • 1+59.20560
    • 10+57.74760
    • 30+56.77560
    库存:10
