13848-18G02B
13848-18G02B
    EATON(伊顿)
    13848-18G02B
13848-18G02B 数据手册
Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row Edge Connectors - 1 Sided Boards/Vertical Mount Series 1384X Edge Connectors – 1 Sided Boards/Vertical Mount SPECIFICATIONS 13848-08G02B Rating: 10A, 250V 3 Center Spacing: 0.375” or ⁄8” (9.52mm) Wire Range: #14-22 AWG Cu; entry to PC board at 90° angle. Number of Poles: 4- to 16-poles PC Board: Edge contact accepts standard 1⁄16” (0.0625) PCB. Contacts: Cantilever design 0.02” thick phosphorus bronze with mating surface tin-plated (0.0002) over copper (0.00005). Terminals: Pressure plate terminals. Material: Black, UL Rated 94V0 Thermoplastic (125°C) Operating Temperature: -55°C to 105°C (212°F) Agency Information: File E62622; CSA File 47235 13847-08TO2B Dimensions - in (mm) Poles A B C D 04 05 06 08 10 12 14 16 18 2.25 2.62 3.00 3.75 4.50 5.25 6.00 6.75 7.50 1.87 2.25 2.62 3.37 4.12 4.87 5.62 6.37 7.12 1.12 1.50 1.87 2.62 3.37 4.12 4.87 5.62 6.37 1.53 1.90 2.28 3.03 3.78 4.53 5.28 6.03 6.40 13847 Series A B C 0.89 (22.6) 0.15 (3.9) D * Dimensions in inches. To convert to millimeters, multiply by 25.4. Optional polarizing key (Part No. C5971) consult with factory. 1.03 (26.2) 13848 Series A B C 0.15 (3.9) 1 1.03 (26.2) 2 3 4 5 Ø.06 (Ø1.5) 6 11 12 13 14 15 D Ø.09 (Ø 2.3) Part Numbering System 1n 3n 8n 4 n Series n Block Style nn Poles – 7 - Flat mtg. ears 04 to 18 w/ 2 slots 8 - Mtg. ears w/2 standoffs with hole for mounting strip Terminal Plating Screw Style n 0n 2 n B n T - Tin over copper 02 - #6-32 pan head. w/ SEMS wire clamp B - Black Block Color – n Special Options M - Marking strip * Consult Factory For additional product information, visit www.eaton.com/connectors 108
13848-18G02B 价格&库存
很抱歉,暂时无法提供与“13848-18G02B”相匹配的价格&库存,您可以联系我们找货
