319
319
    SWITCHCRAFT
    CIRCUIT BOARD FOR 221I
319 数据手册
INTRODUCING...AUDIOSTIX! AudioStix from Switchcraft® are the newest additions to our expanding line of premium pro audio products. They can be used as stand-alone adapters, rear mounted into our modular QGPK Series rack panels, or permanently installed into any number of custom racks and wall plates. AudioStix are made in the USA. For more information, visit www.switchcraft.com #318 MINI AUDIOSTIX • 3.5mm (1/8” Mini) Stereo Output • Balanced, Mono, Mic-Level XLR Output • Volume Control • Ground Lift Switch • Transformer Isolation • Output: Mic Level #318 1/8” Stereo Jack to Balanced, Mono 3-Pin Male XLR with Volume Control and Ground Lift Switch #319 MINI AUDIOSTIX FOR PERMANENT INSTALL • • • • 3.5mm (1/8” Mini) Stereo Output Balanced, Mono, Line-Level Terminal Block Output 20dB Pad Switch Ground Lift Switch • • • Transformer Isolation Output: Line Level Use individually or rear mount into our QGPK Series rack panels #319 1/8” Stereo Jack to Balanced, Mono 3-Contact Terminal Block with Pad and Ground Lift Switch #366R & #367R AES/EBU IMPEDANCE ADAPTERS • • • XLR Female to BNC (366R) BNC to XLR Male (367R) Adapts 75 Ohm (BNC) to 110 Ohm (XLR) • • Transformer Isolation Use individually or rear mount into our QGPK Series rack panels #366R AES-EBU Adapter (110-75 Ohm), Female XLR to BNC #367R AES-EBU Adapter (75-110 Ohm), BNC to Male XLR 5555 N ELSTON AVE | CHICAGO, IL 60630 | P: 773.792.2700 | F: 773.792.2129 | WWW.SWITCHCRAFT.COM Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Switchcraft: 319 367R 366R 318
319
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为集电极,6脚为发射极。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
很抱歉,暂时无法提供与“319”相匹配的价格&库存,您可以联系我们找货
  • 1+1162.330431+150.66016
  • 10+988.0261610+128.06700
  • 25+926.2193025+120.05566
  • 50+882.0721350+114.33334
  • 100+840.03758100+108.88487
库存:3
