MBG Series
The plastic connector with metal quick mating feature
MBG provides the complete answer to high number of mating cycles
Endurance
Rapid and secure locking
In accordance with
Complete range of contacts
5 000 mating/unmating cycles
Locks with audible positive «click»
UL file: E238675
CSA certfied: LR54977
Trim Trio contacts #16
MBG Series | Overview
Layout
Contacts number
Insert arrangement
MBG4
4
MBG12
12
MBG19
19
MBG30
30
MBG46
46
3
MBG Series | Connectors
OR
OR
WITH
Specifications
Part number
Contacts
number*
Panel mounting receptacle
Strain relief
For female contacts
For male contacts
For male contacts
For female contacts
4
MBG4P1
MBG4P11
MBG4R1
MBG4R11
MBG4S1
12
MBG12P1
MBG12P11
MBG12R1
MBG12R11
MBG12S1
19
MBG19P1
MBG19P11
MBG19R1
MBG19R11
MBG19S1
30
MBG30P1
MBG30P11
MBG30R1
MBG30R11
46
MBG46P1
MBG46P11
MBG46R1
MBG46R11
*Contacts supply separately
4
Plug
MBG30S1
MBG30S2
MBG46S1
Dimensions
Plug - MBG.P.
L
B
B
MBG4P11 only
ØA
ØA
Contacts
number
ØA±0.25
B±0.25
4
15.08
21.90
12
19.43
27.25
19
22.83
30.53
30
27.94
35.51
46
34.42
41.91
L
30.5
Receptacle - MBG.R.
MBG4R11 only
3.15±0.25
A
Contacts
number
ØA±0.25
B max
F
C
D
F
C
D
L
A
ØE
B
B
ØE
C±0.18
D±0.30
ØE±0.18
F max
4
15.08
21.90
31.45
37.36
20.07
29.46
12
19.43
27.25
30.76
36.86
24.64
34.93
19
22.83
30.53
34.04
40.13
27.86
38.10
30
27.94
35.51
38.00
44.91
33.10
43.31
46
34.42
41.91
46.94
54.05
39.70
49.61
L±0.25
40.2
Note: all dimensions are in mm and for information only
5
Dimensions
Strain relief - MBG.S.
Clamp MBG30S2
only
Side A
Side B
Side A
E
ØC
ØD
Side B
L
ØG
F
F
F
Clamp MBG4S1
only
Contacts
number
ØC
ØD
E
F
ØG side A
ØG side B
4
12.2
15.0
20.1
5.3
8.51/6.35
12
18.8
21.1
26.4
7.9
11.30/7.65
14.99/11.38
19
21.3
24.4
29.0
9.4
13.08/8.66
17.53/13.12
30S1
26.7
29.0
34.5
16.3
19.02/15.88
22.86/19.05
30S2
26.7
29.0
34.5
14.0
12.67/10.01
15.85/12.70
L max
54.5
Panel cut
21.3
J
R 0.4 max
N
2.5
View B
Ø3.4 (4x)
Fig.2 For back panel mounting
Contacts
number
Fig.
J
K
L
M
N
4
1
20.86
27.41
18.08
31.45
10.16
12
2
25.30
32.74
26.54
30.76
11.65
19
2
28.50
35.89
26.54
34.04
13.32
30S1
2
33.73
40.97
28.65
38.00
15.49
30S2
2
40.36
47.22
35.13
46.94
18.85
R 1.0
K
N
P
R
L
Ø3.4 (3x)
Fig.1 For back panel mounting
6
ll
Fu
View A
L
For front panel
mounting
21.3
M
J
M
K
See view B
10.6
For front panel
mounting
J
2.5
R 0.4 max
See view A
10.3
P
Standard version
Reversed version
0.25
0.9
Tooling
Handle (without head)
Tool kit
Part number
Part number
SHANDLES
TOOLKIT
Head Crimp Tooling (without handle)
Contacts
Extraction Tool #16
Part number
RX2025GE1
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
Part number
of head
Contact size
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6mm
Coaxial contacts
#16
Ø 1.6mm
M10S1J
with die set &
stop bushing
(1): Example of plating, for other plating options see page 9
* Heads to be used with handle PN: SHANDLES
Handle
(2): loose contact
Head
Complete set
7
MBG Series | Contacts
Contacts
Female
Max
wire Ø
Max
insulator Ø
Machined
30-28
26-24
22-20
22-20
20-16
16-14
RM28M1K(1)
RM24M9K(1)
RM20M13K(1)
RM20M12K(1)
RM16M23K(1)
RM14M30K(1)
RC28M1K(1)
RC24M9K(1)
RC20M13K(1)
RC20M12K(1)
RC16M23K(1)
RC14M30K(1)
0.55
0.80
1.15
1.15
1.80
2.30
1.00
1.60
1.80
2.20
3.20
3.20
Stamped & Formed Reeled
Contacts
26-24
22-20
18-16
18-16
14
SM24M1TK6(1)(2)
SM20M1TK6(1)(2)
SM16M1TK6(1)(2)
SM16M11TK6(1)(2)
SM14M1TK6(1)(2)
SC24M1TK6(1)(2)
SC20M1TK6(1)(2)
SC16M1TK6(1)(2)
SC16M11TK6(1)(2)
SC14M1TK6(1)(2)
0.90-1.60
1.20-2.10
3.20
3.00
3.20
For jacket diameter from
1.78 to 3.05mm
Inner conductor up to 2.44mm diameter
RMDXK10D28
RMDX60xxD28
RMDXK10D28 +
york090
RMDX60xxD28
RCDXK1D28
RCDX60xxD28
RCDXK1D28 +
york090
RCDX60xxD28
AWG
Crimp
Contact type
See note (2) for loose piece
Cable Multipiece
Coaxial
Part number
Male
#16
Cable Monocrimp
Twisted pair Multipiece
Twisted pair Monocrimp
0.64 to 1.45mm
Inner conductor from AWG30 to AWG24
(2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6
Specific contacts
Contact size
#16
Ø 1.6mm
Longer RM
contact
#16
Ø 1.6mm
Shorter RC
contact
Part number
RM28M1GE1RM24M9GE1RM20M13GE1RM16M23 GE1RM14M50 GE1RM14M30 GE1RC28M1GE7RC24M9GE7RC20M13GE7RC20M12GE7RC16M23GE7RC14M50GE7RC14M30GE7-
Coaxial contacts
See pages 12
8
Hand tools (SHANDLES)
head
Tool with separate locator
Hand tool
Positioner + locator setting
Extraction tools
S16RCM20
S16RCM16
S16RCM1450
S16RCM14
S16RCM20
S16RCM16
S16RCM1450
S16RCM14
MH860
MH86186
6/8
M317
UH25
3
4/6
5/6
MH860
MH86164G
5/7
6/8
M317
UH25
3
RX2025GE1
Plating Selector Guide
Contact preloaded
Electrical characteristics:
contact resistance
#16
Ø1.6mm
Machined
Available platings (contact preloaded)
< 3mΩ
Min 0.4μ gold over 2μ Ni
Contact supply separately
contact resistance
Contact size
Available platings options (contacts supplied separately)
Active part: Gold flash over Ni
Crimp area: Nickel
Active part: 0.75μ gold min over 2μ Ni
Crimp area: 1.3μ tin over Ni
Other: Nickel
S31
#16
Ø1.6mm
Machined
< 3mΩ
Stamped &
formed
< 6mΩ
S18
#16
J
Gold flash over 2μ Ni
D70
Superseded by S31
S6
Superseded by S18
Other platings on request (contacts supplied separately)
#16
T
2μm Ni min all over +
3 to 5μm Sn all over
D28
0.75μ gold over Ni
Packaging - Size contacts #16
Due to the wide variety of applications, contact packaging is offered for small series (bulk package) and high volume production (reeled contacts):
Stamped & Formed
• 25 pieces loose package
• 3 000 pieces reeled
Machined contacts
• 50 pieces bulk package
• 1 000 pieces bulk package
• 2 000 pieces reeled
Note : 1 000 pieces bulk package available by adding 1000 at the end of the part number: e.g. RC16M23K1000
2 000 pieces reeled package available by adding K at the begining of the part number: e.g. KRC16M23K
9
Contacts (Continued)
Contact Selector Guide
Contact
size
#16
Ø1.6
mm
Wire size
Type
Part number
AWG
mm²
Male
Female
Machined
30-28
0.05-0.08
Machined
26-24
0.13-0.2
Stamped &
Formed
26-24
0.13-0.25
Machined
22-20
0.32-0.52
Stamped &
Formed
22-20
0.35-0.5
Machined
20-16
0.52-1.5
Stamped &
Formed
18-16
0.8-1.5
Stamped &
Formed
18-16
0.8-1.5
Machined
16-14
1.5-2.5
RM28M1RM24M9SM24M1-(1)
SM24ML1-(2)
RM20M13RM20M12SM20M1-(1)
SM20ML1-(2)
RM16M23SM16M1-(1)
SM16ML1-(2)
SM16M11-(1)
SM16ML11-(2)
RM14M30SM14M1-(1)
SM14ML1-(2)
RC28M1RC24M9SC24M1-(1)
SC24ML1-(2)
RC20M13RC20M12SC20M1-(1)
SC20ML1-(2)
RC16M23SC16M1-(1)
SC16ML1-(2)
SC16M11-(1)
SC16ML11-(2)
RC14M30SC14M1-(1)
SC14ML1-(2)
Stamped &
Formed
14
2.0-2.5
Max
wire Ø
Max
insulator Ø
Available
plating
see page 9
0.55
1.00
K, J
0.80
1.60
K, J
0.89-1.28
Insulation
grip
TK6, S31, S18
1.80
1.15
2.20
K, J
1.17-2.08
Insulation
grip
TK6, S31, S18
1.80
3.20
K, J
3.00
No insulation
grip
TK6, S31, S18
2.00-3.00
Insulation
grip
TK6, S31, S18
2.30
3.20
K, J
3.20
No insulation
grip
TK6, S31, S18
(1) contact reeled (2) loose contact
Exemple: RM16M3K - Size #16, Machined, AWG20 wire, gold plating.
Wire Stripping Length
Part number
Male
Machined contact
Female
Stripping
length L
(mm)
#16 - Ø 1.6mm
RM28M1- / RM24M9RM20M13- / RM20M12-
RC28M1- / RC24M9RC20M13- / RC20M12-
4.8
RM16M23- /RM14M30-
RC16M23- /RC14M30-
7.1
L
Stamped & formed
#16 - Ø 1.6mm
With insulation support
L
SM24M1- / SM24ML1SM20M1- / SM20ML1-
SC24M1- / SC24ML1SC20M1- / SC20ML1-
4
SM16M11- / SM16ML11-
SC16M11- / SC16ML11-
4.65
#16 - Ø 1.6mm
Without insulation support
SM16M1- / SM16ML1-
SC16M1- / SC16ML1-
6.35
SM14M1- / SM14ML1-
SC14M1- / SC14ML1-
6.35
L
Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B
10
First Mate Last Break Contacts
Contact
size
Type
#16
Ø1.6 mm
Machined
Longer male
contact
(+1mm)
#16
Ø1.6 mm
Shorter
female contact
(-0.7mm)
Machined
Wire size
Part number
AWG
mm²
Male
30-28
0.05-0.08
26-24
0.13-0.2
22-20
0.32-0.52
20-16
0.52-1.5
RM28M1GE1RM24M9GE1RM20M13GE1RM20M12GE1RM16M23GE1RM14M30GE1-
RC28M1GE7RC24M9GE7RC20M13GE7RC20M12GE7RC16M23GE7RC14M30GE7-
16-14
1.5-2.5
30-28
0.05-0.08
26-24
0.13-0.2
22-20
0.32-0.52
20-16
0.52-1.5
16-14
1.5-2.5
Female
Color band
Max
wire Ø
(mm)
Max
insulator Ø
(mm)
Front
nt
0.55
1.1
Red
0.8
1.6
Red
Red
1.8
Black
Red
2.2
Blue
Red
3.2
Red
2.28
Red
0.55
1.1
Blue
0.8
1.6
Red
Blue
1.8
Black
Blue
2.2
Blue
Blue
1.18
1.8
1.18
Rear
Re
1.8
3.2
Blue
2.28
Blue
Available
plating
see p. 9
K or J
K or J
How to Make FMLB / LMFB Connection
Contact 1
Contact 2
Standard male
contact
Standard female
contact
Longer male contact
Standard male
contact
Standard female
contact
Shorter female
contact
First Mate Last Break contacts should be
chosen only if the cavity is not marked with
the ground symbol. For cavities marked
with the ground symbol, standard contacts
will fulfill the same role as a first mate, last
break contact used in a standard cavity.
FMLB
LMFB
Ground symbol
11
#16 Coaxial Contacts
Coaxial Contact Range
We provide 2 types of coaxial contacts suitable for 50 or 75Ω, coaxial cable or twisted pair cable.
Monocrimp Coaxial Contact
• The monocrimp one-piece coaxial contacts offer high reliability plus the
economic advantage of a 95% reduction in installation time over conventional
assembly methods.
• This economy is achieved by simultaneously crimping both the inner conductor
and outer braid or drain wire.
Multipiece Crimp Coaxial Contact
• The inner conductor and outer braid is crimped individually.
• The thermoplastic insulating bushing in the outer body is designed to accept
and permanently retain the inner contact.
• An outer ferrule is used to connect the braid to the outer contact and provide
cable support to ensure against bending and vibration.
Suitable for Coaxial Cable or Twisted Cable
• For jacket diameter from 0.64 to 1.45mm
• For jacket diameter from 1.78 to 3.05mm
Contacts for Coaxial Cable Summary
Contact range
Contact type
Male contact
Female contact
Multipiece
RMDXK10D28
RCDXK1D28
Monocrimp
RMDX60xxD28
RCDX60xxD28
Contact part number with
cable combination
See page 13
Cabling notice
See pages 17 & 18
See page 19
Contacts for Twisted Pairs Cable Summary
12
Contact range
Male contact
Female contact
cable combination
Multipiece
RMDXK10D28
+ YORK090
RCDXK1D28
+ YORK090
See page 14
Monocrimp
RMDX60xxD28
RCDX60xxD28
Contact type
Cabling notice
See page 15
See page 16
Coaxial Cable - Contact Monocrimp and Multipiece
Cable
type
ImpeContact
dance
type
Ω
Ø over
jacket
inch
mm
Ø over
dielectric
inch
mm
Inner
cond
size
Ø outer braid
Ext.
Ø
mm
inch
mm
RG161/U
75
0.09"
2.29
0.057"
1.45
RG179A/U
75
0.105"
2.67
0.063"
1.6
0.3
0.084" 2.13 max
RG179B/U
75
0.105"
2.67
0.063"
1.6
0.3
0.084" 2.13 max
RG187/U
75
0.11"
2.79 max
0.06"
1.52
0.3
RG188/U
50
0.11"
2.79 max
0.06"
1.52
0.51
0.078" 1.98 max
RG174/U
50
0.11"
2.92
0.06"
1.52
0.48
0.088" 2.24 max
AMPHENOL 21-598
50
0.105"
2.67
0.06"
RG196/U
50
0.08"
2.03 max
RG178A/U
50
0.075"
Multi
piece
1.52
0.48
0.034" 0.086
0.3
1.91
0.034"
0.86
0.3
0.054" 1.37 max
Male contact kit
for coaxial cable
Female contact kit
for coaxial cable
RMDXK10D28
RCDXK1D28
RG/188A/U
50
0.110"
2.79
0.06"
1.52
0.51
0.078" 1.98 max
RMDX6036D28
RCDX6036D28
KX21TVT (europe)
RG178 B/U
50
0.075"
1.91
0.034"
0.86
0.3
0.054" 1.37 max
RMDX6034D28
RCDX6034D28
RG178 / BU
50
0.075"
1.91
0.034"
0.86
0.3
0.054" 1.37 max
RMDX6050D28
RCDX6016D28
RG174/U
50
RG188A/U
50
Mono
crimp
0.115"
2.92
0.06"
1.52
0.48
0.088" 2.24 max
RMDX6032D28
RCDX6032D28
0.11"
2.79
0.06"
1.52
0.51
0.078" 1.98 max
RMDX6036D28
RCDX6036D28
RG316/U
50
0.107"
2.72
0.06"
1.52
0.51
0.078" 2.05 max
RMDX6036D28
RCDX6036D28
raychem 5024A3111
50
0.12"
3.05
0.083"
2.11
0.64
0.097"
2.46
RMDX6052D28
RCDX6052D28
raychem 5026e1614
50
0.083"
2.11
0.05"
1.27
0.48
0.067"
1.7
RMDX6036D28
RCDX6036D28
0.1"
2.54
0.058"
1.47
0.3
RMDXK10D28
RCDXK1D28
0.103"
2.62
0.06"
1.52
0.51
0.078"
1.98
RMDX6018D28
RCDX6018D28
surprenant pn 8134
PRD PN 247ASC1123-001
Multi
piece
PRD PN 247AS-C1251
0.092"
2.34
0.05"
1.27
0.64
0.067"
1.7
RMDX6018D28
RCDX6018D28
JUDD C15013010902
0.087"
2.13
0.05"
1.27
0.48
0.066"
1.67
RMDX6036D28
RCDX6036D28
CDC PIN22939200
0.09"
2.29
0.048"
1.22
0.3
0.064"
1.63
RMDX6046D28
RCDX6016D28
CDC PIN22939200
0.09"
2.29
0.048"
1.22
0.3
0.064"
1.63
RMDX6050D28
RCDX6016D28
CDC PIN245670000
0.104"
2.64
0.067"
1.7
0.3
0.083"
2.11
RMDX6050D28
RCDX6016D28
ampex
0.114"
2.9
0.075"
1.91
0.38
0.09"
1.29
RMDX6032D28
RCDX6032D28
TI PN 920580
0.7"
1.78
0.038"
0.96
0.48
0.054v
1.37
RMDX6024D28
RCDX6024D28
0.096"
2.44
RMDX6026D28
RCDX6026D28
2.11
RMDX6050D28
Mono
crimp
Honeywell PN 58000062
0.12"
3.05
0.077"
1.96
0.41
solid
0.104"
2.64
0.067"
1.7
0.3
0.09"
2.29
0.048"
1.22
0.3
1.63
RMDX6050D28
0.114"
2.9
0.075"
1.91
0.38
1.29
RMDX6032D28
RCDX6032D28
0.07"
1.78
0.038"
0.96
0.48
1.37
RMDX6024D28
RCDX6024D28
0.12"
3.05
0.077"
1.96
0.41
2.44
RMDX6026D28
RCDX6026D28
13
#16 Coaxial Contacts (Continued)
Twisted Cable - Contact Monocrimp and Multipiece
Cable
type
Ø over
jacket
(single wire)
Ø outer
braid
Inner cond size
inch
mm
Stranded
definition
Ext. Ø
mm
inch
mm
Male
contact kit for
coaxial cable
Female
contact kit for
coaxial cable
2#24 stranded MIL-W-16878 type B
24
0.049"
1.24
max
7/.008
RMDXK10D28
RCDXK1D28
2 #24 solid MIL-W-76 type LW
24
0.047"
1.12
max
1/.0201
RMDXK10D28
RCDXK1D28
26
0.043"
1.09
max
7/.0063
RMDXK10D28
RCDXK1D28
28
0.028"
0.71
max
RMDXK10D28
RCDXK1D28
Twisted pair 1/.201 solid MIL-W-76
type LW or MIL-W-16878
26
0.044"
1.12
max
1/.0201
0.511
RMDXK10D28
RCDXK1D28
Twisted pair solid MIL-W-81822/3
28
0.028"
0.71
max
1/.0126
0.32
RMDXK10D28
RCDXK1D28
#28 7/.0036 per Hitachi spec
ec-711 (13-2820)
0.046"
1.17
7/.0036
RMDX6031D28 + RCDX6031D28 +
YORX090
YORX090
20218201
0.028"
0.71
YORX090
YORX090
#30 solid
0.025"
0.64
RMDX6015D28 + RCDX6015D28 +
YORX090
YORX090
#26 7/.0063
26
0.028"
0.71
7/.063
0.16
YORX090
YORX090
#26 19/.004
26
0.049"
1.24
19/.004
RMDX6019D28 + RCDX6019D28 +
YORX090
YORX090
24
0.049"
1.24
7/.008
YORX090
YORX090
#24 19/.005
24
0.057"
1.45
19/.005
YORX090
YORX090
26
1.25
19x0.1
YORX090
YORX090
24
1.25
7x0.2
YORX090
YORX090
24
1.45
19x0.13
YORX090
YORX090
26
0.7
7x0.16
YORX090
YORX090
2 #26 stranded MIL-W-76 type LW
or MIL-W-16878 type B&E
2 #28 solid MIL-W-81822/3
#24 7/.008
14
Contact
type
Inner
AWG
cond
Multi
piece
Mono
crimp
0.16
Twisted Pair Cable Multipiece Contact Cabling
Cable
reference
Contact
type
Male contact
Female
contact
Crimp
tool
Die
set
Stop
bushing
Cable strip
length
A
B
C
Inner conductor crimp
g dim t dim
Braid crimp
g dim
t dim
2#24 stranded mil
w 16878 type B
2 #24 solid mil-w-76
type LW
2 #26 stranded
mil w 76 type LW or
mil w16878 type B & E
Multi
piece
2 #28 solid
mil-w-81822/3
RMDXK10D28 RCDXK1D28 M10S1J
See assembly notice
twisted pair 1/.201 solid
mil w 76 type LW or mil
w 16878
twisted pair solid mil w
81822/3
Female contact
6.35±0.41
Strip lengths
of cable
Outer hyring
YOC074
Twisted pair
adapter
Inner supporting
sleeve
YORK-090
RCDXB-055-1
Outer female contact
Inner pin
RCDX60-2
RMD26L-1
Conductor "W"
7.95±0.41
13.49±0.41
Conductor "X"
Step 1:
Step 2:
Step 3:
Twisted pair adapter
Supporting
sleeve
Outer hyring
Male contact
Outer male contact
Inner socket
RMDX60-2
RFD26L-1
Inner supporting
sleeve
RMDXB-055-3
Outer hyring
Twisted pair
adapter
YORK-090
7.95±0.41
YOC074
Conductor "Y"
Strip lengths
of cable
Conductor "Z"
7.95±0.41
15.54±0.41
Step 1:
Step 2:
Step 3:
Locking louver typical
7.54
±0.41
5.94
Inner supporting
sleeve
Outer hyring
Grounding louver typical
0.25±0.05
7.54±0.41
When using solid wire flatten
conductor "X" and "Z" using
N24FL-1 die as shown
7.95±0.41
15.54±0.41
Note : all dimensions are in mm
15
Twisted Pair Cable Monocrimp Contact Cabling
Contact
type
Cable reference
Male
contact
Female
contact
Crimp
tool
ec-711 (13-2820)
Die
set
S80
Stop
bushing
Cable strip
length
A
B
C
4.7
SL105
6.1
Inner conductor
crimp
g dim
t dim
g dim
t dim
3.07 to 2.9
4.32
1.30 to
1.12
1.4 to 1.22
2.97 to
2.84
1.4 to 1.22
2.97 to
2.84
3.07 to
2.79
20218204
S80
SL105
3.94
6.1
3.16
1.30 to
1.17
#30 solid
S83
SL105
4.7
6.1
4.06
1.22 to
1.12
1.35 to
1.22
2.97 to
2.84
3.12 to
2.95
#26 7/.0063
S80
SL105
4.7
6.1
4.06
1.30 to
1.17
1.4 to 1.22
2.97 to
2.84
3.07 to 2.9
1.35 to
1.22
2.84 to
2.79
3.12 to
2.97
Mono
crimp
#26 19/.004
RMDX6031D28
+ YORX090
#24 7/.008
RCDX6031D28
+ YORX090
M10S1J
M10SG8 ASSY'Y
TOOL DIE SET
STOP BUSHING
M10S1J TOOL
#24 19/.005
4.7
6.1
4.06
1.22 to
1.17
4.7
6.1
4.06
1.22 to
1.17
1.35 to
1.22
2.84 to
2.79
3.12 to
2.97
4.7
6.1
4.06
1.22 to
1.17
1.35 to
1.22
2.84 to
2.79
3.12 to
2.97
4.7
6
4
AWG26 (19x0.1)
M10SG8
crimping kit
AWG24 (7x0.2)
AWG24 (19x0.13)
AWG26 (7x0.16)
S80
SL105
• Select appropriate monocrimp coax twisted pair contact and cable combination.
• Select appropriate crimp tooling (hand tool, S-die set, stop bushing).
• Strip the twisted pair cable to the designated wire strip lengths.
• Insert the stripped cable into the contact. One cable is to be inserted into the
inside diameter of hyring, and pushed forward into the inner contact. The
second cable is to be inserted between the outside diameter of hyring and the
inside diameter of the outer contact body.
• Crimp the contact.
See cable strip lengths
RMDX60
Male coax contact
Cable strip length
B
C
RCDX60
Female coax contact
A
16 min.
G
G
Braid crimp (G) to be measured with
die set fully closed
16
Braid crimp
Inner conductor crimp (G) to be
measured with die set fully closed
Multipiece Male Contact with Coax Cable
Cable
reference
RG161U
RG179
RG187U
RG188/U
RG174/U
RG178A/U
RG196U
Hyring
complementary
compoments
Contact
Outer contact crimp tool
Inner contact crimp tool
Crimp tool M10S1J
Crimp tool M10S1J
Die set
Stop bushing
Die set
A
B
C
4.37
7.95
15.88
4.37
7.95
15.88
4.37
7.95
15.88
4.37
7.95
15.88
4.37
7.95
15.88
7.54
9.12
17.53
7.54
9.12
17.53
4.37
7.95
15.88
4.37
7.95
15.88
S23D2
S26D2
Male:
RMDXK10D28
S221
YOC074 +
RMDXB0553
21-598
SL471
SL46D2
S23D2
YOC074
surprenant pn
8134
Multipiece kit details
includes
Stop bushing
YOC074
AMPHENOL
RMDXK10D28
Cable strip length
Cable strip length
RMDX602D28
Outer contact
RFD26L1D28
Inner contact
YOC074
Outer hyring
RMDXB0553
Inner supporting
sleeve
A
Dielectric
diameter
B
C
Contact assembly with dielectric diameter over 1.4mm - without inner supporting sleeve
15.88±0.41
Outer male contact
Inner socket
RMDX60-2
RFD26L-1
Step 1:
- Assemble outer hyring onto cable
- Assemble inner socket to inner conductor and crimp
Outer hyring
YOC074
Step 2:
- Insert the assembly into the outer male contact
until the inner socket snaps into place
- The cable braid (shield) should now cover the
barrel of the outer male contact as shown
±0.41
7.95
Strip lengths
of cable
4.37±0.41
Step 3:
- Slide outer hyring forward against spring and
crimp in place as shown
Contact assembly with dielectric diameter under 1.4mm - with inner supporting sleeve
Outer male contact
Inner socket
RMDX60-2
RFD26L-1
Step 1:
- Assemble supporting sleeve over dielectric and under braid
- Assemble inner socket to inner conductor, push back against
sleeve and crimp
Supporting
sleeve
Outer hyring
Inner supporting
sleeve
RMDXB-055-3
Step 2:
Outer hyring
17.53±0.41
±0.41
9.12
Strip lengths
of cable
YOC074
7.54±0.41
Step 3:
17
Multipiece Female Contact with Coax Cable
Cable
reference
RG161U
RG179
RG187U
RG188/U
RG174/U
RG178A/U
RG196U
Hyring
complementary
compoments
Contact
Crimp tool M10S1J
Crimp tool M10S1J
Die set
Stop bushing
Die set
Stop bushing
S23D2
S26D2
Female:
RCDXK1D28
21-598
S221
YOC074 +
RMDXB0553
SL471
B
11.13
4.37
11.13
4.37
11.13
4.37
11.13
4.37
SL46D2
S23D2
8134
6.35
11.13
11.13
4.37
11.13
4.37
11.13
Cable strip length
RCDX602D28
Outer contact
RMD26L1D28
Inner contact
YOC074
Outer hyring
RCDXB0553
Inner supporting
sleeve
A
Dielectric
diameter
B
C
Outer hyring
11.13±0.41
YOC074
Strip lengths
of cable
4.37
Step 1:
- Assemble inner pin to inner conductor and crimp
±0.41
Inner pin
RMD26L-1
RCDX60-2
Step 2:
- Insert the assembly into the outer female contact
until the inner pin snaps into place
barrel of the outer female contact as shown
Step 3:
Outer hyring
11.13±0.41
Strip lengths
of cable
YOC074
±0.41
6.35
Step 1:
- Assemble inner pin to inner conductor, push back against
sleeve and crimp
Outer hyring
18
11.13
6.35
C
4.37
YOC074
surprenant pn
includes
A
YOC074
AMPHENOL
RCDXK1D28
Cable strip length
Supporting
sleeve
Supporting sleeve
Inner pin
RCDXB-055-1
RMD26L-1
RCDX60-2028
Step 2:
Step 3:
Coax Cable with Monocrimp Contact Cabling
Cable
reference
Male
contact
Female
contact
CDC PIN22939200
RMDX6046D28
Crimp
tool
Cable strip length
Inner conductor
crimp
g dim
t dim
Braid crimp
Die
set
Stop
bushing
A
B
C
g dim
t dim
RCDX6016D28
S80
SL105
4.19
5.97
8.51
1.30/1.17
1.40/1.22
2.77/2.64
3.02/2.84
CDC PIN22939200
RMDX6046D28
RCDX6016D28
S87
SL105
5.08
6.35
8.89
1.30/1.17
1.40/1.22
2.77/2.64
3.02/2.84
CDC PIN245670000
RMDX6050D28
RCDX6016D28
S80
SL105
5.08
6.35
8.89
1.30/1.17
1.40/1.22
2.97/2.84
3.12/2.95
KX21TVT (europe)
RG178 B/U
RMDX6034D28
RCDX6034D28
S82
SL105
5.08
6.35
8.89
1.30/1.17
1.32/1.17
2.84/2.74
3.07/2.9
RG178 / BU
RMDX6050D28
RCDX6016D28
S87
SL105
5.08
6.35
8.89
1.30/1.17
1.40/1.22
2.77/2.64
3.02/2.84
ampex
RMDX6032D28
RCDX6032D28
S80
SL105
5.08
6.35
11.68
1.30/1.17
1.40/1.22
2.97/2.84
3.12/2.95
TI PN 920580
RMDX6024D28
RCDX6024D28
S82
SL105
5.08
6.35
8.89
1.35/1.19
1.42/1.27
2.87/2.74
3.07/2.9
RG174/U
RMDX6032D28
RCDX6032D28
S80
SL105
5.08
6.35
11.68
1.30/1.17
1.40/1.22
2.97/2.84
3.12/2.95
RMDX6026D28
RCDX6026D28
S82
SL105
5.08
6.35
8.89
1.35/1.19
1.42/1.27
2.87/2.74
3.07/2.9
RG188A/U
RMDX6036D28
RCDX6036D28
S80
SL105
5.08
6.35
11.68
1.30/1.17
1.40/1.22
2.97/2.84
3.12/2.95
RG316/U
RMDX6036D28
RCDX6036D28
S80
SL105
5.08
6.35
11.68
1.30/1.17
1.40/1.22
2.97/2.84
3.12/2.95
5.08
6.35
8.89
1.22/1.17
1.35/1.22
2.92/2.79
3.12/2.97
5.08
6.35
8.89
1.22/1.17
1.35/1.22
2.92/2.79
3.12/2.97
5.08
6.35
11.68
1.37/1.27
1.45/1.32
2.92/2.79
5.08
6.35
8.89
1.22/1.17
1.35/1.22
2.92/2.79
3.12/2.97
5.08
6.35
8.89
1.22/1.17
1.35/1.22
2.92/2.79
3.12/2.97
PRD PN
247AS-C1123-001
RMDX6018D28
RCDX6018D28
M10S1J
M10SG8 ASSY'Y
TOOL DIE SET
STOP BUSHING
M10S1J TOOL
PRD PN 247AS-C1251
RMDX6018D28
RCDX6018D28
raychem 5024A3111
RMDX6052D28
RCDX6052D28
raychem 5026e1614
RMDX6036D28
RCDX6036D28
JUDD C15013010902
RMDX6036D28
inner cond. #30,
braid diam 2.64
RMDX6050D28
S80
SL105
5.1
6.35
8.9
inner cond. #30,
braid diam 2.29
RMDX6050D28
S87
SL105
4.2
6.35
8.5
inner cond. #28,
braid diam 2.9
RMDX6032D28
RCDX6032D28
S80
SL105
5.1
6.35
11.7
inner cond. #26,
braid diam 1.78
RMDX6024D28
RCDX6024D28
S82
SL105
5.1
6.35
8.9
inner cond. #26,
braid diam 3.05
RMDX6026D28
RCDX6026D28
S82
SL105
5.1
6.35
8.9
RCDX6036D28
S88
SL105
M10SG8 ASSY'Y
TOOL DIE SET
STOP BUSHING
M10S1J TOOL
• Select appropriate cable and contact combination.
• Strip coax cable to the designated wire strip lengths.
• Insert the stripped coax into the rear of the contact.
Cable strip length
RMDX60
Male coax contact
A
RCDX60
Female coax contact
B
C
19
Handle & Interchangeable Heads
Crimping with SOURIAU Tooling
1) Fully close then release the tool, keep it open.
Open the 2 pins.
2) Choose the adapter head (sold separately), keep vertical and
slide it into the handle until the mechanical end.
3) Close the two pins simultaneously to maintain the head.
4) Strip the cable properly check the recommended size
in the catalog on page 10.
GOOD
WRONG
5) Place conductors, with no deterioration, in the contact bucket.
All strands to be located in the crimp bucket.
6) Position the contact in the bottom of the tool by checking
its orientation. Maintain the wire in position.
7) Tighten sharply the handles to the end of the mechanism (max
175 N). After handles are opened, extract the contact.
8) Control the quality of crimping.
WRONG
For further information contact us at contactindustry@souriau.com
or visit our web site www.souriau-industrial.com
21
Any duplication is prohibited, unless approved in writing.
PNMBGEUSEN02 © Copyright SOURIAU 2012 - All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement.
MBG Series |
很抱歉,暂时无法提供与“MBG30P-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+148.533801+18.91770
- 10+126.2485010+16.07940
- 20+118.4002020+15.07980
- 100+107.29840100+13.66580
- 200+100.55800200+12.80740
- 500+95.77670500+12.19840
