RASM722BK
RASM722BK
    SWITCHCRAFT
RASM722BK 数据手册
0.35 9.0 0.076 PIN 1.9 A LOCKING SHOULDER 10° 0.05 1.3 LOCKING GROOVE 0.57 14.5 A 0.25 6.3 0.43 11.0 0.26 6.5 A B 0.08 2.0 0.10 2.5 0.06 1.6 0.20 5.1 0.27 6.9 SECTION A-A 0.59 14.9 0.130 3.30 1° 0.18 TYP 4.6 CENTER PIN SLEEVE SHUNT SLEEVE DETAIL A SCALE 14 : 1 0.67 17.1 NOTES: SLEEVE SHUNT 0.250 6.35 SLEEVE 0.266 6.76 CL JACK 0.07 1.7 0.150 3.81 JACK MATING FACE (EDGE OF PC BOARD) DETAIL B 0.130 3.30 RECOMMENDED PC BOARD LAYOUT (COMPONENT SIDE) SCALE 14 : 1 1. THIS PRODUCT IS RoHS COMPLIANT. CUSTOMER DRAWING 2. MATERIALS: CENTER PIN: COPPER ALLOY, NICKEL PLATED SLEEVE CONTACT: SPRING COPPER ALLOY, SILVER PLATED PIN TERMINAL AND SHUNT: COPPER ALLOY, SILVER PLATED HOUSING AND COVER: HIGH TEMPERATURE THERMOPLASTIC, BLACK 3. SPECIFICATIONS: LIFE: 5000 CYCLES; INSERTION FORCE: 5LB [2.3 KG] MAX; WITHDRAWL FORCE: 0.5 LB [0.2 KG] MIN; CONTACT RESISTANCE: 30 MILLIOHM MAX, 60 MILLIOHM MAX. AFTER TEST; INSULATION RESISTANCE: 30 MEGAOHM MIN. @ 100VDC; DIELECTRIC WITHSTANDING VOLTAGE: 250VAC FOR 1 MINUTE; CURRENT (CARRYING): 5A OPERATING TEMPERATURE: -30 C TO +65 C 0.240 6.10 SCHEMATIC SLEEVE SHUNT 0.03 0.6 0.283 7.19 0.360 9.14 0.001±0.003 TYP 0.04±0.08 SLEEVE 0.160 4.06 CENTER PIN 0.27 6.8 CENTER PIN 0.030 0.8 THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES SIZE WIDTH FINISH - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 REV ECO 25775 ECO NUMBER 1/22/07 DATE REVISIONS BS SPEC No. FIRST USED ON BY 1/17/07 TJK APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME B LBS/M TEMPER MATERIAL DATE DRAWN A MULT BY BS SPEC No. SCALE 4:1 CHKD TJK 08/20/08 APVD TJK 08/20/08 LOCKING POWER JACK, SM, 0.08 [2.0mm], RoHS SHEET PART No. 1 OF 1 RASM722BK REV A
RASM722BK 价格&库存
很抱歉,暂时无法提供与“RASM722BK”相匹配的价格&库存,您可以联系我们找货
