PCL722AS
PCL722AS
    SWITCHCRAFT
PCL722AS 数据手册
CENTER PIN/ JACK SIZE MATING POWER PLUG PCL712AS 0.10 (2.5 mm) 761KS12, 761KS15, 761KS17 PCL722AS 0.080 (2.0 mm) S761KS12, S761KS15, S761KS17 767KS12, 767KS15, 767KS17 PART NUMBER PANEL MOUNT SEAL O-RING MATING PLUG SEAL O-RING 0.156 3.96 FLAT WASHER 0.150 3.81 0.062 TYP 1.57 HEX NUT SLEEVE 0.040 1.02 CL 0.75 19.1 0.58 14.7 CENTER PIN/JACK SIZE SEE TABLE SLEEVE SHUNT G 0.060 REF 1.52 (COMPONENT SIDE) CENTER PIN SLEEVE SLEEVE SHUNT SLEEVE SCHEMATIC 0.53 13.4 0.62 15.7 SLEEVE SHUNT CENTER PIN 7/16-32 UN 2A THREAD REF NOTES: CENTER PIN RECOMMENDED PCB LAYOUT CRACKS IN CENTER PIN ROLL OVER AREA ARE ACCEPTABLE 0.014 x 0.054 [0.36 x 1.37] TERMINAL TYP REF MAXIMUM PANEL THICKNESS 0.090 2.29 0.370 9.40 REF CL 0.156 3.96 0.440±0.002 11.18±0.05 0.156 REF 3.96 0.51 12.9 RECOMMENDED PANEL MTG HOLE 1. HEX NUT, FLAT WASHER, AND PANEL O-RING SUPPLIED UNASSEMBLED CUSTOMER DRAWING 2. DIMENSIONS SHOWN FOR REFERENCE ONLY. 3. MATERIAL: HOUSINGS, HEX NUT - COPPER ALLOY, NICKEL PLATED INSULATOR HOUSING - THERMOPLASTIC D O-RINGS - THERMOPLASTIC RUBBER, LUBRICATED WITH SYNTHETIC GREASE TERMINAL INSULATORS - PHENOLIC FLAT WASHER - STEEL, NICKEL PLATED PIN, SPRING, TERMINALS - COPPER ALLOY, SILVER PLATED G 4. IT IS RECOMMENDED THAT THE JACK MOUNTING NUT BE TIGHTENED SNUG BY HAND BEFORE APPLYING A FINAL TIGHTENING TORQUE OF 8-10 LB-IN USING HAND TOOLS ONLY. POWER DRIVER OR IMPACT DRIVERS ARE NOT RECOMMENDED. 5. THIS PRODUCT IS RoHS COMPLIANT THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. G 28397 06-11-21 PC TJK F 28350 12-22-20 PC TJK E 28220 11-08-19 PC TJK D 27229 12-4-13 TO TJK - TWO PLACE DECIMALS 0.02 [0.5] C 27151 5-22-13 TO TJK - THREE PLACE DECIMALS 0.005 [0.13] B 27029 10/01/12 BL TJK DATE DRAWN BY A 26591 8/6/10 RS TJK 7/23/09 PNK REV ECO NUMBER DATE REVISIONS BY APVD UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] DO NOT SCALE DRAWING SolidWorks CAD File SIZE WIDTH MULT FINISH B TEMPER MATERIAL SPEC No. FIRST USED ON NAME LBS/M SPEC No. SCALE CHKD RS 8/6/10 2:1 APVD TJK 8/6/10 SEALED POWER JACKS STRAIGHT PC, RoHS SHEET PART No. 1 OF 1 PCL712AS, PCL722AS REV G
PCL722AS 价格&库存
很抱歉,暂时无法提供与“PCL722AS”相匹配的价格&库存,您可以联系我们找货
