L722RAS
L722RAS
    SWITCHCRAFT
    L722RAS
L722RAS 数据手册
CENTER PIN/ JACK SIZE MATING POWER PLUG L712RAS 0.10 [2.5 mm] 761KS12, 761KS15, 761KS17 L722RAS 0.080 [2.0 mm] S761KS12, S761KS15, S761KS17 767KS12, 767KS15, 767KS17 PART NUMBER PANEL MOUNT SEAL O-RING MATING PLUG SEAL O-RING 0.610 15.48 FLAT WASHER 0.220±0.002 5.59±0.05 HEX NUT CENTER PIN 0.58 14.7 SLEEVE 1.03 26.3 G 0.370 9.40 REF CENTER PIN/JACK SIZE SEE TABLE 0.060 1.52 REF 1. FOR HAND INSERTION USE SPACING 0.130 [3.30] FOR AUTOMATED INSERTION USE SPACING 0.135 [3.43] 0.130±0.002 3.30±0.05 (SEE NOTE 1) 0.067±0.001 1.70±0.03 TYP 0.330 8.38 SLEEVE SHUNT RECOMMENDED PCB LAYOUT (COMPONENT SIDE) 7/16-32 UN 2A THREAD REF NOTES: MTG SURFACE OF BUSHING CRACKS IN CENTER PIN ROLL OVER AREA ARE ACCEPTABLE 0.62 15.7 MAXIMUM PANEL THICKNESS 0.090 2.29 0.130±0.002 3.30±0.05 (SEE NOTE 1) SLEEVE SHUNT 0.140 3.56 REF 0.390 9.91 CENTER PIN 0.440±0.002 11.18±0.05 SLEEVE CENTER PIN 0.610 15.5 SLEEVE SHUNT SLEEVE RECOMMENDED PANEL MTG HOLE SCHEMATIC 2. DIMENSIONS SHOWN FOR REFERENCE ONLY. CUSTOMER DRAWING 3. HEX NUT, FLAT WASHER, AND PANEL O-RING SUPPLIED UNASSEMBLED 4. MATERIAL: HOUSINGS, HEX NUT - COPPER ALLOY, NICKEL PLATED INSULATOR HOUSING - THERMOPLASTIC D O-RINGS - THERMOPLASTIC RUBBER, LUBRICATED WITH SYNTHETIC GREASE TERMINAL INSULATORS - PHENOLIC FLAT WASHER - STEEL, NICKEL PLATED PIN, SPRING, TERMINALS - COPPER ALLOY, SILVER PLATED G 5. IT IS RECOMMENDED THAT THE JACK MOUNTING NUT BE TIGHTENED SNUG BY HAND BEFORE APPLYING A FINAL TIGHTENING TORQUE OF 8-10 LB-IN USING HAND TOOLS ONLY. POWER DRIVER OR IMPACT DRIVERS ARE NOT RECOMMENDED. 6. THIS PRODUCT IS RoHS COMPLIANT THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. G 28397 06-11-21 PC TJK F 28350 12-22-20 PC TJK E 28220 11-08-19 PC TJK D 27229 12-4-13 TO TJK - TWO PLACE DECIMALS 0.02 [0.5] C 27151 5-22-13 TO TJK - THREE PLACE DECIMALS 0.005 [0.13] B 27029 10/01/12 BL TJK DATE DRAWN BY A 26591 8/6/10 RS TJK 7/23/09 PNK REV ECO NUMBER DATE REVISIONS BY APVD UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] DO NOT SCALE DRAWING SolidWorks CAD File SIZE WIDTH MULT FINISH B TEMPER MATERIAL SPEC No. FIRST USED ON NAME LBS/M SPEC No. SCALE CHKD RS 8/6/10 2:1 APVD TJK 8/6/10 SEALED POWER JACKS RIGHT ANGLE PC, RoHS SHEET PART No. 1 OF 1 L712RAS, L722RAS REV G
L722RAS 价格&库存
很抱歉,暂时无法提供与“L722RAS”相匹配的价格&库存,您可以联系我们找货
