A
B
A
SECTION A-A
C
B
SECTION B-B
Ø 0.080" (2.0mm)
CENTER PIN REF
Ø 0.10" (2.5 mm)
CENTER PIN REF
Ø 0.05" (1.3mm)
SOLID CENTER PIN REF
732A
722A
712A
J
0.82
20.8
POWER JACK
CRACKS IN CENTER PIN ROLL OVER
AREA ARE ACCEPTABLE
0.54
13.7
0.43
11.0
FLAT WASHER
C
SECTION C-C
SLEEVE
0.215
5.46
REF
HEX NUT
SLEEVE SHUNT
CENTER PIN
CENTER PIN
5/16-32 NEF 2A
THREAD REF
CENTER PIN
SLEEVE SHUNT
SLEEVE
NOTES:
1. DIMENSIONS SHOWN FOR REFERENCE ONLY.
2. HEX NUT AND FLAT WASHER SUPPLIED UNASSEMBLED.
SCHEMATIC
CUSTOMER DRAWING
3. MATERIAL:
HOUSING, HEX NUT - COPPER ALLOY, NICKEL PLATED
INSULATOR HOUSING - THERMOPLASTIC, BLACK
TERMINAL INSULATORS - PHENOLIC
FLAT WASHER - STEEL, NICKEL PLATED
PIN, SPRING, TERMINALS - COPPER ALLOY, SILVER PLATED
J 4. IT IS RECOMMENDED THAT THE JACK MOUNTING NUT BE TIGHTENED
SNUG BY HAND BEFORE APPLYING A FINAL TIGHTENING TORQUE OF
8-10 LB-IN USING HAND TOOLS ONLY. POWER DRIVER OR IMPACT
DRIVERS ARE NOT RECOMMENDED.
5. THESE PRODUCTS ARE RoHS COMPLIANT
0.055 x 0.110 SLOT
[1.40 x 2.79]
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES [mm]
SIZE
WIDTH
FINISH
- TWO PLACE DECIMALS
0.02
[0.5]
- THREE PLACE DECIMALS
0.005 [0.13]
SPEC No.
FIRST USED ON
28397
06-11-21
PC
TJK
DATE DRAWN
BY
H
27884
05-04-17
PC
TJK
09-27-17
PC
ECO NUMBER
DATE
REVISIONS
BY
APVD
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
B
LBS/M
TEMPER
MATERIAL
J
REV
MULT
SPEC No.
SCALE
CHKD
PC
09-27-17
3:1
APVD
TJK
09-27-17
POWER JACKS
7_2A SERIES, RoHS
SHEET
PART No.
1
OF
712A 722A 732A
1
REV
J
很抱歉,暂时无法提供与“732A”相匹配的价格&库存,您可以联系我们找货
