PCL712A
PCL712A
    SWITCHCRAFT
    CONN PWR JACK 2.5X5.5MM SOLDER
PCL712A 数据手册
A 0.150 3.81 B 0.156 3.96 SLEEVE SHUNT SLEEVE 0.040 1.02 0.156 3.96 A Ø 0.10" [2.5 mm] CENTER PIN REF B Ø 0.080" [2.0mm] CENTER PIN REF PCL712A CENTER PIN 0.062 1.57 TYP PCL722A RECOMMENDED PCB LAYOUT (COMPONENT SIDE) POWER JACK SLEEVE 0.64 16.2 0.285 7.24 BUSHING FLAT REF CENTER PIN CENTER PIN SLEEVE SHUNT SLEEVE SCHEMATIC 0.014 x 0.054 [0.36 x 1.37] TERMINAL TYP REF SLEEVE SHUNT FLAT WASHER CENTER PIN HEX NUT J 5/16-32 NEF 2A THREAD REF 0.43 11.0 0.315 8.00 REF NOTES: 0.45 11.4 CRACKS IN CENTER PIN ROLL OVER AREA ARE ACCEPTABLE 0.156 3.96 REF 1. DIMENSIONS SHOWN FOR REFERENCE ONLY. CUSTOMER DRAWING 2. HEX NUT AND FLAT WASHER SUPPLIED UNASSEMBLED. 3. MATERIAL: HOUSING, HEX NUT - COPPER ALLOY, NICKEL PLATED INSULATOR HOUSING - THERMOPLASTIC TERMINAL INSULATORS - PHENOLIC FLAT WASHER - STEEL, NICKEL PLATED PIN, SPRING, TERMINALS - COPPER ALLOY, SILVER PLATED J 4. IT IS RECOMMENDED THAT THE JACK MOUNTING NUT BE TIGHTENED SNUG BY HAND BEFORE APPLYING A FINAL TIGHTENING TORQUE OF 8-10 LB-IN USING HAND TOOLS ONLY. POWER DRIVER OR IMPACT DRIVERS ARE NOT RECOMMENDED. 5. THESE PRODUCTS ARE RoHS COMPLIANT THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] SIZE WIDTH FINISH SPEC No. FIRST USED ON 28397 06-11-21 PC TJK DATE DRAWN BY H 26591 8-6-10 RS TJK 10-7-93 ES ECO NUMBER DATE REVISIONS BY APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME B LBS/M TEMPER MATERIAL J REV MULT SPEC No. SCALE CHKD ES 11-11-93 3:1 APVD TAO 11-11-93 POWER JACKS PCL712A, PCL722A, RoHS SHEET PART No. 1 OF 1 PCL712A PCL722A REV J
PCL712A 价格&库存
很抱歉,暂时无法提供与“PCL712A”相匹配的价格&库存,您可以联系我们找货
PCL712A
  • 1+72.615931+9.10618
  • 10+61.7065910+7.73813
  • 25+57.8389025+7.25311
  • 50+55.0753850+6.90656
  • 100+52.44589100+6.57682
  • 300+48.53550300+6.08645
  • 500+46.81846500+5.87113
  • 1000+44.586121000+5.59119
库存:539
