S10
S10
    SWITCHCRAFT
    CONN PWR PLUG 2X5.5MM SOLDER
S10 数据手册
8 7 6 4 3 2 0.72 18.3 1.86 47.2 0.82 20.8 0.82 20.8 0.50 12.7 F 0.50 12.7 HANDLE 5/16-24 UNF 2A THREAD TUBULAR INSULATOR CENTER PIN TERMINAL (TIP) CABLE CLAMP SLEEVE TERMINAL E 1 1.86 47.2 1.52 38.6 F 5 2.49 63.3 PLUG HANDLE I.D./ CABLE O.D. RANGE SEE TABLE 2.49 63.3 0.97 24.7 TIP INSULATOR, BLUE 0.716 18.19 REF 0.26 6.6 FLOATING LOCKING RING 5/16-32 UNEF 2B THREAD 0.08 PIN I.D. [2.0] S1012, S1015, S1017 S10KS12, S10KS15, S10KS17 RUBBER SEAL HANDLE, NON-LOCKING, NON-SEALING PLUGS RUBBER SEAL HANDLE, LOCKING, SEALING PLUGS 1.00 25.4 E 0.716 18.19 REF 0.218 REF 5.54 O-RING SEAL D 0.97 24.7 1.86 47.2 0.82 20.8 D 1.86 47.2 0.82 20.8 0.38 9.5 2.04 51.8 C 2.04 51.8 0.98 24.9 C 0.98 24.9 0.716 18.19 REF 0.716 18.19 REF 0.218 5.54 B B S10 S10K METAL HANDLE, NON-LOCKING, NON-SEALING PLUG METAL HANDLE, LOCKING, NON-SEALING PLUG NOTES: 1. HANDLE AND TUBULAR INSULATOR SUPPLIED UNASSEMBLED. A 2. MATERIAL: CENTER CONTACT - COPPER ALLOY, SILVER PLATED TERMINALS - COPPER ALLOY, TIN PLATED PLUG BARREL - COPPER ALLOY, NICKEL PLATED COUPLING RING - COPPER ALLOY, NICKEL PLATED METAL HANDLE - COPPER ALLOY, NICKEL PLATED RUBBER SEAL HANDLE - BLACK ELASTOMER OVER METAL HANDLE TIP INSULATOR - THERMOPLASTIC, BLUE TERMINAL INSULATOR - PHENOLIC TUBULAR INSULATOR - MYLAR O-RING - ELASTOMER, BLACK 3. THESE PRODUCTS ARE RoHS COMPLIANT. 8 7 PART NUMBER S10 S10K HANDLE TYPE CABLE O.D. RANGE REF METAL UP TO 0.218" S1012 0.125" - 0.150" S1015 0.150" - 0.175" S1017 S10KS12 RUBBER SEAL HANDLE 0.175" - 0.210" 0.125" - 0.150" S10KS15 0.150" - 0.175" S10KS17 0.175" - 0.210" 6 MATING POWER JACKS CUSTOMER DRAWING RAPC10S, RAPC10PS, RASPC10S RASH10S, RASH10PS RASM10S, RASM10PS RASSM10S RAPC10, RAPC10P, RASPC10 RASH10, RASH10P RASM10, RASM10P RASSM10 THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] WIDTH A 27139 ECO NUMBER 04/29/13 DATE REVISIONS 4 PC BY 02/16/12 DO NOT SCALE DRAWING SolidWorks CAD File NAME C LBS/M TEMPER MATERIAL SPEC No. FIRST USED ON TJK APVD MULT FINISH DATE DRAWN REV 5 - TWO PLACE DECIMALS SIZE BY A SPEC No. SCALE CHKD PNK PNK 02/16/12 2:1 APVD SRC 01/16/12 S10 SERIES POWER PLUGS, RoHS SHEET PART No. 1 OF S10 SERIES 1 REV A
很抱歉,暂时无法提供与“S10”相匹配的价格&库存,您可以联系我们找货
