RASH10PS
RASH10PS
    SWITCHCRAFT
RASH10PS 数据手册
ABOVE REF PART NUMBER BELOW REF 0.004 0.10 SEE NOTE 3 RASH10 NO RASH10S YES RASH10P NO RASH10PS YES SEAL O-RING NOT ALWAYS SUPPLIED SEE TABLE & NOTE 1 NO YES HEX NUT SEE NOTE 1 0.95 24.2 DETAIL A 0.125 3.18 MAXIMUM PANEL THICKNESS SCALE 6 : 1 SHUNT TERMINAL PCB LOCATING POST NOT ALWAYS PRESENT SEE TABLE 0.055 1.40 MOUNTING BUSHING 5/16-32 UNEF 2A THREAD 0.47 11.9 0.08 [2.0mm] CENTER PIN FLAT WASHER SEE NOTE 1 LOCATING SEAL O-RING PCB POST 0.35 9.0 2X 0.180 4.57 0.03 0.6 CENTER PIN TERMINAL 0.10 2.5 0.23 5.8 BUSHING I.D. SLEEVE SPRING TERMINAL SLEEVE TERMINAL SLEEVE TERMINAL 0.43 11.0 0.26 6.5 A SHUNT TERMINAL 0.08 2.0 0.19 4.9 0.07 1.7 0.06 1.6 0.020 0.51 0.325 8.26 0.062 1.57 0.10 2.5 CENTER PIN TERMINAL 0.008 0.20 0.07 1.7 0.19 4.8 0.10 2.5 RASH10PS SHOWN HERE 0.349 8.87 0.248 6.29 SHUNT A SLEEVE 0.290±0.002 7.37±0.05 SCHEMATIC 0.316±0.002 8.03±0.05 1. HEX NUT, WASHER, AND O-RING (IF REQUIRED) SUPPLIED UNASSEMBLED. 2. MATERIAL: HOUSING, COVER: THERMOPLASTIC, BLACK MOUNTING BUSHING, HEX NUT: COPPER ALLOY, NICKEL PLATED CENTER PIN: COPPER ALLOY, NICKEL PLATED PIN AND SHUNT TERMINALS: COPPER ALLOY, SILVER PLATED SLEEVE SPRING TERMINAL: SPRING COPPER ALLOY, SILVER PLATED FLAT WASHER: STEEL, NICKEL PLATED O-RING: ELASTOMER, BLACK 4. THESE PRODUCTS ARE RoHS COMPLIANT. 0.04 1.1 CENTER PIN NOTES: 3. HIGH POINT OR EDGE OF EACH OF THE THREE SOLDER TABS SHALL BE WITHIN A ZONE DEFINED BY COPLANARITY OF 0.004 INCH. SURFACE A SHALL BE 0.002 BELOW OR 0.010 ABOVE THE PLANE ESTABLISHED BY THE THREE HIGH POINTS OR EDGES OF THE THREE SOLDER TABS. 0.030 0.76 0.020 0.51 0.054 1.36 0.60 15.2 0.14 3.4 TYP CUSTOMER DRAWING RECOMMENDED PANEL CUT-OUT THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] SIZE REV 27139 ECO NUMBER 04/29/13 DATE REVISIONS PC BY - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] 02/17/12 DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER BY SPEC No. SCALE 3:1 CHKD PNK PNK 02/17/12 APVD SRC 02/17/12 RA POWER JACKS, HYBRID HIGH AMP, 0.08 [2.0mm] PIN, RoHS B LBS/M MATERIAL SPEC No. FIRST USED ON TJK APVD MULT FINISH DATE DRAWN A WIDTH SHEET PART No. 1 OF RASH10 SERIES 2 REV A 0.177 4.50 0.248 6.30 0.248 6.30 0.177 4.50 0.160 4.06 0.160 4.06 0.150 3.81 0.120 3.05 0.258 6.55 0.025 0.64 SLV 0.044 1.12 A 0.120 3.05 0.150 3.81 0.025 0.64 0.258 6.55 0.044 1.12 SLV 0.040 1.02 A SLV SHUNT JACK MOUNTING SURFACE JACK MOUNTING SURFACE 0.050 1.27 0.130 3.30 PIN 0.189 4.80 PIN SHUNT 0.120 3.05 0.070 [1.78] MIN FOR CLEARANCE FIT 0.067 [1.70] MAX FOR INTERFERENCE FIT REQUIRED ONLY FOR JACKS WITH POST 0.265 6.73 0.130 3.30 0.050 1.27 SLV SHUNT 0.030 0.76 PIN SHUNT PIN 0.130 3.30 0.189 4.80 0.030 0.76 0.265 6.73 0.070 [1.78] MIN FOR CLEARANCE FIT 0.067 [1.70] MAX FOR INTERFERENCE FIT REQUIRED ONLY FOR JACKS WITH POST 0.130 3.30 0.120 3.05 0.157 3.99 0.157 3.99 2X 0.250 6.35 2X 0.250 6.35 0.349 8.87 0.478 12.14 0.349 8.86 ALTERNATE PCB LAYOUT COMPONENT SIDE 0.478 12.14 RECOMMENDED PCB LAYOUT COMPONENT SIDE CUSTOMER DRAWING SCALE 4:1 DATE DRAWN 12/03/19 DRAWN BY SHEET PART No. OF RASH10 SERIES PC SolidWorks CAD File 2 B 2 REV A
RASH10PS 价格&库存
很抱歉,暂时无法提供与“RASH10PS”相匹配的价格&库存,您可以联系我们找货
