Additional Resources:
Product Page
date
10/27/2020
page
1 of 3
MODEL: PJ-057B │ DESCRIPTION: DC POWER JACK
2.5 mm center pin
2.5 A rating
right-angle orientation
through hole
pick-n-place top
flush face
U
ED
FEATURES
N
RoHS
SPECIFICATIONS
conditions/description
rated input current
min
TI
parameter
rated input voltage
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
terminal strength
flammability rating
RoHS
Note:
Vdc
2.5
A
50
30
mΩ
mΩ
0.3
-25
500
Vac
3
kg
500
g
85
°C
5,000
cycles
O
life
units
MΩ
any direction for 10 seconds
operating temperature
max
24
100
N
insertion/withdrawal force
typ
UL94V-0
yes
1. When measured at a current of less than 100 mA/1 kHz
IS
C
SOLDERABILITY
min
typ
max
units
wave soldering
dipped in solder pot for 5 ±0.5 seconds
255
260
265
°C
D
parameter
cuidevices.com
Product Page
CUI Devices │ MODEL: PJ-057B │ DESCRIPTION: DC POWER JACK
date 10/27/2020│ page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
MATERIAL
PLATING
copper
nickel
ED
center pin
brass
tin
terminal 2
copper alloy
tin
terminal 3
brass
tin
plastic
PBT
IS
C
O
N
TI
N
U
terminal 1
D
Recommended PCB Layout
Top View
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 9.15 mm
Note:
Model
PJ-057B
Center Pin
Ø2.5 mm
1. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
Product Page
date 10/27/2020│ page 3 of 3
REVISION HISTORY
description
1.0
initial release
1.01
applied new spec template
1.02
increased voltage rating
1.03
brand update
1.04
updated drawing
date
07/30/2007
ED
rev.
09/27/2013
04/14/2016
11/05/2019
10/27/2020
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-057B”相匹配的价格&库存,您可以联系我们找货
