RASH712BK
RASH712BK
    SWITCHCRAFT
RASH712BK 数据手册
0.35 9.0 0.098 PIN 2.5 A LOCKING GROOVE 0.57 14.5 LOCKING SHOULDER 0.05 1.3 A 0.25 6.3 10° 0.43 11.0 0.26 6.5 0.13 TYP 3.4 0.10 2.5 B A 0.08 2.0 0.008 0.2 0.06 1.6 0.04 1.1 0.02 0.5 0.03 0.8 SECTION A-A 0.02 0.5 0.29 7.5 0.10 2.5 0.42 10.7 SCHEMATIC NOTES: 1. THIS PRODUCT IS RoHS COMPLIANT. 2. MATERIALS: CENTER PIN: COPPER ALLOY, NICKEL PLATED SLEEVE CONTACT: SPRING COPPER ALLOY, SILVER PLATED PIN TERMINAL AND SHUNT: COPPER ALLOY, SILVER PLATED HOUSING AND COVER: HIGH TEMPERATURE THERMOPLASTIC, BLACK DETAIL A SCALE 14 : 1 0.27 6.8 3. SPECIFICATIONS: LIFE: 5000 CYCLES; INSERTION FORCE: 5LB [2.3 KG] MAX; WITHDRAWL FORCE: 0.5 LB [0.2 KG] MIN; CONTACT RESISTANCE: 30 MILLIOHM MAX, 60 MILLIOHM MAX. AFTER TEST; INSULATION RESISTANCE: 30 MEGAOHM MIN. @ 100VDC; DIELECTRIC WITHSTANDING VOLTAGE: 250VAC FOR 1 MINUTE; CURRENT (CARRYING): 5A OPERATING TEMPERATURE: -30 C TO +65 C 0.001±0.003 TYP 0.04±0.08 0.18 TYP 4.6 0.67 17.1 DETAIL B SCALE 14 : 1 SLEEVE SHUNT SLEEVE CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED CENTER PIN 0.03 0.6 CENTER PIN SLEEVE SHUNT SLEEVE 1° 0.54 13.8 0.59 14.9 0.27 6.9 0.20 5.1 0.10 2.4 1. ALL DIMENSIONS IN INCHES 0.07 1.7 SIZE WIDTH FINISH - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 REV ECO 25775 ECO NUMBER 1/22/07 DATE REVISIONS BS SPEC No. FIRST USED ON BY 1/17/07 TJK APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME B LBS/M TEMPER MATERIAL DATE DRAWN A MULT BY BS SPEC No. SCALE 4:1 CHKD TJK 08/20/08 APVD TJK 08/20/08 LOCKING POWER JACK, SH, 0.10 [2.5mm], RoHS SHEET PART No. 1 OF 2 RASH712BK REV A 0.189 4.80 0.189 4.80 0.025 0.64 0.025 0.64 0.130 * 3.30 0.130 * 3.30 CENTER PIN 0.050 1.27 0.626 15.90 0.030 0.76 0.120 3.05 0.120 3.05 0.044 1.12 0.542 13.77 0.266 6.76 0.160 * 4.06 0.120 3.05 SLEEVE 0.294 7.47 0.050 1.27 0.160 * 4.06 0.040 1.02 0.250 * 6.35 CENTER PIN SLEEVE SLEEVE SHUNT 0.250 * 6.35 0.250 * 6.35 0.626 15.90 0.423 10.74 0.120 3.05 0.150 * 3.81 0.130 * 3.30 0.030 0.76 0.258 6.55 0.044 1.12 SLEEVE SHUNT 0.542 13.77 0.294 7.47 SLEEVE 0.266 6.76 0.423 10.75 SLEEVE 0.150 * 3.81 0.130 * 3.30 0.258 6.55 0.265 6.73 0.250 * 6.35 0.265 6.73 JACK MATING FACE (EDGE OF PC BOARD) RECOMMENDED PC BOARD LAYOUT (COMPONENT SIDE) ALTERNATE PC BOARD LAYOUT (COMPONENT SIDE) CUSTOMER DRAWING NOTE: * SURFACE MOUNT PADS. SCALE 4:1 DATE DRAWN 08/20/08 DRAWN BY SHEET TOOL No. OF RASH712BK BS SolidWorks CAD File 2 B 2 REV A
RASH712BK 价格&库存
很抱歉,暂时无法提供与“RASH712BK”相匹配的价格&库存,您可以联系我们找货
