HR41A-17WBP-5SC
HR41A-17WBP-5SC
    HRS(广濑)
    CONNHSGPLUG5POSCABLESKT
HR41A-17WBP-5SC 数据手册
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR41A Series Waterproof Connectors for Outdoor Use Jun. 2021 ③ HR41A Series/Waterproof Connectors for Outdoor Use Features 1. Waterproof Connector with Excellent Weather Resistance for Outdoor Use Bulkhead Rear Mount Type (Panel Thickness=2mm) 2 70.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. With a highly weather resistant plastic shell made of UL compliant material ( UL746C f1) , HR41A is ideal for outdoor applications. Flange Type 70 Mated Condition 2. Waterproof Performance IP67, IP68 when mated. IP67 : Left for 30 min. at a water depth of 1m. IP68 : Left for 14 days at a water depth of 2m. 3. Easy to Operate Push- on Bayonet Lock Mating : Push the plug directly into the receptacle. The push- on bayonet lock quickly achieves complete locking in a single action. Push Un-mating : Simply twist and remove the plug 1. Rotate locking collar 2. Pull Plug in either direction Locking Design ( Push- on Bayonet Lock) 4. Easy Field Assembly The simple crimp connection and easy assembly design are ideal for on- site assembly. 2 HR41A Series/Waterproof Connectors for Outdoor Use 5. Sequential Contacts Contacts are sequentially arranged. 6. Designed to Accommodate Hot Swapping Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Hot swapping condition test methods meet UL1977 standards. 7. Surge Resistant Walls between adjacent contacts provides insulation against 15kV surges caused by lightning. 8. Safety Standard Certified UL1977 standard certified. 3 HR41A Series/Waterproof Connectors for Outdoor Use Product Specifications Rated Current (Note 1) 13A (Ambient Temp. 25℃ ) Rated Voltage 1000V AC/DC UL,TÜV -40 to +105℃ Storage Temperature Range -10 to +60℃ Rated Current (Note 1) 10A Operating Temperature (Note 2) -40 to +105℃ Rated Voltage 600V AC/DC Storage Temperature Range -10 to +60℃ Items Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating Temperature (Note 2) Specifications Conditions Contact Resistance 5m Ω Max. Measured at 1A DC Insulation Resistance 5000M Ω Min. Measured at 500V DC Withstand Voltage No flashover or breakdown 2200V AC for one min. Vibration Resistance No electrical interruption of 10μ s or more Frequency : 10 to 55 to 10Hz/cycle Half amplitude 0.75mm, 5 minutes/cycle 10 cycles each in 3 axis directions Shock Resistance No electrical interruption of 10μ s or more Acceleration : 490m/s2, duration : 11ms, 3 times each in 3 axis directions Mating Durability Contact resistance 10m Ω Max. 500 times Temperature Cycle Insulation resistance 500M Ω Min. -40℃ for 30 minutes → Room temperature for 2 to 3 minutes → +105℃ for 30 minutes → Room temperature for 2 to 3 minutes. Repeated for 5 cycles. Moisture Resistance (Steady State) Insulation Resistance : 50M Ω Min. (High Humidity) 500M Ω Min. (Dry) Temperature : 40℃ , relative humidity : 90 to 95%, left for 96 hours Water Resistance No water intrusion inside connector Left submerged at a water depth of 2m in the mated condition for 14 days Note 1 : Varies depending on the temperature the connector is used at. Use within the derating curve is recommended. When applying the UL or TÜV standards, use within the derating curve. Note 2 : Includes temperature rise due to current flow. Note 3 : Depending on the cable design and specifications, cable clamping force, rotation force, waterproof performance, etc. may differ. Please confirm before use. 4 HR41A Series/Waterproof Connectors for Outdoor Use [Reference] Derating Curve HR41A (5 Contacts Conducting) Derating Curve Basic Curve Derating Curve 30 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Current[A] 25 20 15 10 5 0 Note 1 : Note 2 :                0 20 40 60 80 100 Ambient Temperature[°C] 120 The derating curve is derived from the basic curve multiplied by the derating factor of 0.8. The measurement method of the derating curve is as follows: • HR41A, unused prior to testing. • Conductor cross-sectional area of test cable : 16 AWG (1.31mm2)  • Test condition : Measured after power supplied while the mated connectors are in a stationary state. Materials / Finish Component Materials Finish UL Standard (Noncombustible) Insulator Polyamide, PBT - UL94V-0 Contact Copper Alloy Partially Gold Plated - O-ring, Gasket Silicone Rubber - - 5 HR41A Series/Waterproof Connectors for Outdoor Use Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Connector HR41A - 17 W B P A - 5 S C (##) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❾  Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Crimp Contact HR41A - S C - 1 1 1 (##) ❶ ❽ ❾     ❶ Series Name HR41A ❼ No. of Pos. 3 or 5 ❷ Shell Size 17 ❽ Contact Gender S : Female Contact P : Male Contact ❸ Specialty W : Waterproof Type ❾ Contact Assembly C : Crimp ❹ Lock Mechanism B : Bayonet Lock  ❺ Shell Type P : Plug R : Receptacle J : Jack  Contact Type 1 : Loose Contacts 2 : Reel Contacts  Design 1 : If the design of contacts of the same size   differs, 1, 2, 3 etc. are added to distinguish them  Contact Area Plating 1 : Gold Plated ❻ Serial Symbol 6 Additional specifications are identified by adding (01), (02), etc. HR41A Series/Waterproof Connectors for Outdoor Use Connector Mating Combinations Diagram Plug Receptacle (Bulkhead Rear Mount Type) Receptacle (Flange Type) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Jack Receptacle Cap Plug Cap ● Connector Plug Receptacle Jack HR41A-17WBRA-5PC HR41A-17WBRB-5PC HR41A-17WBJ-5PC HR41A-17WBJB-5PC HR41A-17WBJD-5PC HR41A-17WBJF-5PC HR41A-17WBRA-3SC - HR41A-17WBPA-5SC HR41A-17WBPAB-5SC HR41A-17WBPAD-5SC HR41A-17WBPAE-5SC HR41A-17WBPAF-5SC HR41A-17WBP-3PC HR41A-17WBPAB-3PC ● Plug Cap Plug Cap HR41A-17WBPA-5SC HR41A-17WBPAB-5SC HR41A-17WBPAD-5SC HR41A-17WBPAE-5SC HR41A-17WBP-C HR41A-17WBPAF-5SC HR41A-17WBP-3PC HR41A-17WBPAB-3PC ● Receptacle/Jack Cap Receptacle/Jack Cap HR41A-17WBRA-5PC HR41A-17WBRB-5PC HR41A-17WBRA-3SC HR41A-17WBJ-5PC HR41A-17WBR-C HR41A-17WBJB-5PC HR41A-17WBJD-5PC HR41A-17WBJF-5PC 7 HR41A Series/Waterproof Connectors for Outdoor Use Plug ● 5pos. Type Part No. HRS No. No. of Pos. Applicable Cable Diameter Remarks Purchase Unit HR41A-17WBPA-5SC CL0141-0203-1-00 10.7 to 11.5 1pc per bag HR41A-17WBPAB-5SC CL0141-0210-7-00 9.0 to 9.8 10pcs per bag (Note 2) HR41A-17WBPAD-5SC CL0141-0226-7-00 HR41A-17WBPAE-5SC CL0141-0223-9-00 7.4 to 8.2 HR41A-17WBPAF-5SC CL0141-0228-0-00 9.9 to 10.7 5 8.2 to 9.0 Sequential Mating 20pcs per bag (Note 3) 10pcs per bag (Note 2) Note 1 : Please refer to the specification document for details on the sequential mating design. Note 2 : Orders are accepted in multiples of 10pcs. Note 3 : Orders are accepted in multiples of 20pcs. ● 3pos. Type 65.8(Assembled length) 24.6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ24.6 65.8 (Assembled length) Part No. HRS No. HR41A-17WBP-3PC CL0141-0217-6-00 HR41A-17WBPAB-3PC CL0141-0232-0-00 No. of Pos. Applicable Cable Diameter Remarks Purchase Unit φ 10.7 to 11.5 - 10pcs per bag (Note 1) φ 9.0 to 9. 8 - 20pcs per bag (Note 2) 3 Note 1 : Orders are accepted in multiples of 10pcs. Note 2 : Orders are accepted in multiples of 20pcs. 8 HR41A Series/Waterproof Connectors for Outdoor Use Receptacle ● Bulkhead Rear Mount Type (5pos. Type) 30(HEX) 23.3 17.9 1 3 φ 2 4 Part No. HR41A-17WBRA-5PC HRS No. No. of Pos. Purchase Unit CL0141-0201-6-00 5 10pcs per bag (Note) Note : Orders are accepted in multiples of 10pcs. ● Bulkhead Rear Mount Type (3pos. Type) 30(HEX) 23.3 17.9 ø 1 2 Mating Alignment Mark (Triangle Mark) Part No. HR41A-17WBRA-3SC HRS No. No. of Pos. Remarks Purchase Unit CL0141-0218-9-00 3 Sequence Mating 20pcs per bag (Note 2) Note 1 : Please refer to the specification document for details on the sequential mating design. Note 2 : Orders are accepted in multiples of 20pcs. ● Flange Type (5pos.) Part No. HR41A-17WBRB-5PC 15.5 34.2 3.5 φ21 29 29 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Mating Alignment Mark (Triangle Mark) HRS No. No. of Pos. Purchase Unit CL0141-0222-6-00 5 20pcs per bag (Note) Note : Orders are accepted in multiples of 20pcs. 9 HR41A Series/Waterproof Connectors for Outdoor Use Jack ● 5pos. Type 74(Assembled Length) 4 2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 HRS No. HR41A-17WBJ-5PC CL0141-0202-9-00 HR41A-17WBJB-5PC CL0141-0212-2-00 HR41A-17WBJD-5PC CL0141-0216-3-00 HR41A-17WBJF-5PC CL0141-0229-5-00 No. of Pos. φ 3 Part No. Applicable Cable Diameter Purchase Unit 10.7 to 11.5 9.0 to 9.8 5 8.2 to 9.0 9.9 to 10.7 Note : Orders are accepted in multiples of 10pcs. 10 10pcs per bag (Note) HR41A Series/Waterproof Connectors for Outdoor Use Caps ● Plug Cap .4 Part No. HR41A-17WBP-C HRS No. CL0141-0219-1-00 Applicable Connectors Purchase Unit HR41A-17WBPA-5SC HR41A-17WBPAB-5SC HR41A-17WBPAD-5SC HR41A-17WBPAE-5SC HR41A-17WBPAF-5SC HR41A-17WBP-3PC HR41A-17WBPAB-3PC 20pcs per bag (Note) Note : Orders are accepted in multiples of 20pcs. ● Receptacle/Jack Cap φ24.6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6 φ2 Part No. HR41A-17WBR-C HRS No. CL0141-0220-0-00 Applicable Connectors HR41A-17WBRA-5PC HR41A-17WBRB-5PC HR41A-17WBRA-3SC HR41A-17WBJ-5PC HR41A-17WBJB-5PC HR41A-17WBJD-5PC HR41A-17WBJF-5PC Note : Orders are accepted in multiples of 20pcs. 11 Purchase Unit 20pcs per bag (Note) HR41A Series/Waterproof Connectors for Outdoor Use Crimp Contacts Female Contact Gold Plated ● 2.4 2.3 A Type Part No. Loose Contacts (Note 1) Reel Contacts (Note 2) Plating Thickness of Applicable Cable Contact Portion HRS No. HR41A-SC-111 CL0141-0213-5-00 Gold : 0.76μ m HR41A-SC-111(01) CL0141-0213-5 01 Gold : 0.2μ m HR41A-SC-211 CL0141-0206-0-00 Gold : 0.76μ m HR41A-SC-211(01) CL0141-0206-0-01 Gold : 0.2μ m Remarks 100pcs per bag (Note 3) 16 to 20 AWG 0.52 to 1.31mm2 5,000pcs per reel Note 1 : Use a cable with an outer diameter of φ 1.9- 2.55. Note 2 : Use a cable with an outer diameter of φ 1.9- 3.2. Note 3 : Orders are accepted in bag increments. Silver Plated 2.4 2.3 A A 24 Type Part No. HRS No. Loose Contacts JRC-SC-112 CL0114-0241-8-00 Reel Contacts JRC-SC-212 CL0114-0242-0-00 Plating Thickness of Contact Portion Silver : 5μ m Note 1 : Use a cable with an outer diameter of φ 1.9- 2.55. Note 2 : Orders are accepted in bag increments. 12 2.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 23.6 2.9 A Applicable Cable 16 to 20 AWG 0.52 to 1.31mm2 Remarks 100pcs per bag (Note 2) 5,000pcs per reel HR41A Series/Waterproof Connectors for Outdoor Use Male Contact Gold Plated ● 2.4 2.3 A 2.9 A Type Part No. Loose Contacts (Note 1) Reel Contacts (Note 2) Plating Thickness of Applicable Cable Contact Portion HRS No. HR41A-PC-111 CL0141-0214-8-00 Gold : 0.76μ m HR41A-PC-111(01) CL0141-0214-8-01 Gold : 0.2μ m HR41A-PC-211 CL0141-0207-2-00 Gold : 0.76μ m HR41A-PC-211(01) CL0141-0207-2-01 Gold : 0.2μ m Remarks 100pcs per bag (Note 3) 16 to 20 AWG 0.52 to 1.31mm2 5000pcs per reel Note 1 : Use a cable with an outer diameter of φ 1.9- 2.55. Note 2 : Use a cable with an outer diameter of φ 1.9- 3.2. Note 3 : Orders are accepted in bag increments. Silver Plated 2.4 2.3 A A 23.7 Type Part No. HRS No. Loose Contacts JRC-PC-112 CL0114-0239-6-00 Reel Contacts JRC-PC-212 CL0114-0240-5-00 Plating Thickness of Contact Portion Silver : 5μ m Note 1 : Use a cable with an outer diameter of φ 1.9- 2.55. Note 2 : Orders are accepted in bag increments. 13 2.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 24.8 Applicable Cable 16 to 20 AWG 0.52 to 1.31mm2 Remarks 100pcs per bag (Note 2) 5000pcs per reel HR41A Series/Waterproof Connectors for Outdoor Use Receptacle Panel Mounting Hole Dimensions 0.1 .5± 18 Maximum Mounting Dimensions 0.1 .5± 18 21.44±0.1 4×M3 23±0.1 Minimum Mounting Dimensions 12 ° 120 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Flange Type 0° φ2 4.2 3×11.1+0.05 0 Mating Guide Position +0 . 0 05 t=2.0(Max.) 21.44±0.1 Bulkhead, Rear Mount Type 23±0.1 4×M3 Applicable tools ● Manual Crimp Tool HT802/HR41A-11 ● ● Manual Crimp Tool JRC-TC-11, JRC-TC-12 ● Automatic Crimp Press CM-105C Extraction Tool HR41A-TP 14 HR41A Series/Waterproof Connectors for Outdoor Use Type Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Manual Items Manual Crimp Tool (Note) Automatic Crimp Press Automatic Applicable Contacts Part No. HRS No. HT802/HR41A-11-16 CL0150-0408-5-00 HT802/HR41A-11-18 CL0150-0404-4-00 HT802/HR41A-11-20 CL0150-0407-2-00 JRC-TC-11 CL0150-0033-4-00 JRC-PC-112 JRC-SC-112 16 AWG Jacket Outer Diameter : φ 1.9-2.55 JRC-TC-12 CL0150-0034-7-00 JRC-PC-112 JRC-SC-112 18 to 20 AWG Jacket Outer Diameter : φ 1.9-2.55 CM-105C CL0901-0001-0-00 - - AP105-HR41A-1 CL0901-2055-3-00 HR41A-SC-211 HR41A-PC-211 16 to 20 AWG Jacket Outer Diameter : φ 1.9-3.2 AP105-JRC-1 CL0901-2039-7-00 JRC-PC-212 JRC-SC-212 16 to 20 AWG Jacket Outer Diameter : φ 1.9-2.55 HR41A-TP CL0150-0405-7-00 - - 16 AWG Jacket Outer Diameter : φ 1.9-2.55 HR41A-SC-111 HR41A-PC-111 18 AWG Jacket Outer Diameter : φ 1.9-2.55 20 AWG Jacket Outer Diameter : φ 1.9-2.55 Press Applicator (Note) Extraction Tool Applicable Cable (Note) When using a cable with jacket outer diameter of φ 2.55 to 3.2, use AP105-HR41A-1. Connector Usage Precautions 1. Assembly and installation of connectors and components should be done in reference to the specified assembly procedures and with the proper amount of tightening torque. If the torque is too low or too strong it may result in loosening or damage. ( Please contact your Hirose representative for the correct procedures. ) 2. After mating a connector, pull on the cable slightly to confirm the connector is firmly in place. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 6/ 2021. Contents are subject to change without notice for the purpose of improvements. 15
HR41A-17WBP-5SC 价格&库存
很抱歉,暂时无法提供与“HR41A-17WBP-5SC”相匹配的价格&库存,您可以联系我们找货
