SIM Card Sockets
ID1 Series
Miniature and Thin
Photograph (1)
■Features
Slide Lock System
1. Suited for Plug-in SIM Cards of the GSM Standard (11.11)
In Europe, SIM card Subscriber Identity Modules are used
for subscriber identification with portable telephone terminals
of the GSM system for which standards have been unified.
The ID1A Series of sockets are suited for use with GSM
standard (11.11) plug-in SIM cards.
2. Miniature and Thin
These sockets are miniature and thin with a height of 2.45
mm, length of 30.6 mm, and width of 17.4 mm. The weight
has been reduced by 30% compared with our existing
products. (See Photograph (1).)
3. Suited to Automatic Mounting
The board mounting method is of the surface mount
type.In addition to the standard tray packaging
specification, an embossed tape specification suited to
automatic mounting is also available.
Photograph (2)
Structure and Names of the Parts
4. Prevention of Incorrect Insertion to the Board
A board-positioning boss prevents incorrect insertion to the
board by means of boss position and boss diameter.
5. Slide Lock System
An original lock structure securely holds the SIM card and easy
opening and closing of the card holder is another feature.
(See Photograph (2).)
■Applications
Portable terminals and equipment that use GSM Standard
C32
Photograph (3)
■Product Specifications
Current rating 1 A
Rating
Voltage rating 100 V AC
Storage temperature
-10ç to +60ç (NOTE 2)
Storage humidity 40 to 70% (NOTE 2)
Operating temperature
-30ç to +80ç (NOTE 1)
Operating humidity range 40 to 80%
Item
Specification
Conditions
1. Insulation resistance
1000Mø min.
100 V DC
2. Withstanding voltage
No flashover or insulation breakdown.
500 V AC / 1 minute
3. Contact resistance
40 mø max.
100 mA
4. Vibration
No electrical discontinuity of 10 µs or
more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm,
2 hours in each of the 3 directions.
5. Humidity (Steady state)
Contact resistance 60 mø max.
Insulation resistance 100 Mø min.
96 hours at temperature of 40ç and humidity of
90% to 95%
6. Temperature cycle
Temperature: -55ç: 30 min. --> 15 to 35ç: 5 min.
MAX --> 85ç: 30 min --> 15 to 35ç: 5 min. MAX) for 5 cycles
7. Durability (Insertion/withdrawal)
Contact resistance of 60 mø max.
5000 cycles
8. Resistance to Soldering heat
Reflow: At the recommended temperature profile
Manual soldering: 300ç for 3 seconds
No deformation of components affecting
performance.
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating
Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage,
shipment or during transportation.
■Materials
Part
Material
Insulator
Synthetic resin
Contacts
Phosphor bronze
Card holder
Synthetic resin
Slider
Synthetic resin
Finish
Remarks
Color : Black
Contact portion: Gold plating
Lead portion: Solder plating
UL94V-0
Color : Black
Color : Beige
UL94V-0
______
UL94V-0
●Ordering Information
ID1A - 6 S - 2.54 SF (21)
1
2
3
4
5
6
1 Series Name: ID1A
2 Number of contacts: 6
3 Contact type
S: Socket
4 Contact pitch: 2.54 mm
5 Terminal type
SF: SMT type
6 Packaging type
Blank: Tray packaging
(21): Embossed tape packaging
C33
■Sockets
With the card holder closed
With the card holder open
1
2
3
When locking, slide the protruding portion of the slider after the card holder has been closed.
The co-planarity at the SMT lead tip portion is 0.1 maximum.
indicates a 7.62 ±0.2 center line.
Part Number
CL No.
Number of Contacts
Packaging type
ID1A-6S-2.54SF
645-0003-9
6
Tray
ID1A-6S-2.54SF(21)
645-0003-9-21
6
Embossed tape (NOTE 1)
NOTE 1: Embossed tape packaged items are sold by the reel with 500 pieces per reel.
C34
Number of Pieces
______
500 pieces per reel
BPCB mounting pattern
BTemperature Profile
Max.
Applicable Conditions
Reflow system: IR reflow
Solder type: Cream type 63 Sn/37 Pb
(Flux component 9 wt%)
Test board: Glass epoxy 85 x 60 x 1 mm
Metal mask thickness: 0.15 mm
Conditions may change and are dependent on type
and thicness of solder.
C35
■Embossed Carrier Tape Dimensions
Unreeling direction
●Reel
C36
Dimensions
■Method of Using the Sockets
1. Part Structure and Names
Please see Photograph (3) on C39 page.
2. Opening the Holder Cover
Press the slider and at the same time move it in the direction
marked "OPEN". This action will release the lock and free the
card holder.
Remove the SIM card (as shown) so that it comes out from the
card holder.
3. Closing the Holder Cover
Insert the SIM card to the card holder.
Close the card holder, press the slider, and at the same time
move it in the direction marked "LOCK" on the card holder.
A click sound will indicate that the lock has been engaged.
C37
BPrecautions for Use
1) When opening the card holder with a SIM card inserted, avoid the action of directly lifting the SIM card and
releasing the lock. Doing so will cause damage to the lock structure.
2) The card holder is based on a structure that moves only in the turning direction. Avoid pulling or applying
unreasonable force in other directions.
3) Do not close the card holder when the slider is protruding from the card holder. Doing so will cause damage
to the lock structure. (Please refer to the photographs below.)
4) A lock that is not fully engaged will cause poor contact.
5) Do not perform hot-line insertions. (NOTE 1)
NOTE 1: The term hot-line insertion means performing an insertion while the electricity is supplied.
Yes
No
The slider is protruding
BWashing Conditions
1) Organic Solvent Washing
Solvent
IPA (Isopropyl alcohol)
HCFC (Hydrochlorofluorocarbon)
Normal temperature washing
Heated washing
Yes
Yes
Yes
Yes
2) Water Type Washing
When using water type cleaning agents (e.g., terpene, and alkali saponifiers), select the cleaning agent based
on the documentation issued by the various manufacturers of cleaning agents which describes the effects on
metals and resins.
3) Washing Precautions
Residual flux or cleaning agent on the sockets when washing with organic solvents or water type cleaners can
give rise to the deterioration of electrical performance. In this regard it is important to check whether a thorough
washing has been performed.
C38
ID1A-6S-2.54SFB(81) 价格&库存
很抱歉,暂时无法提供与“ID1A-6S-2.54SFB(81)”相匹配的价格&库存,您可以联系我们找货
