PART NUMBER PLUG FINGER
HANDLE
HANDLE
CABLE
OPENING I.D.
35HDRABAU
GOLD
BLACK
0.29
35HDRABAUS
GOLD
BLACK
0.175
35HDRANAU
GOLD
NICKEL
0.29
35HDRANAUS
GOLD
NICKEL
0.175
35HDRANN
NICKEL
NICKEL
0.29
35HDRANNS
NICKEL
NICKEL
0.175
MATERIALS:
1.52 REF
PLUG MOLDING COMPOUND - L.C.P. BLACK
SLEEVE, PLUG BODY
- BRASS, NICKEL OR GOLD PLATED
RING SLEEVE
TIP ROD
HOUSING
- ZINC, BLACK OR NICKEL PLATED
TUBULAR INSULATOR
- MYLAR, TRANSLUCENT
.41 REF
.51 REF
HANDLE
- BRASS, BLACK OR NICKEL PLATED
CLAMP TERMINAL
- CRS, TIN PLATED
SOLDER LUGS (TIP & RING)
- BRASS, TIN PLATED
.14 REF
[3.5mm]
.51 REF
SOLDER LUG
(TIP)
SOLDER LUG
(RING)
TUBULAR INSULATOR
SHIPPED UNASSEMBLED
HANDLE
SHIPPED UNASSEMBLED
CABLE OPENING I.D.
SEE TABLE
HOUSING
CLAMP TERMINAL
(SLEEVE)
CUSTOMER DRAWING
SLEEVE,
PLUG BODY
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
- TWO PLACE DECIMALS
0.01
- THREE PLACE DECIMALS
0.005
- ANGLES
1
- ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
RING
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
TIP
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
A
REV
24662
ECO NUMBER
3-23-04
DATE
REVISIONS
JL
BY
AKE
SIZE
FINISH
SPEC No.
FIRST USED ON
DATE DRAWN
6-27-00
NAME
DO NOT SCALE DRAWING
SolidWorks CAD File
MULT
B
LBS/M
TEMPER
MATERIAL
SPEC No.
SCALE
3:1
3. REMOVE ALL BURRS
APVD
WIDTH
BY
CHKD
APVD
AKE
AKE
3-23-04
AKE
3-23-04
3.5mm RA STEREO PLUG
SHEET
PART No.
1
OF
1
35HDRA SERIES
REV
A
很抱歉,暂时无法提供与“35HDRANAUS”相匹配的价格&库存,您可以联系我们找货
