SJD-3510-45
SJD-3510-45
    CUIDEVICES
    CONN STEREO JACK 3.5MM 4/5P PCB
SJD-3510-45 数据手册
Additional Resources: Product Page D E 11.0 0.433 12.0 0.472 tolerance and dimension update 2/23/2010 F 24.0 0.945 TI N 21.50 0.846 14.00 0.551 2/9/2011 4/19/2013 U 2.40 0.094 DATE 1/7/10 housing material change rib added to pin for strength, plastic and terminal material corrected 7.00 0.276 (2 PLCS) 3.60 0.142 (2 PLCS) DESCRIPTION added kinked pins ED REV. C F 6.50 0.256 2.00 0.079 4.00 0.157 3.50 0.138 12.50 0.492 3.50 0.138 N SPECIFICATIONS: RATING: 16V DC @ 0.3A CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES OPERATING TEMPERATURE: -25~85 C IS C 5L 2L 1L 1U 5.00 0.197 4U 3U 1.25 0.049 5.00 0.197 10.00 0.394 1.50 0.059 (9 PLCS) 12.50 0.492 PCB LAYOUT TOP VIEW PC FILE NAME: SJD-3510-45 Scale: 1:1 O 2.00X2.20 (2 PLCS) 4L 3L LOWER 7.50 0.295 6.00 0.236 2.50 0.098 SCHEMATIC 1.25 0.049 5.00 0.197 14.0 0.551 5U UPPER 1.00 0.039 (9 PLCS) 2.00 0.079 10.00 0.394 SJD-3510-45 MODEL NO. 3.00 0.118 (2 PLCS) COPYRIGHT 2013 BY CUI INC. MATERIAL F TERMINAL 1U TERMINAL 3U TERMINAL 4U TERMINAL 5U TERMINAL 1L TERMINAL 2L TERMINAL 3L TERMINAL 4L TERMINAL 5L COVER HOUSING Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy PBT PA-46 5U 1U 3U 4U 5L 1L 2L 3L 4L RoHS TOLERANCE: X.X ±0.3mm X.XX ±0.2mm PLATING Tin Tin Tin Tin Tin Tin Tin Tin Tin 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com TITLE: DUAL STACK 3.5mm STEREO JACK PCB MT. PART NO. RDS F UNITS: SJD-3510-45 DRAWN BY: REV: MM [INCHES] APPROVED BY: SCALE: 2:1
SJD-3510-45 价格&库存
很抱歉,暂时无法提供与“SJD-3510-45”相匹配的价格&库存,您可以联系我们找货
