SJD-3510-33
SJD-3510-33
    CUIDEVICES
    3.50mm (0.141", 1/8", Mini Plug) - Headphone Phone Jack, Dual Stereo Connector Solder
SJD-3510-33 数据手册
REV. C D E 12.0 0.472 DESCRIPTION added kinked pins tolerance and dimension update housing material change DATE 1/7/2010 3/11/2010 2/9/2011 11.0 0.433 7.00 0.276 (2 PLCS) 3.60 0.142 (2 PLCS) 2.40 0.094 24.0 0.945 21.50 0.846 13.90 0.547 6.50 0.256 SJD-3510-33 MODEL NO. 1.90 0.075 4.00 0.157 2.00 0.079 10.00 0.394 UPPER 3.00 0.118 (2 PLCS) 3.50 0.138 1.00 0.039 (9 PLCS) SCHEMATIC 12.50 0.492 5.00 0.197 14.0 0.551 7.50 0.295 LOWER 5U 1U 4U 5L 1L Scale: 1:1 4L 2.00X2.20 (2 PLCS) 6.00 0.236 RoHS 3.50 0.138 5U 2.50 0.098 TOLERANCE: X.X ±0.3mm X.XX ±0.2mm 5L 4L 1L 1U 5.00 0.197 4U 10.00 0.394 1.50 0.059 (6 PLCS) 12.50 0.492 PCB LAYOUT TOP VIEW PC FILE NAME: SJD-3510-33 SPECIFICATIONS: RATING: 16V DC @ 0.3A CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES COPYRIGHT 2011 BY CUI INC. TERMINAL 1U TERMINAL 4U TERMINAL 5U TERMINAL 1L TERMINAL 4L TERMINAL 5L COVER HOUSING MATERIAL PLATING Brass Brass PBS PBS PBS PBS PBT HF + PA46 HF NY66 Tin Tin Tin Tin Tin Tin 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com TITLE: DUAL STACK 3.5mm STEREO JACK PCB MT. PART NO. ZRJ E UNITS: SJD-3510-33 DRAWN BY: REV: MM [INCHES] APPROVED BY: SCALE: 2:1
SJD-3510-33 价格&库存
很抱歉,暂时无法提供与“SJD-3510-33”相匹配的价格&库存,您可以联系我们找货
