SJD-3511-45
SJD-3511-45
    CUIDEVICES
    CONN STEREO JACK 3.5MM 4/5P PCB
SJD-3511-45 数据手册
REV. A B C 12.60 0.496 26.30 1.035 10.00 0.394 2.00X2.20 (2 PLCS) co 1.80 0.071 (2 PLCS) 6.00 0.236 4.00 0.157 5L 1U 2L 1L 5.00 0.197 3U 4U 1.25 0.049 1.50 0.059 (7 PLCS) D 10.00 0.394 12.50 0.492 PCB LAYOUT TOP VIEW PC FILE NAME: COPYRIGHT 2011 BY CUI INC. UPPER 1.00 0.039 (7 PLCS) SCHEMATIC TERMINAL 1U TERMINAL 3U TERMINAL 4U TERMINAL 5U TERMINAL 1L TERMINAL 2L TERMINAL 3L TERMINAL 4L TERMINAL 5L FRONT SHIELD COVER HOUSING LOWER Scale: 1:1 SPECIFICATIONS: RATING: 16V DC @ 0.3A CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES is 4L 3L 2.00 0.079 (2 PLCS) nt 1.50 0.059 (2 PLCS) SJD-3511-45 MODEL NO. in 2.80 0.110 (2 PLCS) 4.00 0.157 SJD-3511-45 d 24.60 0.969 6.50 0.256 4.00 0.157 0.30 (TYP) 5.00 0.197 ue 15.00 0.591 5U DATE 12/15/2005 4/5/2006 2/9/2011 11.20 0.441 7.00 0.276 (2 PLCS) 3.60 0.142 (2 PLCS) 2.50 0.098 DESCRIPTION NEW DRAWING A dded dimensions housing material change PLATING Brass Brass Brass PBS PBS Brass Brass PBS PBS Brass PBT HF + PA46 HF NY66 Tin Tin Tin Tin Tin Tin Tin Tin Tin Tin 3U 4U 5L 1L 2L 3L 4L RoHS TOLERANCE: X.X ±0.2mm X.XX ±0.1mm X.XXX ±0.05mm MATERIAL 5U 1U V-INFINITY 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2332 866-372-1258 Fax: 503-612-2382 Website: www.v-infinity.com TITLE: DUAL STACK 3.5mm STEREO JACK w/ FNT SHLD PART NO. UNITS: SJD-3511-45 DRAWN BY: ZRJ APPROVED BY: REV: C MM [INCHES] SCALE: 2:1
SJD-3511-45 价格&库存
很抱歉,暂时无法提供与“SJD-3511-45”相匹配的价格&库存,您可以联系我们找货
