SJD-3511-33
SJD-3511-33
    CUIDEVICES
    CONN STEREO JACK 3.5MM 3/3P PCB
SJD-3511-33 数据手册
REV. A B C DESCRIPTION NEW DRAWING A dded dimensions housing material change 11.20 0.441 12.60 0.496 ue 15.00 0.591 d 7.00 0.276 (2 PLCS) 3.60 0.142 (2 PLCS) 24.60 0.969 26.30 1.035 2.80 0.110 (2 PLCS) 10.00 0.394 2.00X2.20 (2 PLCS) UPPER 1.00 0.039 (4 PLCS) SCHEMATIC 2.50 0.098 1U 1L 5.00 0.197 4U 10.00 0.394 D 12.50 0.492 1.50 0.059 (4 PLCS) PCB LAYOUT TOP VIEW PC FILE NAME: SJD-3511-33 COPYRIGHT 2011 BY CUI INC. TERMINAL 1U TERMINAL 4U TERMINAL 5U TERMINAL 1L TERMINAL 4L TERMINAL 5L FRONT SHIELD COVER HOUSING RoHS TOLERANCE: X.X ±0.2mm X.XX ±0.1mm X.XXX ±0.05mm SPECIFICATIONS: RATING: 16V DC @ 0.3A CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES is 4L 4U 5L 1L 4L 4.00 0.157 5L LOWER 5U 1U Scale: 1:1 co 1.80 0.071 (2 PLCS) 6.00 0.236 2.00 0.079 (2 PLCS) nt 1.50 0.059 (2 PLCS) 4.00 0.157 SJD-3511-33 MODEL NO. in 6.50 0.256 4.00 0.157 0.30 (TYP) 5U DATE 12/15/2005 4/4/2006 2/9/2011 MATERIAL PLATING Brass Brass PBS PBS PBS PBS Brass PBT HF + PA46 HF NY66 Tin Tin Tin Tin Tin Tin Tin 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com TITLE: DUAL STACK 3.5mm STEREO JACK w/ FNT SHLD PART NO. UNITS: SJD-3511-33 DRAWN BY: ZRJ APPROVED BY: REV: C MM [INCHES] SCALE: 2:1
SJD-3511-33 价格&库存
很抱歉,暂时无法提供与“SJD-3511-33”相匹配的价格&库存,您可以联系我们找货
