SJ-3535NGS
SJ-3535NGS
    CUIDEVICES
    CONN STEREO JACK 3.5MM 5P PCB
SJ-3535NGS 数据手册
Additional Resources: Product Page 5.65 0.222 3.60 0.142 DATE 11/28/2005 3/2/2006 14.75 0.581 tin ue 3.95 0.156 DESCRIPTION NEW DRAWING Correction made to schematic d REV. A B 6.00 0.236 12.75 0.502 7.00 0.276 0.50 0.020 (2 PLCS) 3.50 0.138 (TYP) 11.40 0.449 2.50 0.098 0.85 0.033 5.15 0.203 1 2 8.05 0.317 1.90 0.075 (6 PLCS) 1.15 0.045 1.50 0.059 1.50 0.059 3.45 0.136 1.15 0.045 2 3.45 0.136 on 2.45 0.096 4 2.45 0.096 4 8.05 0.317 1 0.85 0.033 5.15 0.203 is c 2.50 0.098 11.40 0.449 SPECIFICATIONS: RATING: 16V DC @ 300mA CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES PCB LAYOUT TOP VIEW MODEL NO. SJ-3533NGS D 1 2 SCHEMATIC 4 PC FILE NAME: SJ-3533NGS COPYRIGHT 2005 BY CUI INC. TERMINAL 1 TERMINAL 2 TERMINAL 4 BUSHING RING SPRING TIP SPRING SHIELD HOUSING MATERIAL PLATING Brass Brass Brass Brass SUS301 SUS301 Tin Tin Tin Nickel Nickel Iron Plate PBT Nickel Tin RoHS TOLERANCE: X.X ±0.2mm X.XX ±0.1mm X.XXX ±0.05mm 9615 SW Allen Blvd., Ste. 103 Beaverton, OR 97005 Phone: 503-643-4899 800-275-4899 Fax: 503-372-1266 Website: www.cui.com TITLE: 3.5mm 5 PIN RIGHT ANGLE STEREO JACK PART NO. ZRJ B UNITS: SJ-3533NGS DRAWN BY: REV: MM [INCHES] APPROVED BY: SCALE: 2:1 Additional Resources: Product Page 5.65 0.222 3.60 0.142 DATE 11/28/2005 3/2/2006 14.75 0.581 tin ue 3.95 0.156 DESCRIPTION NEW DRAWING Correction made to schematic d REV. A B 6.00 0.236 12.75 0.502 7.00 0.276 0.50 0.020 (2 PLCS) 3.50 0.138 (TYP) 11.40 0.449 2.50 0.098 0.85 0.033 11.60 0.457 1 5 2 8.05 0.317 1.90 0.075 (7 PLCS) 1.15 0.045 on 2.45 0.096 1.50 0.059 2 3.45 0.136 1.50 0.059 3.45 0.136 1.15 0.045 5.15 0.203 4 2.45 0.096 4 8.05 0.317 11.60 0.457 1 0.85 0.033 5 5.15 0.203 2.50 0.098 is c SPECIFICATIONS: RATING: 16V DC @ 300mA CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES 11.40 0.449 PCB LAYOUT TOP VIEW SJ-3534NGS 1 2 5 D MODEL NO. SCHEMATIC 4 PC FILE NAME: SJ-3534NGS COPYRIGHT 2005 BY CUI INC. TERMINAL 1 TERMINAL 2 TERMINAL 4 TERMINAL 5 BUSHING RING SPRING TIP SPRING SHIELD HOUSING MATERIAL PLATING Brass Brass Brass Brass Brass SUS301 SUS301 Tin Tin Tin Tin Nickel Nickel Iron Plate PBT Nickel Tin RoHS TOLERANCE: X.X ±0.2mm X.XX ±0.1mm X.XXX ±0.05mm 9615 SW Allen Blvd., Ste. 103 Beaverton, OR 97005 Phone: 503-643-4899 800-275-4899 Fax: 503-372-1266 Website: www.cui.com TITLE: 3.5mm 5 PIN RIGHT ANGLE STEREO JACK PART NO. ZRJ B UNITS: SJ-3534NGS DRAWN BY: REV: MM [INCHES] APPROVED BY: SCALE: 2:1 Additional Resources: Product Page 5.65 0.222 3.60 0.142 DATE 11/28/2005 3/2/2006 14.75 0.581 tin ue 3.95 0.156 DESCRIPTION NEW DRAWING Correction made to schematic d REV. A B 6.00 0.236 12.75 0.502 7.00 0.276 0.50 0.020 (2 PLCS) 3.50 0.138 (TYP) 11.40 0.449 2.50 0.098 11.60 0.457 0.85 0.033 8.05 0.317 1 3 2 6.15 0.242 1.90 0.075 (8 PLCS) 1.50 0.059 2 3.45 0.136 1.50 0.059 3.45 0.136 1.15 0.045 5.15 0.203 1.15 0.045 on 2.45 0.096 5 4 2.45 0.096 4 6.15 0.242 8.05 0.317 1 0.85 0.033 3 5 5.15 0.203 11.60 0.457 SPECIFICATIONS: RATING: 16V DC @ 300mA CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES is c 2.50 0.098 11.40 0.449 PCB LAYOUT TOP VIEW SJ-3535NGS 1 2 5 3 4 D MODEL NO. SCHEMATIC PC FILE NAME: SJ-3535NGS COPYRIGHT 2005 BY CUI INC. TERMINAL 1 TERMINAL 2 TERMINAL 3 TERMINAL 4 TERMINAL 5 BUSHING RING SPRING TIP SPRING SHIELD HOUSING MATERIAL PLATING Brass Brass Brass Brass Brass Brass SUS301 SUS301 Tin Tin Tin Tin Tin Nickel Nickel Iron Plate PBT Nickel Tin RoHS TOLERANCE: X.X ±0.2mm X.XX ±0.1mm X.XXX ±0.05mm 9615 SW Allen Blvd., Ste. 103 Beaverton, OR 97005 Phone: 503-643-4899 800-275-4899 Fax: 503-372-1266 Website: www.cui.com TITLE: 3.5mm 5 PIN RIGHT ANGLE STEREO JACK PART NO. ZRJ B UNITS: SJ-3535NGS DRAWN BY: REV: MM [INCHES] APPROVED BY: SCALE: 2:1
SJ-3535NGS 价格&库存
很抱歉,暂时无法提供与“SJ-3535NGS”相匹配的价格&库存,您可以联系我们找货
